RS6332PXM
RS6332PXM
    RUNIC(润石)
    MSOP-8
RS6332PXM 数据手册
RS6331P, RS6332P, RS6334P 1.1MHz, Precision, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ DESCRIPTION HIGH GAIN BANDWIDTH:1.1MHz RAIL-TO-RAIL INPUT AND OUTPUT ±0.5mV Max Vos (RS6331P, RS6332P) ±0.8mV Max Vos (RS6334P) INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V SUPPLY RANGE: +2.1V to +5.5V SPECIFIED UP TO +125°C Micro SIZE PACKAGES: SOT23-5, SOT353(SC70-5) The RS6331P, RS6332P, RS6334P families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (1.1MHz) and slew rate of 0.5V/us. The op-amps are unity gain stable and feature an ultra-low input bias current. The RS6331P, RS6332P and RS6334P has lower offset, which is guaranteed not upper than ±0.5mV (RS6331P, RS6332P) / ±0.8mV (RS6334P) at 25°C with Vs = 5V, VCM = Vs/2. The devices are ideal for sensor interfaces, active filters and portable applications. The RS6331P, RS6332P, RS6334P families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single supplies of 2.1V to 5.5V or dual power supplies of ±1.05V to ±2.75V. APPLICATIONS ⚫ ⚫ ⚫ ⚫ ⚫ SENSORS PHOTODIODE AMPLIFICATION ACTIVE FILTERS TEST EQUIPMENT DRIVING A/D CONVERTERS Device Information (1) PART NUMBER RS6331P RS6332P RS6334P PACKAGE BODY SIZE(NOM) SOT23-5 2.90mm×1.60mm SOIC-8(SOP8) 4.90mm×3.90mm MSOP-8 3.00mm×3.00mm SOT353(SC70-5) 2.10mm×1.25mm SOIC-8(SOP8) 4.90mm×3.90mm MSOP-8 3.00mm×3.00mm TSSOP-8 3.00mm×4.40mm DFN2×2-8L 2.00mm×2.00mm SOIC-14(SOP14) 8.65mm×3.90mm TSSOP-14 5.00mm×4.40mm (1) For all available packages, see the orderable addendum at the end of the data sheet. REV C.2 1 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION C.2 Change Date 2022/05/17 Change Item 1. Update specification layout 2. Update Package Qty on Page 2@RevC.1 3. Added TAPE AND REEL INFORMATION 4. Added Detailed Description 2 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Pin Configuration and Functions (Top View) RS6331P 2 +IN 3 V+ + IN 1 V- 2 -IN - IN 3 5 V+ + - - 4 4 OUT SOT23-5/ SOT353(SC70-5) SOT23-5/ SOT353(SC70-5) NC 1 -IN 2 +IN 3 + V- 5 - 1 + OUT RS6331P RS6331BP V- 4 8 NC 7 V+ 6 OUT 5 NC SOIC-8(SOP8),MSOP-8 Pin Description PIN RS6331P RS6331BP SOT23-5/SOT353 (SC70-5) SOT23-5/SOT353 (SC70-5) -IN 4 3 SOIC8(SOP8)/ MSOP8 2 +IN 3 1 3 NAME RS6331P I/O DESCRIPTION I Negative (inverting) input I Positive (noninverting) input NC - - 1,5,8 - No internal connection (can be left floating) OUT 1 4 6 O Output V- 2 2 4 - Negative (lowest) power supply V+ 5 5 7 - Positive (highest) power supply RS6332P RS6332P OUT A -IN A 8 1 2 V+ OUT A 1 P in 1 In dicator 8 V+ 7 OUTB 7 OUTB -IN A 2 6 -IN B +IN A 3 6 -IN B 5 +IN B V- 4 5 +IN B A +IN A V- 3 + B+ 4 DFN2x2-8L SOIC-8(SOP8),MSOP-8,TSSOP-8 Th er mal P ad on Bottom (can b e l eft fl oatin g) Pin Description PIN NAME I/O DESCRIPTION SOIC-8(SOP8)/MSOP-8/TSSOP-8/DFN2×2-8L -INA 2 I Inverting input, channel A +INA 3 I Noninverting input, channel A -INB 6 I Inverting input, channel B +INB 5 I Noninverting input, channel B OUTA 1 O Output, channel A OUTB 7 O Output, channel B V- 4 - Negative (lowest) power supply V+ 8 - Positive (highest) power supply 3 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Pin Configuration and Functions (Top View) RS6334P 14 OUT D 13 -IN D 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C 9 -IN C 8 OUT C OUT A 1 -IN A 2 +IN A -IN B 6 OUT B 7 