CFM50S SERIES
50 WATT OPEN FRAME
AC-DC MODULES
Features
Universal Input Range 85~264Vac
High Efficiency up to 89%
2”x 3” Open Frame Compact Size
Class I and Class II
No Load Input Power < 0.15W
Approval IEC/EN/UL 62368-1 Ed 3.0
Meets IEC/EN 60335-1
Approval EN 55032 Class B
and CISPR/FCC Class B
Operating Altitude 5000m
Continuous Short Circuit Protection
Over Voltage Protection
Over Voltage Category OVC II & OVC III
MODEL
OUTPUT
OUTPUT
NUMBER
VOLTAGE
CURRENT
VOLTAGE
RIPPLE&
LINE
LOAD
%EFF.
ACCURACY
NOISE
REGULATION
REGULATION
(Typ.)
NOTE1
NOTE2
NOTE3
NOTE4
NOTE5
CFM50S050
5V
8A
±2%
150 mV
±0.5%
±1%
85%
CFM50S120
12 V
4.17 A
±2%
120 mV
±0.5%
±1%
87%
CFM50S150
15 V
3.33 A
±1%
150 mV
±0.5%
±1%
88%
CFM50S240
24 V
2.08 A
±1%
240 mV
±0.5%
±1%
89%
CFM50S360
36 V
1.39 A
±1%
360 mV
±0.5%
±1%
89%
CFM50S480
48 V
1.04 A
±1%
480 mV
±0.5%
±1%
89%
Note:
1. Voltage accuracy is set at 100% full load.
2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measurement @20MHz BW.
3. Line regulation is measured from 90Vac to 264Vac with 100% full load.
4. Load regulation is measured from 10% to full load.
5. Typical efficiency at 230 Vac.
6. Standard input and output connectors (CN1 and CN2) wafer with TAIWAN KING PIN TERMINAL PVHI series and mate with JST
housing VHR series and JST SVH-41T-P1.1 series crimp terminal and output connectors wire 16AWG.
PART NUMBER
Series
CFM50
Number of Outputs
O
Nominal Output Voltage
XX
050:05V
120:12V
CFM50
150:15V
S:Single
Type
-X (Option)
None:Wafer
P:PCB Mount
CA:Cover
240:24V
E:Encapsulated
360:36V
S:Terminal Block
480:48V
SD:Terminal Block with Din rail
Part Number Example:
CFM50S120: Open Frame, 50W, Single 12Vdc Output
www.cincon.com
1
REVISION: V13
CFM50S
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Input Voltage
Safety approvals only to the AC input
(DC input no safety)
All
Operating Temperature
See Derating Curve
Storage Temperature
Device
Min.
Typ.
Units
85
264
Vac
120
370
Vdc
All
-30
80
All
-30
85
IEC/EN/UL 62368-1 OVC II
Operating Altitude
Max.
5000
IEC/EN 62368-1 OVC III
All
2000
Meets IEC/EN 60335-1 OVC II
m
3000
INPUT CHARACTERISTICS
PARAMETER
Operating Voltage Range
Input Frequency Range
Maximum Input Current
100% Load, Vin=100Vac
Leakage Current
Inrush Current
Vin=240Vac, Cold start at 25℃
Device
Min.
All
100
All
50
Typ.
Max.
Units
240
Vac
60
Hz
All
1.2
A
All
0.1
mA
All
110
A
OUTPUT CHARACTERISTICS
PARAMETER
Output Voltage Set Point
Operating Output Current Range
Vin=Nominal Vin, Io=Io max., Tc=25℃
Vin=115Vac and 230Vac,Tc=25℃
Device
Min.
Typ.
Max.
