Micro:Maqueen Robot Car(V2.0)
SKU: ROB0148
I am Maqueen
Hello, my name is Maqueen, is a graphical programming robot for STEM education, which inherits
playability and simple operation of micro:bit. The Mini-body, interesting features and plug-and-play
allow children to quickly learn graphic programming in entertaining, nurturing children's interest in
science and logical thinking.
What are the features of Maqueen?
Support for Makecode, will support Scratch and python later.
Small size, flexible movement.
All-metal miniature gear motor, good quality, strong driving force.
Line patrol, ambient light, LED lights, ultrasonic interface, buzzer, I2C interface, mechanical
expansion screw hole, etc. ... full-featured, highly expandable.
Exclusive customized POM bearing wheel, flexible and reliable, strong obstacle crossing ability.
Easy to install, easy to use.
Function Diagram
Specification
Supply Voltage: 3.5V~5V DC ( Three AAA batteries or 3.7V lithium battery )
Infrared Grayscale Sensor(High-low level) x 2
Buzzer x 1
Infrared Receiver (NEC decoder) x 1
LED Lights (High-low level control) x 2
RGB Ambient Light (16 million colors) x 4
SR04, SR04P Ultrasonic Interface
IIC Interface (3.3V) x 1
N20 All-metal Gear Motor x 2
Motor Reduction Ratio: 1:150
Maximum Rotate Speed: 133 rpm
Motor Drive Mode: PWM motor drive
Bracket and Protective Cover Extension M3 Screw Hole x 6
Programming Method: Makecode graphical programming, Mind + graphical programming (based on
Scratch 3.0)
Dimension: 81mm x 85 mm x 44mm/3.19 x 3.35 x 1.73in
Weight: 75.55g
Product Configuration List
Car Body x 1
Wheel x 2
Three AAA batteries Box x 1
Double Sided Adhesive Tape x 1
Product Installation
Import the Makecode Graphical Library
1. Click the link: makecode.microbit.org, enter the makecode graphical online programming platform.
(Note: Loading will be slow in the first time, please wait patiently)
2. Import the library: Copy they Maqueen library's address: https://github.com/jhlucky/maqueen
3. Import the library by following the steps.
Makecode Programming Example
Motor Control
Learning Target: Mastering the basic method of motor control.
Effect: The car forward 1 second, right turn 1 second, left turn 1 second, back 1 second, back and
right turn 1 second.
Makecode Program Link: https://makecode.microbit.org/_2Cc9gM5P5aDs
Screenshot of Makecode Graphical Program:
RGB Breathing Ambient Light
Learning Target: Learn the basic way of using ambient light.
Effect: The RGB ambient light at the bottom of the Maqueen shows a variety of colors and presents
a gradient effect.
Makecode Program Link: https://makecode.microbit.org/_WkgPLpAotP3f
LED Light Flash
Learning Target: Learn the using way of LED light and buzzer.
Effect: The left and right LED lights flash alternately, and the buzzer emits two different tone
frequencies at intervals of 500 milliseconds.
Makecode Program Link:https://makecode.microbit.org/_6gKRm1RVsDxY
Read Ultrasonic Distance
Learning Target: Learn to read the distance of ultrasound, so that later can be flexible use of these
data.
Effect: The ultrasonic detects the obstruction in front and the distance will be displayed on the dotmatrix screen in centimeters.
Makecode Program Link: https://makecode.microbit.org/_4gi4Dj7yTWgK
Read Infrared Key Assignments
Learning Target: Learn to read the key assignments of infrared, so that later can be flexible use of
these data.
Effect: Put the the IR receiver toward the IR remote control, when you press any key on the IR
remote control. The key assignments that corresponds to the pressed key will displayed on the dot
matrix, in decimal notation the last two digits of the key assignments are displayed.
Makecode Program Link: https://makecode.microbit.org/_361V7bbp0UAg
IR Remote Control and Its Key Assignments
The key assignments in the following table are in hexadecimal. In this product, we read the last two
digits of the key assignments and automatically convert them to decimal data.
Key
Key Assignments
Power
0xff00
VOL+
0xfe01
FUNC/STOP
0xfd02
Left
0xfd04
Pause
0xfa05
Right
0xf906
Down
0xf708
VOL-
0xf609
Up
0xf50a
0xf30c
EQ
0xf20d
ST/REPT
0xf10e
1
0xef10
2
0xee11
3
0xfa05
4
0xeb14
5
0xea15
6
0xe916
7
0xe718
8
0xe619
9
0xe51a
IR Remote Control
Learning Target:Learn to use the IR remote control to command the car.
Effect: Control car forward, left, right, back with 4 keys of IR remote control 2, 4, 6, 8.
Makecode Program Link: https://makecode.microbit.org/_MfDXhX6MM35X
Line-tracking
Effect: The car is running along the black line.
Makecode Program Link: https://makecode.microbit.org/_1VzX7LLAC3im
Ultrasonic Obstacle-avoiding
Effect: Ultrasonic detects the distance between the car and the obstacle in front of it. If the distance
is less than 35cm, the car will randomly choose to turn left or right to avoid obstacles.
Fittings: SR04 Ultrasonic Module x 1 or SR04-P Ultrasonic Module x 1
Makecode Program Link: https://makecode.microbit.org/_Fa4Ef3DwyXW7
Light-operated Sprite
Effect: The car does not move in the darker light, and as the flashlight illuminates the LED, the
vehicle's forward speed begins to increase as the intensity of the light increases.
Makecode Program Link: https://makecode.microbit.org/_fi6DWjCKeM9v
Wireless Remote Control
Learning Target: Learn the way of using micro:bit wireless.
Effect: Use gamepad to control the car's movement.
micro:bit Micro:bit Gamepad
Makecode Program Link of the Car:https://makecode.microbit.org/_ftMMb8WkwDV7
Makecode Program Link of the Gamepad: https://makecode.microbit.org/_gwK0A3JwEW0V
Screenshot of Car's Makecode Graphical Program:
Screenshot of Gamepad's Makecode Graphical Program:
https://www.dfrobot.com/wiki/index.php/Micro:Maqueen_Robot_Car(V2.0)_SKU:_ROB0148 9‐11‐18
很抱歉,暂时无法提供与“ROB0148”相匹配的价格&库存,您可以联系我们找货