A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14 Pin Description PIN NAME I/O DESCRIPTION SOIC-14(SOP14)/TSSOP-14 -INA 2 I Inverting input, channel A +INA 3 I Noninverting input, channel A -INB 6 I Inverting input, channel B +INB 5 I Noninverting input, channel B -INC 9 I Inverting input, channel C +INC 10 I Noninverting input, channel C -IND 13 I Inverting input, channel D +IND 12 I Noninverting input, channel D OUTA 1 O Output, channel A OUTB 7 O Output, channel B OUTC 8 O Output, channel C OUTD 14 O Output, channel D V- 11 - Negative (lowest) power supply V+ 4 - Positive (highest) power supply 4 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN MAX (V-)-0.5 (V+) +0.5 (V-)-0.5 (V+) +0.5 Supply, Vs=(V+) - (V-) 7 Signal input pin (2) Voltage Signal output pin Signal input pin (3) (2) Signal output pin (3) Current Output short-circuit Temperature UNIT V -10 10 mA -140 140 mA (4) Continuous Operating range, TA -40 125 Junction, TJ -40 150 Storage, Tstg -65 150 °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.5V beyond the supply rails should be current-limited to ±140mA or less. (4) Short-circuit to ground, one amplifier per package. ESD Ratings VALUE V(ESD) Electrostatic discharge Human-body model (HBM) ±3000 Machine Model (MM) ±200 UNIT V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) MIN Supply voltage, Vs= (V+) - (V-) Signal-supply Dual-supply NOM MAX UNIT 2.1 5.5 ±1.05 ±2.75 V Thermal Information: RS6331P RS6331P THERMAL METRIC 5PINS 8PINS UNIT SOT23-5 SOT353(SC70-5) SOIC-8 MSOP-8 Junction-to-ambient thermal resistance 273.8 214.7 116 165 °C/W Junction-to-case(top) thermal resistance 126.8 127.1 60 53 °C/W RϴJB Junction-to-board thermal resistance 85.9 60.0 56 87 °C/W ѰJT Junction-to-top characterization parameter 10.9 33.4 12.8 4.9 °C/W ѰJB Junction-to-board characterization parameter 84.9 59.8 98.3 85 °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A N/A N/A °C/W RϴJA RϴJC(top) 5 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Thermal Information: RS6332P RS6332P THERMAL METRIC RϴJA RϴJC(top) RϴJB ѰJT ѰJB RϴJC(bot) 8PINS UNIT SOIC-8 MSOP-8 TSSOP-8 DFN2×2-8L Junction-to-ambient thermal resistance 116 165 192 80.1 °C/W Junction-to-case(top) thermal resistance 60 53 64.3 100 °C/W Junction-to-board thermal resistance 56 87 105.3 45 °C/W Junction-to-top characterization parameter 12.8 4.9 7.6 6.8 °C/W Junction-to-board characterization parameter 98.3 85 105.5 45.2 °C/W Junction-to-case(bottom) thermal resistance N/A N/A N/A 22.7 °C/W Thermal Information: RS6334P RS6334P THERMAL METRIC 14PINS UNIT SOIC-14(SOP14) TSSOP-14 RϴJA Junction-to-ambient thermal resistance 83.8 120.8 °C/W RϴJC(top) Junction-to-case(top) thermal resistance 70.7 34.3 °C/W RϴJB Junction-to-board thermal resistance 59.5 62.8 °C/W ѰJT Junction-to-top characterization parameter 11.6 1 °C/W ѰJB Junction-to-board characterization parameter 37.7 56.5 °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A °C/W 6 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P PACKAGE/ORDERING INFORMATION Orderable Device RS6331PXF Device Marking 6331P Tape and Reel,3000 -40°C ~125°C 6331P Tape and Reel,3000 -40°C ~125°C 6331BP Tape and Reel,3000 1 -40°C ~125°C 6331BP Tape and Reel,3000 Package Type Pin Channel Op Temp(°C) SOT23-5 5 1 -40°C ~125°C RS6331PXC5 SOT353(SC70-5) 5 1 RS6331BPXF SOT23-5 5 1 RS6331BPXC5 