BUK7635-55A
www.VBsemi.com
N-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
60
RDS(on) ()
a, e
ID (A)
0.023 at VGS = 10 V
50
0.027 at V GS = 4.5 V
40
Qg (Max)
66 nC
• Halogen-free According to IEC 61249-2-21
Definition
• Surface Mount
• Available in Tape and Reel
• Dynamic dV/dt Rating
• Logic-Level Gate Drive
• Fast Switching
• Compliant to RoHS Directive 2002/95/EC
D
D2PAK (TO-263)
G
G D
S
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
SYMBOL
LIMIT
VDS
VGS
60
± 10
50
36
200
1.0
0.025
400
150
3.7
4.5
- 55 to + 175
300d
TC = 25 °C
Continuous Drain Currentf
VGS at 10 V
ID
TC = 100 °C
a
Pulsed Drain Current
IDM
Linear Derating Factor
Linear Derating Factor (PCB Mount)e
Single Pulse Avalanche Energyb
EAS
TC = 25 °C
Maximum Power Dissipation
PD
Maximum Power Dissipation (PCB Mount)e
TA = 25 °C
c
dV/dt
Peak Diode Recovery dV/dt
Operating Junction and Storage Temperature Range
TJ, Tstg
for 10 s
Soldering Recommendations (Peak Temperature)d
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11).
b. VDD = 25 V, starting TJ = 25 °C, L = 179 μH, Rg = 25 , IAS = 51 A (see fig. 12).
c. ISD 51 A, dI/dt 250 A/μs, VDD VDS, TJ 175 °C.
d. 1.6 mm from case.
e. When mounted on 1" square PCB (FR-4 or G-10 material).
f. Current limited by the package, (die current = 51 A).
UNIT
V
A
W/°C
mJ
W
V/ns
°C
服务热线:400-655-8788
1
BUK7635-55A
www.VBsemi.com
THERMAL RESISTANCE RATINGS
SYMBOL
TYP.
MAX.
Maximum Junction-to-Ambient
PARAMETER
RthJA
62
(PCB Mount)a
RthJA
40
Maximum Junction-to-Case (Drain)
RthJC
1.0
UNIT
°C/W
Note
a. When mounted on 1" square PCB (FR-4 or G-10 material).
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
Gate-Source Threshold Voltage
VDS
VGS = 0, ID = 250 μA
60
V
VDS/TJ
Reference to 25 °C, ID = 1 mA
0.070
V/°C
VGS(th)
VDS = VGS, ID = 250 μA
1.0
3.0
V
Gate-Source Leakage
IGSS
VGS = ± 10 V
± 100
nA
Zero Gate Voltage Drain Current
IDSS
VDS = 60 V, VGS = 0 V
25
VDS = 48 V, VGS = 0 V, TJ = 150 °C
250
Drain-Source On-State Resistance
Forward Transconductance
RDS(on)
gfs
VGS = 10 V
I D = 21 A b
23
VGS = 4.5 V
I D = 15 A b
27
23
3000
1000
200
60
10
VDS = 25 V, ID = 21A b
μA
S
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
VGS = 0 V,
VDS = 25 V,
f = 1.0 MHz, see fig. 5
VGS = 5.0 V
ID = 51 A, VDS = 48 V,
see fig. 6 and 13b
Gate-Drain Charge
Qgd
40
Turn-On Delay Time
td(on)
17
230
42
110
4.5
7.5
50c
200
Rise Time
Turn-Off Delay Time
Fall Time
Internal Drain Inductance
Internal Source Inductance
tr
td(off)
VDD = 30 V, ID = 51 A,
Rg = 4.6 , RD = 0.56 , see fig. 10b
tf
LD
LS
Between lead,
6 mm (0.25") from
package and center of
die contact
pF
nC
ns
D
nH
G
S
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
Pulsed Diode Forward Currenta
Body Diode Voltage
IS
ISM
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
MOSFET symbol
showing the
integral reverse
p - n junction diode
D
A
G
TJ = 25 °C, IS = 51 A, VGS = 0
S
Vb
TJ = 25 °C, IF = 51 A, dI/dt = 100 A/μsb
2.5
V
130
180
ns
0.84
1.3
μC
Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
b. Pulse width 300 μs; duty cycle 2 %.
c. Current limited by the package, (Die Current = 51 A).
服务热线:400-655-8788
2
BUK7635-55A
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
Fig. 1 - Typical Output Characteristics, TC = 25 °C
Fig. 3 - Typical Transfer Characteristics
Fig. 2 - Typical Output Characteristics, TC = 150 °C
Fig. 4 - Normalized On-Resistance vs. Temperature
服务热线:400-655-8788
3
BUK7635-55A
Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage
Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage
www.VBsemi.com
Fig. 7 - Typical Source-Drain Diode Forward Voltage
Fig. 8 - Maximum Safe Operating Area
服务热线:400-655-8788
4
BUK7635-55A
www.VBsemi.com
RD
VDS
VGS
D.U.T.
Rg
- VDD
5V
Pulse width ≤ 1 µs
Duty factor ≤ 0.1 %
Fig. 10a - Switching Time Test Circuit
VDS
90 %
10 %
VGS
td(on)
Fig. 9 - Maximum Drain Current vs. Case Temperature
tr
td(off) tf
Fig. 10b - Switching Time Waveforms
Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case
服务热线:400-655-8788
5
BUK7635-55A
www.VBsemi.com
L
Vary tp to obtain
required IAS
VDS
VDS
tp
VDD
Rg
D.U.T.
I AS
V DD
VDS
5V
0.01 Ω
tp
Fig. 12a - Unclamped Inductive Test Circuit
IAS
Fig. 12b - Unclamped Inductive Waveforms
Fig. 12c - Maximum Avalanche Energy vs. Drain Current
Current regulator
Same type as D.U.T.
50 kΩ
QG
12 V
5V
0.2 µF
0.3 µF
QGS
QGD
D.U.T.
VG
VDS
VGS
3 mA
Charge
IG
ID
Current sampling resistors
Fig. 13a - Basic Gate Charge Waveform
Fig. 13b - Gate Charge Test Circuit
服务热线:400-655-8788
6
BUK7635-55A
www.VBsemi.com
Peak Diode Recovery dV/dt Test Circuit
D.U.T.
Circuit layout considerations
• Low stray inductance
• Ground plane
• Low leakage inductance
current transformer
Rg
dV/dt controlled by Rg
Driver same type as D.U.T.
ISD controlled by duty factor “D”
D.U.T. - device under test
VDD
Driver gate drive
P.W.
Period
D=
P.W.
Period
VGS = 10 Va
D.U.T. lSD waveform
Reverse
recovery
current
Body diode forward
current
dI/dt
D.U.T. VDS waveform
Diode recovery
dV/dt
Re-applied
voltage
Inductor current
VDD
Body diode forward drop
Ripple ≤ 5 %
ISD
Note
a. VGS = 5 V for logic level devices
Fig. 14 - For N-Channel
服务热线:400-655-8788
7
BUK7635-55A
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead
0.420
0.355
0.635
(16.129)
(9.017)
(10.668)
0.145
(3.683)
0.135
(3.429)
0.200
0.050
(5.080)
(1.257)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
8
BUK7635-55A
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
