VLM60E-24-T
VLM60E-24-T
    ERP
    2.5A 24V 恒定电压 LED 驱动器 AC DC 转换器 拓扑 1 输出
VLM60E-24-T 数据手册
    96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers Nominal Input Voltage Max. Output Power Nominal Output Voltage Max. Output Current Efficiency 120 & 277 Vac, 220 to 240 Vac 96 W 12, 24, 48 Vdc 8, 4, 2 A up to 92% typical Max. Case Temperature 90°C (measured at the hot spot) THD Power Factor < 20% > 0.9 Models with Flying Leads, Aluminum Case (VLM100W Models): L 137 x W 26.0 x H 19.8 mm (L 5.39 x W 1.02 x H 0.77 in) VLM100 series VLM100E dimensions on page 14 LEDs + LEDs + Typical Application Diagram Models with “-S” Suffix, Bottom Leads with Studs, Aluminum Case: L 137 x W 26.0 x H 23.85 mm (L 5.39 x W 1.02 x H 0.94 in) Neutral: White (Blue) Line: Black (Brown)     © ERP Power, LLC 1 LEDs -: Blue (Black) Wiring Diagram TYPICAL APPLICATIONS     FEATURES Very high power density of 24 W/in3 Class 2 power supply Class II power supply per IEC 61347 IP20-rated case with silicone-based potting 90℃ maximum case hot spot temperature Complies with ENERGY STAR®, DLC (DesignLight Consortium®) and CA Title 24 technical requirements Lifetime: 50,000 hours min at 70℃ case temperature UL Class P Worldwide safety approvals Additional safety approvals when using the optional strain reliefs for models with “-T” suffix LEDs +: Red: ( ): Wire Color for models with “-T” suffix (220-240 Vac) Models with “-T” Suffix (Terminal Blocks), Aluminum Case: L 193.2 x W 26.2 x H 19.85 mm (L 7.60 x W 1.03 x H 0.78 in)       VLM100 Series CA Title 24 Strip lights Pendants Linears Cove Lights 5 VLM100 Series Data Sheet Rev. April 2020     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 1 - ORDERING INFORMATION ERP Part Number Nominal Input Voltage (Vac) Open Loop Pout Vout Iout Iout Voltage Max Nom Min Max (No Load Vout (W) (Vdc) (A) (A) Max) (Vdc) VLM100W-12 (1) 120 & 277 96 VLM100W-24 120 & 277 96 VLM100W-48 120 & 277 96 VLM100W-12-S(1) 120 & 277 96 VLM100W-24-S 120 & 277 96 VLM100W-48-S 120 & 277 96 Safety, EMC Compliance Case 120/277 VAC NOMINAL VOLTAGE Aluminum case with flying 12 0.2 8 12.84 leads Aluminum case with flying 24 0.2 4 25.68 leads Aluminum case with flying 48 0.1 2 51.36 leads 12 0.2 8 12.84 Aluminum case with bottom leads and studs 24 0.2 4 25.68 Aluminum case with bottom leads and studs 48 0.1 2 51.36 Aluminum case with bottom leads and studs 220 TO 240 VAC NOMINAL VOLTAGE Aluminum case with flying 12 0.2 8 12.84 leads UL, cUL, FCC UL, cUL, FCC UL, cUL, FCC UL, cUL, FCC UL, cUL, FCC UL, cUL, FCC VLM100E-12 220 to 240 96 VLM100E-24 220 to 240 96 24 0.2 4 25.68 VLM100E-48 220 to 240 96 48 0.1 2 51.36 VLM100E-12-T(2) 220 to 240 96 12 0.2 8 12.84 Aluminum case with terminal blocks CB, ENEC, CE VLM100E-24-T(2) 220 to 240 96 24 0.2 4 25.68 Aluminum case with terminal blocks CB, ENEC, CE VLM100E-48-T(2) 220 to 240 96 48 0.1 2 51.36 Aluminum case with terminal blocks CB, ENEC, CE Aluminum case with flying leads Aluminum case with flying leads CB, ENEC, CE CB, ENEC, CE CB, ENEC, CE Notes: 1. VLM100W-12 is not Class 2 because the over-current protection of this model exceeds the 5A UL Class 2 limit. 