SOT353(SC70-5) 5 Package Qty RS6332PXK SOIC-8(SOP8) 8 2 -40°C ~125°C RS6332P Tape and Reel,4000 RS6332PXM MSOP-8 8 2 -40°C ~125°C RS6332P Tape and Reel,4000 RS6332PXQ TSSOP-8 8 2 -40°C ~125°C RS6332P Tape and Reel,4000 RS6334PXP SOIC-14(SOP14) 14 4 -40°C ~125°C RS6334P Tape and Reel,4000 RS6334PXQ TSSOP-14 14 4 -40°C ~125°C RS6334P Tape and Reel,4000 7 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) RS6331P, RS6332P, RS6334P PARAMETER CONDITIONS TJ MIN TYP MAX UNIT 5.5 V 145 uA POWER SUPPLY Vs Operating Voltage Range 25C IQ Quiescent Current/Amplifier 25C PSRR tON Power-Supply Rejection Ratio Vs=2.1V to 5.5V, VCM=(V-)+0.5V Turn-on time Vs= 5V 2.1 85 25C 75 -40C to 125C 65 92 dB 20 us INPUT VOS VOSTC Input Offset Voltage RS6331P 25C -0.5 ±0.2 0.5 RS6332P 25C -0.5 ±0.2 0.5 RS6334P 25C -0.8 ±0.3 0.8 Input Offset Voltage Average Drift -40C to 125C ±2 mV uV/C IB Input Bias Current 25C ±10 ±50 pA Ios Input Offset Current 25C ±10 ±50 pA VCM Common-Mode Voltage Range 5.6 V CMRR Vs= 5.5V 25C -0.1 Vs= 5.5V, VCM =-0.1V to 4V 25C 75 -40C to 125C 68 25C 63 -40C to 125C 57 25C 95 Common-Mode Rejection Ratio Vs= 5.5V, VCM =-0.1V to 5.6V 95 85 dB OUTPUT RL=2KΩ, Vo= 0.15V to 4.85V AOL Open-Loop Voltage Gain RL=10KΩ, Vo= 0.05V to 4.95V Output Swing From Rail IOUT RL=2KΩ -40C to 125C 85 25C 100 -40C to 125C 92 25C RL=10KΩ Output Current Source 110 120 25 8 dB mV 25C 120 mA Slew Rate 25C 0.5 V/us Gain-Bandwidth Product 25C 1.1 MHz Phase Margin 25C 64 ° 1.3 us 4.7 us FREQUENCY RESPONSE SR GBP PM ts Setting Time,0.1% Overload Recovery Time VIN Gain≥VS NOISE en Input Voltage Noise Density f = 1KHz 25C 22 nV/√Hz f = 10KHz 25C 20 nV/√Hz 8 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. Open-Loop Gain(dB) 100 80 110 VS=5V 90 70 60 50 40 30 20 10 0 -20 10 100 1K 10K 100K 1M 120 100 CMRR(dB) Gain Phase Phase Margin (°) 120 80 60 40 -10 10M 20 1 10 1K 10K Figure 2. Common-Mode Rejection Ratio vs Frequency 1000 120 Voltage Noise(nV/√Hz) Figure 1. Open-Loop Gain and Phase vs Frequency 100 VS=5V PSRR(dB) 100 10 80 60 40 20 1 10 100 1K 10K 1 100K 10 Figure 3. Input Voltage Noise Spectral Density vs Frequency 1K 10K Figure 4. Power-Supply Rejection Ratio vs Frequency 100 100 VS=5V Quiescent Current(uA) 95 100 Frequency(KHz) Frequency(Hz) Quiescent Current(uA) 100 Frequency(KHz) Frequency(Hz) 90 85 80 75 70 65 60 VS=2.7V 95 90 85 80 75 70 65 60 -40 -20 0 20 40 60 80 100 120 140 -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) Temperature(℃) Figure 6. Quiescent Current vs Temperature Figure 5. Quiescent Current vs Temperature 9 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. 145 Source Current(mA) 140 Sink Current(mA) 135 130 125 120 115 110 105 100 -40 -20 0 150 145 140 135 130 125 120 115 110 105 100 -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) 20 40 60 80 100 120 140 Temperature(℃) Figure 7. Sink Current vs Temperature Figure 8. Source Current vs Temperature 100K 50mV/div Input Bias Current(pA) 10K 1K 100 10 1 -40 -20 0 20 40 60 80 100 120 140 200ns/div Temperature(℃) Figure 10. SMALL-SIGNAL STEP RESPONSE VIN 1V/div 0V 200mV/div Figure 9. Input Bias Current vs Temperature 1V/div 0V VOUT VS=±2.5V G=-100 1us/div 4us/div Figure 11. LARGE−SIGNAL STEP RESPONSE Figure 12. POSITIVE OVERVOLTAGE RECOVERY 10 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P TYPICAL CHARACTERISTICS VIN 0V 0V VOUT 1V/div 