UTL6102G1W3S
UTL6102G1W3S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONNPLUGHSNGF/M6POSINLINE
UTL6102G1W3S 数据手册
A B C D E F G H B.2; Validé NOTES 8 MATERIALS SHELL COUPLING LATCH O'RING SEE TABLE STAINLESS STEEL LUBRICATED RED SILICON PERFORMANCES CHARACTERISTICS MECHANICAL TEMPERATURE CLASS DURABILITY SEALING IN MATED CONDITIONS WIRING FACE SEALING IN UNMATED CONDITIONS POLLUTION DEGREE CORROSION SALT SPRAY FLAMMABILITY OUTDOOR SUITABILITY (UV RESIST) SCOOP PROOF MATING FACE 7 28,1±0,5 11,3±0,4 15 0,5 ELECTRICAL TOUCH PROOF 20 15,5 6 23,5±0,5 POWER AND GROUND LINES: NOMINAL CURRENT IEC61984/UL1977 IEC61984 IEC60529 DIN40050 IEC60529 IEC61984 8 -40°C TO 105°C 500 MATE / UNMATE CYCLES IP68 1BAR DURING 1WEEK IP69K IP67 WITH CAPS 4 MIN 1000H MATERIAL RATING: 5VA MATERIAL RATING: (f1) UL94 UL746C 7 IEC60529 IP2X UL1977 16A WITH AWG14 WIRE / 13A WITH AWG16 WIRE 16A WITH 2.5MM² WIRE / 13A WITH 1.5MM² WIRE AT 60°C NOMINAL CURRENT IEC61984 NOMINAL VOLTAGE NOMINAL VOLTAGE UL1977 IEC61984 IEC61984 600V 250VAC 4KV 4 FOR CLASS II 500VAC 6KV 4 FOR CLASS I IEC61984 IEC61984 48V AC 5A SIGNAL CONTAC (a,b,c) LINES: NOMINAL VOLTAGE NOMINAL CURRENT 6 ROHS COMPLIANT 5 1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING 2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT 3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16 AND #20 , R*M* OR S*M* TYPES 4. CONTACTS TO BE ORDERED SEPARETELY. 5. WARNING: PHASE AND SIGNAL CONTACTS ARE FEMALE VERSION AND GROUND CONTACT IS MALE VERSION 6. UNIT IN MM 4 4 x3 #20 FEMALE SIGNAL CONTACTS LATCH P/N SHELL' S MATERIAL UTL6102G1W3S PA GF REINFORCED BLACK COLOR UTL6102G1W3S03 PA GF REINFORCED LIGHT GREY COLOR 3 3 x2 #16 POWER FEMALE CONTACTS SHELL 5 P/N : SEE TABLE x1 #16 MALE GROUND CONTACT 2 O'RING B 06/03/2015 ISS DATE Designed by: TITLE Scale 2/1 __ 23869 _ Clearances dimensions modification Latest modification - by: RAGAINE M. COUTY L. Date:17/07/2013 CUSTOMER DRAWING FEMALE PLUG LAYOUT 6 CONTACTS SIZE 10 UTL CONNECTOR General linear Tolerances: 0,2 1 WWW.SOURIAU.COM FORMAT A2 H G F E D C 2 MOD N NPRDS / PROJECT UTL This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° UTL1-0050A-C01 B CLASSIFICATION: NOT EXPORT CONTROLLED SHEET 1/1 A 1
UTL6102G1W3S 价格&库存
很抱歉,暂时无法提供与“UTL6102G1W3S”相匹配的价格&库存,您可以联系我们找货
