A
B
C
D
E
F
G
H
A.3; Validé
MASS
NOTES
MATERIALS
PROTECTIVE SCHROUD
5%
1,1 g
BLACK POLYAMID
4
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
CORROSION SALT SPRAY
4
IEC61984/UL1977
-40°C TO 105°C
MIN 1000H
ROHS COMPLIANT
1. IT HAS TO BE MOUNTED ON SIZE 10 PLUG CONNECTOR
REFERENCE UTL5/ UTL6TH / UTL6JC PLUG
2.THE PROTECTIVE SHROUD SHALL BE USED TO PREVENT ANY MANUAL
UNLOCKING OF THE CONNECTOR.
3. A SCREWDRIVER TOOL SHALL BE USED OT UNLOCK THE CONNECTOR
4. *THE DIMENSION 9mm WILL BE UPDATE
5. UNIT IN MM
22 0,3
3
25 0,3
9*
3
2
CountryJurisdiction
& Control List
FR
NOT LISTED
2
P/N : UTL610PS
A
13/2/18
ISS
DATE
Designed by:
TITLE
Creation
Latest modification - by:
R.M.
Date:
13/2/18
PROTECTIVE SHROUD SIZE 10 FOR PANEL PLUG
UTL CONNECTOR
Scale
General linear
Tolerances:
1
2/1
NPRDS / PROJECT
BE170912A
WWW.SOURIAU.COM
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
H
G
F
E
FORMAT
D
A3
CUSTOMER DRAWING
MOD N $
C
SOURIAU DRG N°
UTL1-0110A-C
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL610PS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+20.883661+2.52524