200mV/div At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. VS=±2.5V G=-100 1us/div Figure 13. NEGATIVE OVERVOLTAGE RECOVERY 11 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Detailed Description Overview The RS633XP devices are unity-gain stable, dual and qual-channel op amps with low noise and distortion. The device consists of a low noise input stage with a folded cascade and a rail-to-rail output stage. This topology exhibits superior noise and distortion performance across a wide range of supply voltages that are not delivered by legacy commodity audio operational amplifiers. Phase Reversal Protection The RS633XP family has internal phase-reversal protection. Many op amps exhibit phase reversal when the input is driven beyond the linear common-mode range. This condition is most often encountered in noninverting circuits when the input is driven beyond the specified common-mode voltage range, causing the output to reverse into the opposite rail. The input of the RS633XP prevents phase reversal with excessive common-mode voltage. Instead, the appropriate rail limits the output voltage. This performance is shown in figure 14 3 Voltage (V) 2 1 0 -1 -2 -3 VIN VOUT Time (125us/div) C004 Figure 14. Output Waveform Devoid of Phase Reversal During an Input Overdrive Condition EMI Rejection Ratio (EMIRR) The electromagnetic interference (EMI) rejection ratio, or EMIRR, describes the EMI immunity of operational amplifiers. An adverse effect that is common to many operational amplifiers is a change in the offset voltage as a result of RF signal rectification. An operational amplifier that is more efficient at rejecting this change in offset as a result of EMI has a higher EMIRR and is quantified by a decibel value. Measuring EMIRR can be performed in many ways, but this document provides the EMIRR IN+, which specifically describes the EMIRR performance when the RF signal is applied to the noninverting input pin of the operational amplifier. In general, only the noninverting input is tested for EMIRR for the following three reasons: • Operational amplifier input pins are known to be the most sensitive to EMI, and typically rectify RF signals better than the supply or output pins. • The noninverting and inverting operational amplifier inputs have symmetrical physical layouts and exhibit nearly matching EMIRR performance. • EMIRR is easier to measure on noninverting pins than on other pins because the noninverting input pin can be isolated on a printed-circuit-board (PCB). This isolation allows the RF signal to be applied directly to the noninverting input pin with no complex interactions from other components or connecting PCB traces. 12 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P Detailed Description (continued) The EMIRR IN+ of the RS633XP is plotted versus frequency in Figure 15. If available, any dual and quad operational amplifier device versions have approximately identical EMIRR IN+ performance. The RS633XP unity-gain bandwidth is 1.1MHz. EMIRR performance below this frequency denotes interfering signals that fall within the operational amplifier bandwidth. 