BCC08ZC
BCC08ZC
    BALLUFF(巴鲁夫)
    CBL 5POS MALE TO FMALE 19.69
BCC08ZC 数据手册
1 2 3 4 E BOMR19100201 C F QC QC 7 8 SIGN DESCRIPTION 2016/08/09 Yulong_wang 2017/04/06 Lingpeng Change The Cable OD 2019-10-29 Peng Add 17Pin Add 6Pin & IP69K. L(mm) 42.5 15.3 E 6 DATE 1 2 M12A-XXBFFM-SL8000 Cable Color:Black $ C B TITLE Amphenol LTW M12 A Type Cable Female Conn. TOLERANCE SCALE REV. 1 2 3:2 E SIZE SHEET A4 WC-REV. A.3 1 OF 3 Lingpeng DWG NO M12A-XXBFFM-SL8XXX CUSTOMER Ma Fei 5 6 Jerry 7 2017-04-06 DATE APPROVED BY ALTW 4 2017-04-06 DATE CHECKED BY QC :Inspection item 3 DATE DRAWN BY ITEM NO 2017-04-06 8 WI0814-03-表單01A2 Amphenol LTW. A UNIT:mm PROPERTY OF Amphenol LTW. DISCLOSURE TO THIRD PARTY HAS TO BE AUTHORIZED BY Notes: E C * Important Dimension. QC * Waterproof Rate: IP68, IP69K. * Connector: 3~6P,8P,10P,12P:PU+GF,Black. 17P:Nylon+GF,Black. * Female Pin: Copper Alloy, Gold Plated. * Screw Nut: Zinc Alloy, Nickel Plated. * Outer Mold: PU,Black. * Cable: (A) UL2517,PVC Jacket,Yellow. (B) UL20549,PUR Jacket,Black. (D) UL2517,PVC Jacket,Black. * Rated Voltage: 3 & 4Pin 250V dc. or ac. 5Pin 60V dc. or ac. 6~12Pin,17Pin 30V dc. or ac. * Rated Current: 3~5Pin 4A 6~8Pin 2A 10~12Pin,17Pin 1.5A * Operating Temperature: -25~85 $ C * Cable Length Tolerance: 01M: # 40mm 02M~05M: # 60mm 06M~10M: # 100mm 11M~30M: # 200mm 31M~99M: # 500mm 12.90 (Hex.) D 45.0 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. IT IS CONFIDENTIAL AND A D 5 ECN NO. LEN1680943~960 LEN1681003~011 LEN1750089~96 REV. 1 2 3 4 5 E C F E D E D M 12A - XX B F F M - S L 8 X XX B 8: IP68/69K(防水等級68/69K) L: Straight(180 $ F: Female Pin(母Pin) M: Molding Type(射出成型) TITLE TOLERANCE 1 2 3:2 E 26 6.0 PUR 4.8 5.0 4.4 4.0 3.8 7.0 24 22 26 6.0 PVC Cable Jacket 5.5 5.0 5.1 4.8 4.5 24 22 Cable OD AWG Item No. SIZE SHEET A4 WC-REV. A.3 2 OF C Amphenol LTW M12 A Type Cable Female Conn. SCALE 22 線端) S: Screw(螺紋式) REV. 24 3 Lingpeng DWG NO M12A-XXBFFM-SL8XXX CUSTOMER Ma Fei 5 6 Jerry 7 2017-04-06 DATE APPROVED BY ALTW 4 2017-04-06 DATE CHECKED BY QC :Inspection item 3 DATE DRAWN BY ITEM NO 2017-04-06 8 WI0814-03-表單01A2 Amphenol LTW. A 5.5 5.0 5.1 4.8 4.5 7.0 A: PVC UL2517 Cable,Yellow(PVC黃色外被線材) B: PUR UL20549 Cable,Black(PUR黑色外被線材) D: PVC UL2517 Cable,Black(PVC黑色外被線材) B F: Female Connector(母座) UNIT:mm PVC 8 M12A-17BFFM-SL8DXX M12A-12BFFM-SL8DXX