ATM2301PSA
P-Channel Enhancement Mode Field Effect Transistor
Drain-Source Voltage: -20V
Drain Current: -2.5A
Features
Trench FET Power MOSFET
Excellent RDS(on) and Low Gate Charge
RDS(ON) < 110mΩ (VGS = -4.5V)
RDS(ON) < 130mΩ (VGS = -2.5V)
Application
DC/DC Converter
Load Switch for Portable Devices
Battery Switch
Absolute maximum ratings (Ta=25℃
unless otherwise noted)
Parameter
Symbol
Value
Unit
VDS
-20
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
ID
-2.5
A
Pulsed Drain Current
IDM
-10
A
Power Dissipation
PD
0.4
W
RθJA
357
℃/W
Junction Temperature
TJ
150
Storage Temperature
TSTG
-55~ +150
Thermal Resistance from Junction to Ambient
AGERTECH MICROELECTRONICS
Subsidiary of Sino‐Talent International Holdings Ltd.
1/5
Dated:03/2018
Rev: 2.0
ATM2301PSA
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Static Characteristics
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =-250µA
Zero gate voltage drain current
IDSS
VDS =-16V,VGS = 0V
-1
µA
Gate-body leakage current
IGSS
VGS =±12V, VDS = 0V
±100
nA
Gate threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
-0.75
-0.9
V
Drain-source on-resistance1)
RDS(on)
VGS = -4.5V, ID = -4A
90
110
VGS = -2.5V, ID = -2A
110
130
Forward transconductance1)
gFS
VDS =-5V, ID =-2A
-20
-0.4
V
5
mΩ
S
2)
Dynamic characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate resistance
Rg
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
1.3
Turn-on delay time
td(on)
11
Turn-on rise time
tr
Turn-off delay time
td(off)
Turn-off fall time
405
VDS =-10V,VGS =0V,f =1MHz
75
pF
55
f =1MHz
6
3.3
VDS =-10V,VGS =-2.5V,ID=-3A
VDD=-10V,VGEN=-4.5V,ID=-1A
RL=10Ω,RGEN=1Ω
tf
Ω
12
0.7
nC
35
ns
30
10
Source-Drain Diode characteristics
Diode Forward voltage
VDS
VGS =0V, IS=-1.25A
-0.8
-1.3
V
Notes:
1)
Pulse Test: Pulse Width < 300µs, Duty Cycle ≤2%.
2)
Guaranteed by design, not subject to production testing.
2/5
Dated:03/2018
Rev: 2.0
ATM2301PSA
Typical Characteristics Curves
Output Characteristics
Transfer Characteristics
-10
-10
Pulsed
Pulsed
VGS=-2.5V
-8
DRAIN CURRENT ID (A)
-8
VDS=-3V
VGS=-3V,-4V,-5V
Ta=25℃
-6
VGS=-2V
-4
Ta=25℃
-6
Ta=100℃
-4
-2
-2
VGS=-1.5V
-2
-3
DRAIN TO SOURCE VOLTAGE VDS (V)
-4
-1.0
-1.5
-2.0
-2.5
-3.0
GATE TO SOURCE VOLTAGE VGS (V)
RDS(ON) ID
150
-0.5
RDS(ON) - VGS
500
Pulsed
Ta=25℃
Pulsed
400
ON-RESISTANCE RDS(ON) (m)
VGS=-2.5V
100
VGS=-4.5V
50
ID=-2.6A
300
Ta=100℃
200
100
-1.0
-1.5
-2.0
-2.5
Ta=25℃
-2
-3
-4
-5
Threshold Voltage
IS - VSD
-1.2
THRESHOLD VOLTAGE VTH (V)
SOURCE CURRENT IS (A)
Pulsed
1
-1.0
-0.8
ID=-250uA
-0.6
-0.4
0.1
0.0
-0.2
-0.5
-1.0
-1.5
-2.0
25
50
75
100
125
150
JUNCTION TEMPERATURE Tj (℃)
SOURCE TO DRAIN VOLTAGE VSD (V)
3/5
Dated:03/2018
Rev: 2.0
ATM2301PSA
Package Outline
SOT-23
Symbol
Dimensions In Millimeters
Min.
Max.
A
0.90
1.15
A1
0.00
0.10
A2
0.90
1.05
b
0.30
0.50
c
0.08
0.15
D
2.80
3.00
E
1.20
1.40
E1
2.25
2.55
e
e1
0.95 REF.
1.80
2.00
L
L1
0.55 REF.
0.30
0.50
4/5
Dated:03/2018
Rev: 2.0
ATM2301PSA
Package Specifications
5/5
Dated:03/2018
Rev: 2.0
很抱歉,暂时无法提供与“ATM2301PSA”相匹配的价格&库存,您可以联系我们找货