2. Strain reliefs for “-T” models are not included and can be ordered separately using part number SR2. Order quantity for SR2 is per strain relief, and 2 strain reliefs are needed for each driver. SaveEnergy@erp-power.com 2 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 2 - INPUT SPECIFICATION (@25C ambient temperature) Typical Units Minimum Input Voltage Range (Vin) - VLM100W models Vac - VLM100E models Input Frequency Range - VLM100W models Hz - VLM100W models Input Current (Iin) 90 120 & 277 305 198 230 264 47 60 63 47 50 53 1.05 A @ 120 Vac 0.58 A @ 230 vac 0.48 A @ 277 Vac 0.9 > 0.9 A Power Factor (PF) Inrush Current A Leakage Current μA Total Harmonics Distortion (THD) Efficiency Notes The rated output voltage for each model is achieved at Vin≥105 Vac & at Vin≥249 Vac for VLM100W models, and at Vin≥209 Vac for VLM100E models. At maximum load, as specified in section 1. At nominal input voltage From 100% to 60% of rated power At any point on the sine wave and 25°C Meets NEMA-410 requirements 400 μA @ 120 Vac 800 μA @ 230 Vac Measured per IEC60950-1 920 μA @ 277 Vac Complies with IEC61000-3-2 for Class C equipment At nominal input voltage 20% From 100% to 60% of rated power Complies with DLC (Design Light Consortium) technical requirements Measured with nominal input voltage up to 92% Input Harmonics Isolation Maximum % The AC input to the main DC output is isolated 3 - MAIN OUTPUT SPECIFICATION (@25C ambient temperature) Output Voltage (Vout) Units MinimumTypical 12, 24, Vdc 48 Maximum See ordering information for details 12 Vdc: 8 A 24 Vdc: 4 A 48 Vdc: 2 A Output Current (Iout) A Output Voltage Regulation % -5 Output Voltage Overshoot % - 5 - Notes 10 The rated output voltage for each model is achieved at Vin≥105 Vac & at Vin≥249 Vac for VLM100W models, and at Vin≥209 Vac for VLM100E models. At nominal AC line voltage Includes load and current set point variations. The driver does not operate outside of the regulation requirements for more than 500 ms during power on with maximum load. Ripple Voltage ≤ 5% of rated output voltage for each Measured at maximum load and nominal input voltage. Calculated in accordance with the IES Lighting Handbook, 9th edition. model Start-up Time ms SaveEnergy@erp-power.com 500 Measured from application of AC line voltage to 100% light output. Complies with ENERGY STAR® luminaire specification. 3 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 4 - ENVIRONMENTAL CONDITIONS Units Operating Ambient Temperature (Ta) °C Maximum Case Temperature (Tc) °C Storage Temperature Humidity Cooling Acoustic Noise Mechanical Shock Protection Vibration Protection MTBF Lifetime °C % Minimum Typical Maximum -20 -40 5 Convection cooled Notes 50 50°C is the non-derated temperature (Refer to section 7 "Output power de-rating at higher temperatures". +90 Case temperature measured at the hot spot tc (see label in page 13) +85 95 Non-condensing dBA 22 Measured at a distance of 1 foot (30 cm) per EN60068-2-27 per EN60068-2-6 & EN60068-2-64 > 200,000 hours when operated at nominal input and output conditions, and at Tc ≤ 70°C 50,000 hours at Tc ≤ 70°C maximum case hot spot temperature (see hot spot tc on label in page 13) 5 - EMC COMPLIANCE AND SAFETY APPROVALS EMC Compliance Conducted and VLM100W models: Compliant with FCC CFR Title 47 Part 15 Class B at 120 Vac & Class A at 277 Vac VLM100E models: Compliant with EN55015 (CISPR 15) at 220, 230, and 240 Vac Radiated EMI Harmonic Current Emissions IEC61000-3-2 For Class C equipment Voltage Fluctuations & Flicker IEC61000-3-3 ESD (Electrostatic IEC61000-4-2 6 kV contact