CFM50S050
4.90
5
5.10
CFM50S120
11.76
12
12.24
CFM50S150
14.85
15
15.15
CFM50S240
23.76
24
24.24
CFM50S360
35.64
36
36.36
CFM50S480
47.52
48
48.48
CFM50S050
8.0
CFM50S120
4.17
CFM50S150
3.33
CFM50S240
2.08
CFM50S360
1.39
CFM50S480
Holdup Time
Units
Vdc
A
1.04
Vin=115Vac
All
ms
Load Regulation
10% Load to full load
All
±1.0
Line Regulation
Vin=High line to low line
8
Output Voltage Regulation
Hiccup mode (Auto recovery)
All
±0.5
CFM50S050
6.3
CFM50S120
15.6
CFM50S150
18.0
CFM50S240
29.1
CFM50S360
43.3
CFM50S480
Over Current Protection
All
All
www.cincon.com
2
Vdc
56.8
110
140
REVISION: V13
CFM50S
PARAMETER
Output Ripple and Noise
Load Capacitance
1. Add a 0.1uF ceramic capacitor and a 10uF
aluminum electrolytic capacitor to output
2. Oscilloscope is 20MHz band width
3. Ambient Temperature=25℃
1. Vin=115Vac and 230Vac
2. Output is max. load
3. Ambient temperature=25℃
Device
Min.
Typ.
Efficiency
Max.
CFM50S050
150
CFM50S120
120
CFM50S150
150
CFM50S240
240
CFM50S360
360
CFM50S480
480
CFM50S050
8000
CFM50S120
4200
CFM50S150
3400
CFM50S240
2087
CFM50S360
1440
CFM50S480
1. Output is rated load
2. Input voltage is 230Vac
Series
Units
mV
uF
600
CFM50S050
85
CFM50S120
87
CFM50S150
88
CFM50S240
89
CFM50S360
89
CFM50S480
89
ISOLATION CHARACTERISTICS
PARAMETER
Device
Min.
Input to Output
1 Minute
All
Isolation Resistance
Input to output
All
100
Device
Min.
Typ.
Max.
4250
Units
Vac
MΩ
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
Pout=max. rated power
All
Typ.
Max.
Units
kHz
65
GENERAL SPECIFICATIONS
PARAMETER
MTBF
Io=100%; Ta=25℃ per MIL-HDBK-217F
All
Humidity
Non-condensing
Meet MIL-STD-810F Table 516.5, Table
516.5-I 10ms, each axis 3 times (±X、±Y、
±Z axis)
Meet MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1 hour (each
axis). Total 3 hrs.
All
Shock
Vibration
Weight
Device
www.cincon.com
4
g
CFM50S
95
CFM50S-P
93
CFM50S-CA
180
CFM50S-E
222
CFM50S-S
233
All
3
93
k
hours
% RH
1200
All
CA (Cover)
SD (Din rail type)
Units
g
P (PCB Mount)
S (Terminal Block)
Max.
75
Open Frame (Wafer)
E (Encapsulated)
Typ.
All
CFM50S-SD
Dimensions
Min.
grams
330
3.000x2.000x1.067 Inches
(76.20x50.80x27.1 mm)
3.000x2.000x1.142 Inches
(76.20x50.80x29mm)
3.598x2.520x1.358 Inches
(91.40x64.00x34.50 mm)
2.170x3.140x1.201Inches
(55.20x79.80x30.50 mm)
2.170x4.200x1.201Inches
(55.20x106.60x30.50 mm)
2.170x4.200x1.784Inches
(55.20x106.60x45.31 mm)
REVISION: V13
CFM50S
Series
Class B
Conducted Disturbance
Class I, Class II, IEC/EN/UL62368-1
EN 55032:2015+AC:2016, 47 CFR FCC Part 15 Subpart B,
EN 61000-3-2:2019, EN 61000-3-3:2013
EN 55032, 47 CFR FCC Part 15
Radiated Disturbance
Class B
Harmonic Current Emissions
EN 61000-3-2:2019
