MMBT5551
MMBT5551
    HXY(华轩阳)
    SOT23-3
    通用三极管 SOT23-3 NPN VCEO=160V Ic=600mA PD=300mW hFE=100~300
MMBT5551 数据手册
HXY MMBT5551 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG FEATURES z z Collector Current: IC=0.6A Power Dissipation of 300mw C E B SOT-23 Package Marking and Ordering Information Product ID Pack Marking MMBT5551 SOT-23 G1 C Qty(PCS) 3000 B E MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol Limit Unit Collector-Base Voltage VCBO 180 V Collector-Emitter Voltage VCEO 160 V Emitter-Base Voltage VEBO 6 V Collector Current IC 600 mA Collector Power Dissipation PC 300 mW Thermal Resistance From Junction To Ambient RΘJA 416 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg Shenzhen HuaXuanYang Electronics CO.,LTD -55~+150 ℃ www.hxymos.com HXY MMBT5551 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Collector-base breakdown voltage V(BR)CBO Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO Collector cut-off current ICBO Emitter cut-off current IEBO DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage * Test conditions Min Typ Max Unit IC=100µA, IE=0 180 V IC=1mA, IB=0 160 V IE=10µA, IC=0 6 V VCB=120V, IE=0 50 nA VEB=4V, IC=0 50 nA hFE(1) * VCE=5V, IC=1mA 80 hFE(2) * VCE=5V, IC=10mA 100 hFE(3) * VCE=5V, IC=50mA 50 300 VCE(sat)1 * IC=10mA, IB=1mA 0.15 V VCE(sat)2 * IC=50mA, IB=5mA 0.2 V VBE(sat)1 * IC=10mA, IB=1mA 1 V VBE(sat)2 * IC=50mA, IB=5mA 1 V 300 MHz 6 pF fT Transition frequency Collector output capacitance Cob VCE=10V,IC=10mA, f=100MHz VCB=10V, IE=0, f=1MHz 100 *Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%. Typical Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY MMBT5551 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY MMBT5551 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG SOT-23 Package Outline Dimensions Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° SOT-23 Suggested Pad Layout Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY MMBT5551 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
MMBT5551 价格&库存
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