discharge, 8 kV air discharge, level 3 Discharge) RF Electromagnetic Field IEC61000-4-3 3 V/m, 80 - 1000 MHz, 80% modulated at a distance of 3 meters Susceptibility Electrical Fast Transient IEC61000-4-4 ± 2 kV on AC power port for 1 minute, ±1 kV on signal/control lines Immunity ± 2 kV line to line (differential mode) /± 2 kV line to common mode ground Compliance IEC61000-4-5 (tested to secondary ground) on AC power port, ±0.5 kV for outdoor cables Surge ANSI/IEEE c62.41.1-2002 & c62.41.2-2002 category A, 2.5 kV ring wave Conducted RF Disturbances Voltage Dips UL cUL CE CB ENEC IEC61000-4-6 3V, 0.15-80 MHz, 80% modulated IEC61000-4-11 >95% dip, 0.5 period; 30% dip, 25 periods; 95% reduction, 250 periods Safety Agency Approvals VLM100W models: UL8750 listed Class 2 VLM100W models: CAN/CSA C22.2 No. 250.13-14 LED equipment for lighting applications VLM100E models: IEC61347-2-13 electronic control gear for LED Modules & EN55015 (EMC compliance) VLM100E models VLM100E models Hi Pot (High Potential) or Dielectric voltage-withstand - VLM100W models - VLM100E models SaveEnergy@erp-power.com Typical Safety Maximum Units Minimum Vdc 2500 Insulation between the input (AC line and Neutral) and the output Tested at the RMS voltage equivalent of 1768 Vac 4242 Tested at the RMS voltage equivalent of 3000 Vac Meets class II reinforced/double insulation 4 Notes www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 6 - PROTECTION FEATURES Under-Voltage (Brownout) The VLM100 series provides protection circuitry such that an application of an input voltage below the minimum stated in section 1 (Input Specification) shall not cause damage to the driver. Short Circuit and Over Current Protection The VLM100 series is protected against short-circuit such that a short from any output to return shall not result in a fire hazard or shock hazard. The driver shall hiccup as a result of a short circuit or over current fault. Removal of the fault will return the driver to within normal operation. The driver shall recover, with no damage, from a short across the output for an indefinite period of time. Internal Over temperature Protection The VLM100 is equipped with an internal temperature sensor on the primary power train. Failure to stay within the convection power rating will cause the driver to shut down. The main output current will be resumed when the temperature of the built-in temperature sensor cools adequately. Output Open Load A no load condition will not damage the VLM100 or cause a hazardous condition. The driver will remain stable and operate normally after application of a load. When the LED load is removed, the output voltage of the VLM100 series is limited to 7% about the output voltage of each model. Over Power Protection The VLM100 will shut down and auto recover in the event of an over-power condition. This condition will cause no damage to the power supply. Input Over Current Protection The VLM100 series incorporates a primary AC line fuse for input over current protection. 7 - OUTPUT POWER DE-RATING AT ELEVATED TEMPERATURES The VLM100 series can be operated with cooling air temperatures above 50°C by linearly de-rating the total maximum output power (or current) by 2.5%/°C from 50°C to 70°C (see figure 1). 