100 90 80 EMIRR(dB) 70 60 50 40 30 20 10 10M 100M 1G Frequency(Hz) PRF=-10dBm Figure 15. RS633XP EMIRR vs Frequency EMIRR IN+ Test Configuration Figure 16 shows the circuit configuration for testing the EMIRR IN+. An RF source is connected to the operational amplifier noninverting input pin using a transmission line. The operational amplifier is configured in a unity-gain buffer topology with the output connected to a low-pass filter (LPF) and a digital multimeter (DMM). A large impedance mismatch at the operational amplifier input causes a voltage reflection; however, this effect is characterized and accounted for when determining the EMIRR IN+. The resulting dc offset voltage is sampled and measured by the multimeter. The LPF isolates the multimeter from residual RF signals that can interfere with multimeter accuracy. Ambient temperature: 25° C +VS 50Ω Low-Pass Filter + RF source DC Bias: 0 V Modulation: None (CW) Frequency Sweep: 201 pt. Log -VS Not shown: 0.1 µ F and 10 µ F supply decoupling Sample / Averaging Digital Multimeter Figure 16. EMIRR IN+ Test Configuration Schematic 13 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P APPLICATION NOTES The RS6331P, RS6332P, RS6334P are high precision, rail-to-rail operational amplifiers that can be run from a single-supply voltage 2.1V to 5.5V (±1.05V to ±2.75V). Supply voltages higher than 7V (absolute maximum) can permanently damage the amplifier. Rail-to-rail input and output swing significantly increases dynamic range, especially in low-supply applications. Good layout practice mandates use of a 0.1uF capacitor place closely across the supply pins. Typical Applications 25-kHz Low-pass Filter R4 2.94 kΩ Input R1 590Ω C5 1 nF R3 499Ω Output + RS633XP C2 39 nF Figure 17. 25-kHz Low-Pass Filter Design Requirements Low-pass filters are commonly employed in signal processing applications to reduce noise and prevent aliasing. The RS633XP devices are ideally suited to construct high-speed, high-precision active filters. Figure 17 shows a second-order, low-pass filter commonly encountered in signal processing applications. Use the following parameters for this design example: • Gain = 5 V/V (inverting gain) • Low-pass cutoff frequency = 25 kHz • Second-order Chebyshev filter response with 3-dB gain peaking in the passband Detailed Design Procedure The infinite-gain multiple-feedback circuit for a low-pass network function is shown in Figure 17. Use Equation 1 to calculate the voltage transfer function. (1) This circuit produces a signal inversion. For this circuit, the gain at dc and the low-pass cutoff frequency are calculated by Equation 2: ( ) (2) Application Curve Figure 18. Low pass filter transfer function 14 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P LAYOUT GUIDELINS Attention to good layout practices is always recommended. Keep traces short. When possible, use a PCB ground plane with surface-mount components placed as close to the device pins as possible. Place a 0.1uF capacitor closely across the supply pins. These guidelines should be applied throughout the analog circuit to improve performance and provide benefits such as reducing the EMI susceptibility. Layout Example + VIN A + VIN B VOUT A RG VOUT B RG RF RF Figure 19. Schematic Representation Place compon ents close to device and to each other to reduce parasitic e rro rs. OUT A VS+ OUT A V+ -IN A OUT B +IN A -IN B Use low-ESR, ceramic bypass capacitor. Pla ce as close to the d evice as possible. GND RF OUT B GND RG VIN A RF GND RG V- Use low-ESR, ceramic bypass capacitor. Pla ce as close