3019
    ADAFRUIT
    THIRD HAND PANA HAND WORKSTATION
3019 数据手册
Third Hand Pana Hand Workstation Add-On for Panavise PRODUCT ID: 3019  Description We've really gotta HAND it to them, the Third Hand Pana Workstation brings the benefits of the Super Fancy Third Hand Kit to the PanaVise line of work holding vises. This is the most luxurious desktop workholding solution we've laid our hands on. Note: Panavise Jr. and Panavise Multi-Purpose Work Center + base are not included! The gold-color anodized base of the Pana Workstation has integrated mounting holes to be seamlessly attached between any PanaVise work holding vise and a tray base mount to offer the ultimate work station. The Workstation from Hobby Creek comes fully assembled so you can focus your efforts on the project and not your tools! o o o o o 4x - Flexible arms each with a large swiveling alligator clip wrapped in ultra high heat resistant silicon 1x - Precision cut and beautifully gold anodized base 4x - Silicon clip tips for the ultimate heat resistance 4x - Removable feet for a stable standalone operation Integrates perfectly with Panavise vises and base mounts Note: Panavise Jr. and Panavise Multi-Purpose Work Center + base are not included! Technically, you don't even need either to use this work-holder but its waaaay better if you pair them up.  Technical Details o o o o o Base Diameter: 128.9mm / 5.07" Base Thickness: 12.3mm / 0.48" Arm Diameter: 15.9mm / 0.63" Arm Length (including clip): ~340mm / ~13.4" Weight: 407.9g This product is compatible with all PanaVise Workholding vises with a 3 hole 4.3125" Bolt Circle. Compatible models include: 201(Jr.), 300, 301, 305, 324, 350, 391, 396. This product also integrates perfectly with the PanVise Tray base mount, model 312.                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/2740 6‐8‐17
很抱歉,暂时无法提供与“3019”相匹配的价格&库存,您可以联系我们找货