110 % 100 % Percent of Output Power 90% 80% 70% 60% Figure 1 50% 40% 30% 20% 10% 0% 0 SaveEnergy@erp-power.com 10 20 30 40 50 Ambient Temperature (°C) 5 60 70 80 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 8 - PREDICTED LIFETIME VERSUS CASE AND AMBIENT TEMPERATURE VLM100W-24 At 120 Vac and with baseplate dimensions of 195 x 60 x 3 mm (7.68 x 2.36 x 0.12 in.) VLM100W-48 At 120 Vac and with baseplate dimensions of 195 x 60 x 3 mm (7.68 x 2.36 x 0.12 in.)                  Tambient (°C) 35 Tcase (°C) 60    40 65       Predicted Lifetime (k Hours) Predicted Lifetime (k Hours) Lifetime is defined by the measurement of the temperatures of all the electrolytic capacitors whose failure would affect light output under the nominal LED load and worst case AC line voltage. The graphs in figures 2 and 3 are determined by the electrolytic capacitor with the shortest lifetime, among all electrolytic capacitors. It represents a worst case scenario in which the LED driver is powered 24 hours/day, 7 days/week. The lifetime of an electrolytic capacitor is measured when any of the following changes in performance are observed: 1) Capacitance changes more than 20% of initial value 2) Dissipation Factor (tan δ): 150% or less of initial specified value 3) Equivalent Series Resistance (ESR): 150% or less of 4) Leakage current: less of initial specified value initial specified value 45 70 50 75 60 80 65 85  Figure 2         Tambient (°C) 25 Tcase (°C) 60 70 90     30 65 35 70 40 75 45 80 50 85 55 90 Figure 3 Notes:  The ambient temperature Tambient and the differential between Tambient and Tcase mentioned in the above graphs are relevant only as long as both the driver and the light fixture are exposed to the same ambient room temperature. If the LED driver is housed in an enclosure or covered by insulation material, then the ambient room temperature is no longer valid. In this situation, please refer only to the case temperature Tcase.  It should be noted the graph “Lifetime vs. Ambient Temperature” may have an error induced in the final application if the mounting has restricted convection flow around the case. For applications where this is evident, the actual case temperature measured at the Tc point in the application should be used for reliability calculations. SaveEnergy@erp-power.com 6 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 9 – EFFICIENCY VERSUS LOAD VLM100W-12 277 Vac 93.00% 93.00% 92.00% 92.00% Efficiency Efficiency 120 Vac VLM100W-24 91.00% 90.00% 120 Vac 277 Vac 91.00% 90.00% 89.00% 89.00% 88.00% 88.00% 87.00% 87.00% 4 4.8 5.6 6.4 7.2 2.0 8 2.4 2.8 3.2 Load Current (A) Load Current (A) Figure 4 Figure 5 3.6 4.0 VLM100W-48 120 Vac 277 Vac 93.00% 92.00% Efficiency 91.00% 90.00% 89.00% 88.00% 87.00% 1 1.2 1.4 1.6 1.8 2 Load Current (A) Figure 6 SaveEnergy@erp-power.com 7 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 9 – EFFICIENCY VERSUS LOAD (CONTINUED) VLM100E-12-T 220VAC 230VAC 240VAC 93.00% 92.00% 92.00% 91.00% 91.00% Efficiency Efficiency 93.00% VLM100E-24-T 90.00% 89.00% 220VAC 230VAC 240VAC 90.00% 89.00% 88.00% 88.00% 87.00% 4.0 4.8 5.6 6.4 7.2 87.00% 8.0 2.0 Load Current (A) 2.4 2.8 3.2 3.6 Load Current (A) Figure 7 4.0 Figure 8 VLM100E-48-T 220VAC 93.00% 230VAC 240VAC Efficiency 92.00% 91.00% 90.00% 89.00% 88.00% 87.00% 1.0 1.2 1.4 Load Current (A) 1.6 1.8 2.0 Figure 9 SaveEnergy@erp-power.com 8 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 10 – POWER FACTOR VERSUS LOAD VLM100W-12 120 Vac VLM100W-24 