MCL4148
Silicon Epitaxial Planar Switching Diode
Features
• Saving space
• Hermetic sealed parts
• Fits onto SOD 323 / SOT 23 footprints
• Electrical data identical with the device 1N4148
LS-31
Applications
Extreme fast switches
Glass Case MicroMELF
H
C
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Symbol
Value
Unit
100
V
75
V
200
mA
450
mA
0.5
1
4
A
500 1)
mW
Tj
175
Tstg
- 65 to + 175
Peak Reverse Voltage
VRM
Reverse Voltage
VR
E
T
M
E
S
Average Rectified Forward Current
IF(AV)
Repetitive Peak Forward Current
IFRM
Non-repetitive Peak Forward Surge Current
at t = 1 s
at t = 1 ms
at t = 1 μs
Power Dissipation
IFSM
Ptot
Junction Temperature
Storage Temperature Range
1)
Valid provided that electrodes are kept at ambient temperature.
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated: 15/01/2013 Rev: 02
MCL4148
Characteristics at Ta = 25℃
Parameter
Symbol
Min.
Max.
Unit
V(BR)R
100
V
VF
1
V
IR
IR
IR
25
5
50
nA
µA
µA
Reverse Breakdown Voltage
at IR = 100 µA
Forward Voltage
at IF = 50 mA
Leakage Current
at VR = 20 V
at VR = 75 V
at VR = 20 V, Tj = 150℃
Capacitance
at VR = 0, f = 1 MHz
H
C
Ctot
Voltage Rise when Switching ON
tested with 50 mA Forward Pulses
tp = 0.1 s, Rise Time < 30 ns, fp = 5 to 100 KHz
Reverse Recovery Time
at IF = 10 mA to IR = 1 mA, Irr = 0.1 x IR, VR = 6 V,
RL = 100 Ω
4
pF
2.5
V
4
ns
0.45
Vfr
trr
E
T
M
E
S
Rectification Efficiency
at f = 100 MHz, VRF = 2 V
1.
35
M
la ax
ss .
ηV
1.2±0.05
G
Cathode indification
0.19±0.05
R
5
2.
ss
la
G
2±0.1
Glass case MicroMELF
Dimensions in mm
technical drawings
according to DIN
specifications
MCL4148
H
C
E
T
M
E
S
Glass Case Package Outline
Package Outline Dimensions (Units: mm)
Max. 0.45
Max. 0.5
Max. 0.7
Min. 27.5
Max. 1.9
Min. 27.5
Black
Cathode Band
Black
Part No.
Min. 25.4
Max. 1.9
XXX
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
Max. 2.9
Max. 2.8
XXX
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
Max. 3.9
ST
Min. 27.5
Max. 4.2
ST
H
C
Min. 27.5
Glass Case DO-34
Dimensions in mm
XXX
Min. 25.4
Glass Case DO-41
Dimensions in mm
Glass Case DO-35
Dimensions in mm
E
T
M
Glass case MELF
Dimensions in mm
( LL-41 )
Glass case MiniMELF
Dimensions in mm
( LL-34 )
E
S
1.
35
G Ma
la
ss x.
Glass case QuadroMELF
Dimensions in mm
( LS-34 )
1.2±0.05
0.19±0.05
R
2.
5
ss
la
G
2±0.1
Dimensions in mm
(LS-31)
technical drawings
according to DIN
specifications
Dated : 28/04/2011
很抱歉,暂时无法提供与“MCL4148PF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11042
- 500+0.08710
- 2500+0.07414
- 5000+0.06636
- 25000+0.05962
- 50000+0.05599