to the d evice as possible. +IN B Ground (GND) plane on another layer GND VS- VIN B Keep input traces short and run the input tra ces as far aw ay from the supply lines as possible. Figure 20. Layout Example 15 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 16 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P SOT353(SC70-5) D 1.30 b 1.9 E E1 0.75 Pin1 Index Area 0.65 0.4 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters L1 Dimensions In Inches Symbol Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 c 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650(BSC) 0.026(BSC) e1 1.300(BSC) 0.051(BSC) L 0.260 L1 θ 0.460 0.010 0.525 0° 0.018 0.021 8° 17 / 24 0° 8° www.run-ic.com RS6331P, RS6332P, RS6334P MSOP-8 b e E E1 4.8 1.02 D 0.65 0.41 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Dimensions In Millimeters θ Dimensions In Inches Symbol Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.250 0.380 0.010 0.015 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.650(BSC) 0.026(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 18 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P TSSOP-14 e E1 b 5.6 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 H C A A1 θ L Dimensions In Millimeters Dimensions In Inches Symbol Min Max A Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 19 / 24 1° 7° www.run-ic.com RS6331P, RS6332P, RS6334P SOIC-8(SOP8) b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Dimensions In Millimeters θ Dimensions In Inches Symbol Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 20 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P SOIC-14(SOP14) e E b 5.2 E1 1.27 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A θ A1 L Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 21 / 24 www.run-ic.com RS6331P, RS6332P, RS6334P TSSOP-8 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 H C A A1 θ L Dimensions In Millimeters Dimensions In Inches Symbol Min Max A Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 2.900 3.100 0.114 0.122 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 22 / 24 1° 7° www.run-ic.com RS6331P, RS6332P, RS6334P DFN2x2-8L E e D E1 L b D1 TOP VIEW BOTTOM VIEW 0.50 0.70 A1 1.95 A2 A 0.65 0.24 1.20 SIDE VIEW RECOMMENDED LAND PATTERN (Unit: mm) Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 0.700 0.800 0.028 0.031 A1 0.000 0.050 0.000 0.002 A2 0.203(TYP) 0.008(TYP) b 0.180 0.300 0.007 0.012 D 1.900 2.100 0.075 0.083 D1 1.100 1.300 0.043 0.051 E 1.900 2.100 0.075 0.083 E1 0.600 0.800 0.024 0.031 e L 0.500(TYP) 0.250 0.020(TYP) 0.450 23 / 24 0.010 0.018 www.run-ic.com RS6331P, RS6332P, RS6334P TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSION Reel Diameter Reel Width(W1) DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL SOT23-5 Reel Diameter 7’’ Reel Width (mm) 9.5 A0 (mm) 3.20 B0 (mm) 3.20 K0 (mm) 1.40 P0 (mm) 4.0 P1 (mm) 4.0 P2 (mm) 2.0 W (mm) 8.0 Pin1 Quadrant Q3 SOT353(SC70-5) 7’’ 9.5 2.25 2.55 1.20 4.0 4.0 2.0 8.0 Q3 MSOP-8 13’’ 12.4 5.20 3.30 1.50 4.0 8.0 2.0 12.0 Q1 SOIC-8(SOP8) 13’’ 12.4 6.40 5.40 2.10 4.0 8.0 2.0 12.0 Q1 DFN2X2-8L 7’’ 9.5 2.30 2.30 1.10 4.0 4.0 2.0 8.0 Q2 TSSOP-14 13’’ 12.4 6.95 5.60 1.20 4.0 8.0 2.0 14.0 Q1 SOIC-14(SOP14) 13’’ 16.4 6.60 9.30 2.10 4.0 8.0 2.0 16.0 Q1 Package Type 24 / 24 www.run-ic.com
RS6332PXM 价格&库存
很抱歉,暂时无法提供与“RS6332PXM”相匹配的价格&库存,您可以联系我们找货
