2SD880
2SD880
    ST(先科)
    TO220FB-3L
    通用三极管 TO220FB-3L NPN Ic=3A
2SD880 数据手册
2SD880-HAF NPN Silicon Epitaxial Planar Power Transistor Features • Halogen and Antimony Free(HAF), RoHS compliant TO-220FB Plastic Package 1.Base 2.Collector 3.Emitter Absolute Maximum Ratings(Ta = 25℃ unless otherwise specified) Parameter Symbol Value Unit Collector Base Voltage VCBO 60 V Collector Emitter Voltage VCEO 60 V Emitter Base Voltage VEBO 7 V Collector Current IC 3 A Base Current IB 0.3 A PD 30 W Tj 150 ℃ Tstg - 55 to + 150 ℃ Symbol Max. Unit RθJC 4.16 ℃/W Tc = 25℃ Power Dissipation Junction Temperature Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance - Junction to Case 1/5 ® Dated: 01/02/2021 Rev: 01 2SD880-HAF Characteristics at TC = 25℃ Parameter DC Current Gain at VCE = 5 V, IC = 0.5 A O Y G at VCE = 5 V, IC = 3 A Collector Base Cutoff Current at VCB = 60 V Emitter Base Cutoff Current at VEB = 7 V Collector Emitter Breakdown Voltage at IC = 50 mA Collector Emitter Saturation Voltage at IC = 3 A, IB = 0.3 A Base Emitter Turn-on Voltage at VCE = 5 V, IC = 0.5 A Gain Bandwidth Product at VCE = 5 V, IC = 0.5 A Output Capacitance at VCB = 10 V, IE = 0, f = 1 MHz Turn-On Time at IC = 1 A, IB1 = -IB2 = 0.2 A, VCC = 30 V, RL = 30 Ω Storage Time at IC = 1 A, IB1 = -IB2 = 0.2 A, VCC = 30 V, RL = 30 Ω Fall Time at IC = 1 A, IB1 = -IB2 = 0.2 A, VCC = 30 V, RL = 30 Ω 2/5 Symbol Min. Typ. Max. Unit hFE hFE hFE hFE 60 100 150 20 - 120 200 300 - - ICBO - - 100 µA IEBO - - 100 µA V(BR)CEO 60 - - V VCE(sat) - - 1 V VBE(on) - - 1 V fT - 3 - MHz Cob - 70 - pF ton - 0.8 - µs tstg - 1.5 - µs tf - 0.8 - µs ® Dated: 01/02/2021 Rev: 01 2SD880-HAF Electrical Characteristics Curves Fig 2. Output Characteristics Fig 1. Output Characteristics Fig 4. DC Current Gain vs. Collector Current Fig 3. Collector Current vs. VBE 3/5 ® Dated: 01/02/2021 Rev: 01 2SD880-HAF Electrical Characteristics Curves Fig 5. Power Derating Curve Fig 6. VBESAT vs. Collector Current Fig 7. VCESAT vs. Collector Current Fig 8. Output Capacitance 4/5 ® Dated: 01/02/2021 Rev: 01 2SD880-HAF Package Outline Dimensions (Units: mm) UNIT mm UNIT mm A 2.9 2.7 B 6.8 6.4 C 0.7 0.3 P 13.3 12.7 P1 8.2 7.6 Q 3.7 3.5 D 15 11 E 1.5 1.1 F 0.9 0.7 TO-220FB G 2.54 TYP. W 10.2 9.8 H 4.7 4.3 H1 2.5 2.2 K 3.1 2.7 L 16.8 14.8 L1 9.4 9.0 N 1.4 1.2 Marking information " 2SD880* " = Part No. (" * " = HFE grouping Code ) " ****** " = Date Code Marking 2SD880* Font type: Arial ****** 5/5 ® Dated: 01/02/2021 Rev: 01
2SD880 价格&库存
很抱歉,暂时无法提供与“2SD880”相匹配的价格&库存,您可以联系我们找货
