ATM3401PSA
P-Channel Enhancement Mode Field Effect Transistor
Drain-Source Voltage: -30V
Drain Current: -4.2A
Features
Trench FET Power MOSFET
Exceptional on-resistance and
maximum DC current capability
RDS(ON) < 65mΩ (VGS = -10V)
RDS(ON) < 75mΩ (VGS =- 4.5V)
RDS(ON) < 90mΩ (VGS = -2.5V)
Marking:R1
Application
DC/DC Converter
Load Switch for Portable Devices
Battery Switch
Absolute maximum ratings (Ta=25℃
Parameter
unless otherwise noted)
Symbol
Value
Unit
VDS
-30
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
ID
-4.2
A
Power Dissipation
PD
1.2
W
RθJA
104
℃/W
Junction Temperature
TJ
150
Storage Temperature
TSTG
-55~ +150
Thermal Resistance from Junction to Ambient
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/5
Dated:10/2022
Rev: 2.2
ATM3401PSA
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Static Characteristics
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =-250µA
-30
V
Zero gate voltage drain current
IDSS
VDS =-24V,VGS = 0V
-1
µA
Gate-body leakage current
IGSS
VGS =±12V, VDS = 0V
±100
nA
VGS(th)
VDS =VGS, ID =-250µA
-0.9
-1.3
V
VGS =-10V, ID =-4.2A
50
65
VGS =-4.5V, ID =-4A
60
75
VGS =-2.5V, ID =-1A
70
90
VDS =-5V, ID =-4.2A
10
Gate threshold voltage
Drain-source on-resistance1)
RDS(on)
Forward transconductance1)
gFS
-0.7
mΩ
S
Dynamic characteristics2)
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
954
VDS =-15V,VGS =0V,f =1MHz
115
pF
77
Switching characteristics2)
Turn-on delay time
td(on)
Turn-on rise time
tr
Turn-off delay time
td(off)
Turn-off fall time
6.3
VGS=-10V,VDS=-15V,
RL=3.6Ω,RGEN=6Ω
3.2
38.2
ns
tf
12
IS
-2
A
Diode pulsed forward current
ISM
-25
A
Diode Forward voltage
VDS
-1.2
V
Source-Drain Diode characteristics
Diode forward current
1)
VGS =0V, IS=-4.2A
Notes:
1) Pulse test: pulse width≤300μs, duty cycle≤2%.
2) Guaranteed by design, not subject to production testing.
2/5
Dated:10/2022
Rev: 2.2
ATM3401PSA
Typical Characteristics Curves
3/5
Dated:10/2022
Rev: 2.2
ATM3401PSA
Package Outline
SOT-23
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
Dimensions In Millimeters
Min.
0.90
0.00
0.90
0.30
0.08
2.80
1.20
2.25
0.95 REF.
1.80
Max.
1.15
0.10
1.05
0.50
0.15
3.00
1.40
2.55
2.00
0.55 REF.
0.30
0.50
4/5
Dated:10/2022
Rev: 2.2
ATM3401PSA
Package Specifications
5/5
Dated:10/2022
Rev: 2.2
很抱歉,暂时无法提供与“ATM3401PSA”相匹配的价格&库存,您可以联系我们找货