M12A-10BFFM-SL8DXX M12A-08BFFM-SL8DXX M12A-06BFFM-SL8DXX M12A-05BFFM-SL8DXX M12A-04BFFM-SL8DXX M12A-03BFFM-SL8DXX M12A-17BFFM-SL8BXX M12A-12BFFM-SL8BXX M12A-10BFFM-SL8BXX M12A-08BFFM-SL8BXX M12A-06BFFM-SL8BXX M12A-05BFFM-SL8BXX M12A-04BFFM-SL8BXX M12A-03BFFM-SL8BXX M12A-17BFFM-SL8AXX M12A-12BFFM-SL8AXX M12A-10BFFM-SL8AXX M12A-08BFFM-SL8AXX M12A-06BFFM-SL8AXX M12A-05BFFM-SL8AXX M12A-04BFFM-SL8AXX M12A-03BFFM-SL8AXX PROPERTY OF Amphenol LTW. DISCLOSURE TO THIRD PARTY HAS TO BE AUTHORIZED BY C 03: 3Pin 04: 4Pin 05: 5Pin 06: 6Pin 08: 8Pin 10: 10Pin 12: 12Pin E 17: 17Pin B: Cable Without S/R(線端無網尾) 26 6.0 Contacts XX:01~99Meters 01:01Meter 02:02Meters : 99:99Meters 12A: A-Code 7 7.0 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. IT IS CONFIDENTIAL AND A 6 17P 12P 10P 8P 6P 5P 4P 3P 17P 12P 10P 8P 6P 5P 4P 3P 17P 12P 10P 8P 6P 5P 4P 3P 1 2 3 4 5 6 7 8 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. IT IS CONFIDENTIAL AND A F E E D -Black 黑 Blue 藍 -Brown 棕 Pin # Wire 5 4 3 2 1 -Black 黑 Blue 藍 White 白 Brown 棕 Pin # 5 4 3 2 1 Wire Gray 灰 Black 黑 Blue 藍 White 白 Brown 棕 Pin # Wire -Blue 藍 Pink 粉 -Yellow 黃 Green 綠 Brown 棕 White 白 Pin # Wire 8 7 6 5 4 3 2 1 Red 紅 Blue 藍 Pink 粉 Gray 灰 Yellow 黃 Green 綠 Brown 棕 White 白 Pin # Wire --Violet 紫 Black 黑 Red 紅 Blue 藍 Pink 粉 Gray 灰 Yellow 黃 Green 綠 Brown 棕 White 白 Pin # 12 11 10 9 8 7 6 5 4 3 2 1 Wire 17 White/Gray 白/灰 16 Yellow/Brown 黃/棕 15 White/Yellow 白/黃 14 Brown/Green 棕/綠 13 White/Green 白/綠 12 Red/Blue 紅/藍 11 Gray/Pink 灰/粉 10 Violet 紫 9 Red 紅 8 Gray 灰 7 Black 黑 6 Yellow 黃 5 Pink 粉 4 Green 綠 3 White 白 2 Blue 藍 1 Brown 棕 Pin # Wire Red/Blue 紅/藍 Gray/Pink 灰/粉 Violet 紫 Black 黑 Red 紅 Blue 藍 Pink 粉 Gray 灰 Yellow 黃 Green 綠 Brown 棕 White 白 Pin # Wire Pin Out 2 3 12 13 4 11 17 5 14 10 16 15 6 B 1 9 3P 4P 5P 6P 8P 10P 8 7 17P 12P Pin Assignments Front View Amphenol LTW M12 A Type Cable Female Conn. TOLERANCE SCALE REV. 1 2 3:2 E SIZE SHEET A4 WC-REV. A.2 3 OF 3 Lingpeng DWG NO M12A-XXBFFM-SL8XXX CUSTOMER Ma Fei 5 6 Jerry 7 2017-04-06 DATE APPROVED BY ALTW 4 2017-04-06 DATE CHECKED BY QC :Inspection item 3 DATE DRAWN BY ITEM NO 2017-04-06 8 WI0814-03-表單01A2 Amphenol LTW. A UNIT:mm TITLE PROPERTY OF Amphenol LTW. DISCLOSURE TO THIRD PARTY HAS TO BE AUTHORIZED BY C 5 4 3 2 1 8 7 6 5 4 3 2 1 12 11 10 9 8 7 6 5 4 3 2 1
BCC08ZC 价格&库存
很抱歉,暂时无法提供与“BCC08ZC”相匹配的价格&库存,您可以联系我们找货