120 Vac 277 Vac Power Factor Power Factor 277 Vac 1.00 1.00 0.98 0.96 0.94 0.92 0.98 0.96 0.94 0.92 0.90 0.90 4 4.8 5.6 6.4 7.2 8 2.0 2.4 2.8 3.2 Load Current (A) Load Current (A) Figure 10 Figure 11 3.6 4.0 VLM100W-48 120 Vac 277 Vac 1.00 Power Factor 0.98 0.96 0.94 0.92 0.90 1 1.2 1.4 1.6 1.8 2 Load Current (A) Figure 12 SaveEnergy@erp-power.com 9 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 10 – POWER FACTOR VERSUS LOAD (CONTINUED) VLM100E-24-T VLM100E-12-T 230VAC 240VAC 1.00 1.00 0.98 0.98 Power Factor Power Factor 220VAC 0.96 0.94 0.92 220VAC 230VAC 240VAC 2 2.8 3.6 0.96 0.94 0.92 0.90 4 4.8 5.6 6.4 7.2 0.90 8 Load Current (A) 2.4 3.2 4 Load Current (A) Figure 13 Figure 14 VLM100E-48-T 220VAC 230VAC 240VAC 1.00 Power Factor 0.98 0.96 0.94 0.92 0.90 1 1.2 1.4 1.6 1.8 2 Load Current (A) Figure 15 SaveEnergy@erp-power.com 10 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 11 – THD VERSUS LOAD VLM100W-12 120 Vac 277 Vac 25.0 25.0 20.0 20.0 THD_I(%) THD_I(%) 120 Vac VLM100W-24 15.0 277 Vac 15.0 10.0 10.0 5.0 5.0 0.0 0.0 4 4.8 5.6 6.4 7.2 2.0 8 2.4 2.8 3.2 Load Current (A) Load Current (A) Figure 16 Figure 17 3.6 4.0 VLM100W-48 120 Vac 277 Vac 1.4 1.6 25.0 THD_I(%) 20.0 15.0 10.0 5.0 0.0 1 1.2 1.8 2 Load Current (A) Figure 18 SaveEnergy@erp-power.com 11 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 11 – THD VERSUS LOAD (CONTINUED) VLM100E-12-T 230VAC VLM100E-24-T 240VAC 25.0 25.0 20.0 20.0 THD_I(%) THD_I(%) 220VAC 15.0 10.0 220VAC 230VAC 240VAC 2 2.8 3.6 15.0 10.0 5.0 5.0 0.0 0.0 4 4.8 5.6 6.4 7.2 8 2.4 3.2 Load Current (A) Load Current (A) Figure 19 Figure 20 4 VLM100E-48-T 220VAC 25.0 230VAC 240VAC THD_I(%) 20.0 15.0 10.0 5.0 0.0 1 1.2 1.4 1.6 1.8 2 Load Current (A) Figure 21 SaveEnergy@erp-power.com 12 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 12 - MECHANICAL DETAILS  Packaging Options:  I/O Connections:  Models with flying leads: and with “-S” suffix  Models with “T” suffix:  Ingress Protection:  Mounting Instructions: Aluminum case 18 AWG on all leads, 203mm (8 in) long, 105°C rated, stranded, stripped by approximately 9.5mm, and tinned. All the wires, on both input and output, have a 300 V insulation rating. Terminal Blocks IP20 rated The VLM100 driver case must be secured on a flat surface through the two mounting tabs, shown here below in the case outline drawings. We recommended mounting the VLM100 on a baseplate with dimensions of 195 x 60 x 3 mm (7.68 x 2.36 x 0.12 in.). 13 - OUTLINE DRAWINGS (VLM100W MODELS WITH FLYING LEADS) Dimensions: Volume: Weight: L 137 x W 26.0 x H 19.8 mm (L 5.39 x W 1.02 x H 0.78 in) 70.53 cm3 (4.30 in3) 159 g (5.60 oz) All dimensions are in mm Figure 22 SaveEnergy@erp-power.com 13 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 14 - OUTLINE DRAWINGS (VLM100E MODELS WITH FLYING LEADS) Dimensions: Weight: L 151 x W 26.0 x H 19.8 mm (L 5.94 x W 1.03 x H 0.78 in) 162 g (5.71 oz) All dimensions are in mm Figure 23 SaveEnergy@erp-power.com 14 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 15 - OUTLINE DRAWINGS (MODELS WITH “-T” SUFFIX) Dimensions: Weight: L 193.2 x W 26.2 x H 19.85 mm (L 7.60 x W 1.03 x H 0.78 in) 165 g (5.82 oz) All dimensions are in mm Figure 24 SaveEnergy@erp-power.com 15 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 16 - OUTLINE DRAWINGS (MODELS WITH “-T” SUFFIX AND STRAIN RELIEFS) Dimensions: L 251.6 x W 26.2 x H 19.85 mm (L 9.91 x W 1.03 x H 0.78 in) All dimensions are in mm Figure 25 Notes: 1. Strain reliefs for “-T” models are not included and can be ordered separately using part number SR2. 