Voltage Fluctuations & Flicker
EN 61000-3-3:2013
EMC Immunity
EN 55035:2017
Electrostatic Discharge (ESD)
Radio-Frequency,
Continuous
Electrical Fast Transient (EFT)
IEC 61000-4-2:2008, Air Discharge: ±8kV, Contact Discharge: ±4kV
Criterion A
IEC 61000-4-3:2020
Criterion A
IEC 61000-4-4:2012, ±0.5kV, ±1kV, ±2Kv
Criterion A
Safety
EMC Emission
Ed 3.0
Class B
Surge
Conducted Disturbances, Induced
by RF Fields
Power Frequency Magnetic Field
IEC61000-4-5:2014, L-N: ±2kV, L-E (Ground): ±4kV
Criterion A
IEC 61000-4-6:2013
Criterion A
IEC 61000-4-8:2009
Criterion A
Voltage Dips
IEC 61000-4-11:2004, Dip: 30% Reduction, Dip >95% Reduction
Criterion A
Voltage Interruptions
IEC 61000-4-11:2004, >95% Reduction
Criterion B
Application Note Link
CFM50S Series App Notes
CHARACTERISTIC CURVE
Power Derating Curve
CFM50SXXX (-P/CA)
CFM50SXXX (-P/CA)
100
100%
80
LOAD (%)
LOAD (%)
75%
50%
25%
40
20LFM(Natural Convection)
0%
-30 -20 -10
60
20LFM (Natural Convection)
10 20 30 40 50 60 70 80
CFM50SXXX-E(S/SD)
100%
105 125 145 165 185 205 225 245 265
Vin Voltage (Vac)
Ambient Temperature(℃)
CFM50SXXX-E(S/SD)
100
80
LOAD (%)
LOAD (%)
75%
50%
25%
CMF50S050-E(S/SD)
60
40
for Others Model
0%
-30 -20 -10 0
10 20 30 40 50 60 70 80 90
www.cincon.com
Vin Voltage (Vac)
4
REVISION: V13
CFM50S
Series
Performance Data
CFM50S120 (Eff Vs Io)
95%
90%
90%
Efficiency (%)
Efficiency (%)
CFM50S050 (Eff Vs Io)
95%
85%
80%
115V
75%
70%
65%
10%
30%
40%
50%
60%
70%
80%
80%
115V
75%
70%
230V
20%
85%
65%
10%
90% 100%
230V
20%
30%
Current Load (%)
90%
90%
85%
80%
75%
115V
70%
40%
50%
60%
70%
80%
75%
115V
65%
10%
90% 100%
230V
20%
30%
90%
Efficiency (%)
Efficiency (%)
90%
85%
80%
75%
115V
70%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
60%
70%
80%
90% 100%
85%
80%
75%
115V
70%
230V
50%
50%
CFM50S480 (Eff Vs Io)
95%
40%
40%
Current Load (%)
CFM50S360 (Eff Vs Io)
30%
90% 100%
80%
95%
20%
80%
85%
Current Load (%)
65%
10%
70%
70%
230V
30%
60%
CFM50S240 (Eff Vs Io)
95%
Efficiency (%)
Efficiency (%)
CFM50S150 (Eff Vs Io)
20%
50%
Current Load (%)
95%
65%
10%
40%
65%
10%
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
5
REVISION: V13
CFM50S
Series
MECHANICAL SPECIFICATION
2
0. 1
4-Φ
FG
3
6[Φ
.20
3
2.000 [50.80]
CN2
1
CN1
1
1.700 [43.18]
0.150 [3.81]
CFM50SXXX
4
AC Input Connector(CN1):TKP PVHI-03N2 or equivalent
Pin Function Mating Housing
Terminal
ACL
1
JST VHR-3N JST SVH-21T-P1.1
2
or equivalent
or equivalent
3
ACN
0.098 [2.50]max.
2.700 [68.58]
DC Output Connector(CN2):TKP PVHI-04 or equivalent
Terminal
+Vout
1
2
+Vout
JST VHR-4N JST SVH-21T-P1.1
or equivalent
or equivalent
3
-Vout
1.067 [27.10]max.
3.000 [76.20]
0.969 [24.60]max.