2. Strain reliefs allow the driver to operate as independent control gear. This designation allows the driver to be mounted outside of the luminaire. Without strain reliefs the driver must be mounted inside the luminaire. 3. Order quantity for SR2 is per strain relief, and 2 strain reliefs are needed for each driver. 4. Additional information regarding strain reliefs can be found under the accessories section on the ERP website. SaveEnergy@erp-power.com 16 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 17 - OUTLINE DRAWINGS (MODELS WITH “-S” SUFFIX) Dimensions: Weight: L 137 x W 26.0 x H 23.85 mm (L 5.39 x W 1.02 x H 0.94 in) 188 g (6.63 oz) All dimensions are in mm Figure 26 SaveEnergy@erp-power.com 17 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers 18 - LABELING The VLM100W-48 and VLM100E-24-T are used in figure 27 as examples to illustrate typical labels. Figure 27 USA Headquarters Tel: +1-805-517-1300 Fax: +1-805-517-1411 893 Patriot Drive, Suite E, Moorpark, CA 93021, USA CHINA Operations Tel: +86-756-6266298 Fax: +86-756-6266299 No. 8 Pingdong Road 2 Zhuhai, Guangdong, China 519060 ERP Power, LLC (ERP) reserves the right to make changes without further notice to any products herein. ERP makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ERP assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in ERP data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. ERP does not convey any license under its patent rights nor the rights of others. ERP products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the ERP product could create a situation where personal injury or death may occur. Should Buyer purchase or use ERP products for any such unintended or unauthorized application, Buyer shall indemnify and hold ERP and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ERP was negligent regarding the design or manufacture of the part. ERP is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. SaveEnergy@erp-power.com 18 www.erp-power.com     96 W, Efficient, Compact Non-Dimmable CV Class 2 / Class II LED Drivers Revision History Date Comments 13FEB2019  Pg1: render files to stamped sheet metal  Pg2: changed UL limit to correct 5A  Pg10-13: changed MCO to stamped sheet metal 20MAR2019  Pg2: added strain relief info  Pg12: added strain relief info 09APR2019  Added euro flying leads MCO  Added weights  Added euro characterization charts 29OCT2019  Pg2: added safety, EMC compliance column 10MAR2020  Pg18: updated label image 23APR2020  Pg2: added strain relief note  Pg16: added strain relief notes © ERP Power, LLC 19 VLM100 Series Data Sheet Rev. April 2020
VLM60E-24-T 价格&库存
很抱歉,暂时无法提供与“VLM60E-24-T”相匹配的价格&库存,您可以联系我们找货
VLM60E-24-T
    • 1+180.690841+21.93500
    • 4+179.846474+21.83250
    • 15+179.8424915+21.83202
    • 30+179.8385230+21.83154
    • 75+179.8345475+21.83105
    VLM60E-24-T
    • 1+175.654161+21.32358
    • 4+174.833334+21.22393
    • 15+174.8294715+21.22346
    • 30+174.8256030+21.22299
    • 75+174.8217375+21.22252
    VLM60E-24-T
      • 1+162.163061+19.68582
      • 5+161.405275+19.59383
      • 20+161.4017020+19.59340
      • 50+161.3981350+19.59296
      • 125+161.39457125+19.59253