FG
0.150 [3.81]
4
All Dimensions in Inches[mm]
Tolerance Inches:X.XXX=±0.02
Millimeters:X.XX=±0.5
3.000 [76.20]
2.000 [50.80]
3-0.156 [3.96]
1.700 [43.18]
0.969 [24.60]max.
2.700 [68.58]
CFM50SXXX-P
PIN CONNECTION
Function
1
ACL
2
ACN
CN2
PIN CONNECTION
1.142 [29.00]max.
0.173 [4.40]
CN1
Pin
0.473 [12.01]
FG
0.150 [3.81]
0.173 [4.40]
0.484 [12.30]
2
0.098 [2.50]max.
0.307 [7.80]
1
2
3
4
CN2
CN1
1
0.150 [3.81]
.20]
[Φ3
.126
Φ
4-
FG
0.150 [3.80]
-Vout
Pin
Function
1
2
+Vout
+Vout
3
4
-Vout
-Vout
Φ0.071[Φ1.80]
Φ0.039[1.00]
2.642 [67.10]
www.cincon.com
6
REVISION: V13
CFM50S
Series
3.598 [91.40]
0. 5
3*
M
4
3.299 [83.80]
0.150 [3.80]
CFM50SXXX-CA
Terminal
1
ACL
2
or equivalent
or equivalent
3
ACN
2.520 [64.00]
2.000 [50.80]
CN2
1
CN1
1.382 [35.10]
4-0.157 [4.00]
FG
4
Pin
1
2
3
4
CFM50SXXX-E
1.201 [30.50]
1.358 [34.50]
0.260 [6.60]
FG
Terminal
+Vout
+Vout
or equivalent
or equivalent
-Vout
-Vout
FG
CN2
4
3
2
1
0.237 [6.01]
2
de -M3
pt *0
h .5
2.
5m
m
1
0.307 [7.80]
0.571 [14.50]
CN1
2
0.560 [14.22]
FG
1.700 [43.18]
0.244 [6.20]
PIN CONNECTION
Pin
2.17 [55.2]
3.14 [79.8]
2.642 [67.10]
3-0.156 [3.96]
0.138[3.50]
6-Φ0.059[Φ1.50]
Function
1
ACL
2
ACN
1
+Vout
2
+Vout
3
-Vout
4
-Vout
Wafer
CN1
CN2
Tolerance Inches:x.xx=±0.03,x.xxx=±0.02
Millimeters: x.x=±0.7,x.xx=±0.5
0.221 [5.61]
2.700 [68.58]
www.cincon.com
7
REVISION: V13
CFM50S
Series
4.20 [106.6]
CFM50SXXX-S
3.858 [98.00]
0.169 [4.29]
1
2
2.17 [55.2]
CN2
1
2
3
0.437 [11.10]
CN1
1.299 [33.00]
PE
AC Input Connector(CN1):DINKLE EK350V-03P5 or equivalent
Pin
Function
1
2
PE
ACL
3
ACN
Mating Wire Range
16~30 AWG
1.201 [30.50]
DC Output Connector(CN2):DINKLE EK500V-02P or equivalent
Pin
Function
1
+Vout
-Vout
2
Mating Wire Range
12~16 AWG
Tolerance
Inches: x.xx=±0.03, x .xxx=±0.020
Millimeters: x.x=±0.7, x.xx=±0.50
4.20 [106.6]
CFM50SXXX-SD
PE
CN1
1
2
3
DIN RAIL CLIP
0.504 [12.80]
1.378 [35.00]
1.783 [45.30]
1.280 [32.50]
2.17 [55.2]
CN2
1
2
Pin
Function
1
2
PE
ACL
3
ACN
Mating Wire Range
16~30 AWG
Pin
Function
1
+Vout
2
-Vout
Mating Wire Range
12~16 AWG
Tolerance
sales@cincon.com.tw
www.cincon.com
8
REVISION: V13
很抱歉,暂时无法提供与“CFM50S050-P”相匹配的价格&库存,您可以联系我们找货
