HV-317464/260/UYSYGM-ST3-TR1-U1930 数据手册
3.0mm Round LED LAMP with Holder
Harvatek 3.0mm Round LED LAMP with Holder
Official Product
Specifications are subject to change without notice. Data
and drawings herein are copyrighted.
Customer Part No.
Data Sheet No.
Aug.14. 2021 Version of 1.0
Page 1/15
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
Customer Part No.
Data Sheet No.
Page 2/15
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 317464 / 260 / UYSYGM - ST3 - TR1 - U1930
Series Name
HV :
HARVATEK
Color Code
Remark
317464:Array 1 Lamp
260: 3.0mm Round LED LAMP.
UYSYG:
GaP 590nm Yellow Chip.
GaP 570nm Green Chip.
U1930:
Customer Product
Code
M:
White Diffused
ST3: HARVATEK Part No.
TR1: Carrier Tape Dimensions
Features:
Stable Color
Popular 3.0mm through hole package.
White Diffused Lens.
Official Product
Customer Part No.
Data Sheet No.
Page 3/15
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Data Sheet No.
Page 4/15
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
Y/G
30
mA
Operating Temperature
Topr
Y/G
-40to+85
Storage Temperature
Tstg
Y/G
-40to+85
Soldering Temperature*1
Tsol
Y/G
260±5
Power Dissipation
Pd
Y/G
75
mW
Reverse Voltage
VR
Y/G
1.1
V
Peak Forward Current*2
IFP
Y/G
75
mA
*1:Soldering time ≦ 5 seconds. *2:Pulse Width≦ 100μs and Duty≦ 1%
Official Product
Customer Part No.
Data Sheet No.
Page 5/15
Electrical and Optical Characteristic
Parameter
Symbol
Forward Voltage
VF
IF=20 mA
Reverse Current
IR
VR= 1.1 V
Luminous Intensity
IV
IF=20 mA
Viewing Angle
2θ1/2
IF=20 mA
Dominant
Wavelength
λd
Peak Wavelength
Spectrum Radiation
Bandwidth
λρ
Δλ
Condition
Min.
Typ.
Max.
Unit
Y/G
2.0
2.4
V
Y/G
10
μA
Y
10
30
G
10
30
Y/G
60
Y
590
IF=20 mA
mcd
deg
nm
G
570
Y
595
IF=20 mA
nm
G
575
Y
IF=20 mA
nm
G
18
Notes:
θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline
value.
Official Product
Customer Part No.
Data Sheet No.
Page 6/15
Specifications for Bin Grading:(Y)
Iv(mcd)
Grade
Min.
Max.
L
10
M
16
32
N
25
50
P
40
80
Q
63
125
λd(nm)
Grade
Min.
Max.
3
585
588
4
587
590
5
589
592
6
591
594
7
593
595
8
594
597
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Data Sheet No.
Page 7/15
Specifications for Bin Grading:(G)
Iv(mcd)
Grade
Min.
Max.
L
10
M
16
32
N
25
50
P
40
80
Q
63
125
λd(nm)
Grade
Min.
Max.
5
566
569
6
568
571
7
570
573
8
572
575
9
574
577
Notes:
Official Product
Customer Part No.
Data Sheet No.
Page 8/15
Typical Electro-Optical Characteristics Curve(Y)
Official Product
Customer Part No.
Data Sheet No.
Page 9/15
Typical Electrical / Optical Characteristics Curves(G)
Official Product
Customer Part No.
Data Sheet No.
Page 10/15
Soldering condition
Recommended soldering conditions
Reflow
Pre-heat
150~200℃
Pre-heat time
120 seconds Max.
Peak temperature
240℃ Max.
Soldering time
5seconds Max.
Condition
Refer to Temperature-profile
• After reflow soldering rapid cooling should be avoided
Pb-free solder temperature profile
• We suggest that the a maximum reflow soldering temperature is 240℃ for 5seconds Max。
• Reflow soldering should not be done more than two times;
• When soldering ,do not put stress on the LEDs during heating;
Official Product
Customer Part No.
Data Sheet No.
Page 11/15
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%
LTPD:3%
No
Item
1
Test Conditions
Solder
Heat
TEMP:260℃±5℃
Failure
Test
Sample
Hours/Cycle
Size
10 SEC
76 PCS
0/1
300 CYCLES
76 PCS
0/1
300 CYCLES
76 PCS
Judgment
Ac/Er
Criteria
H:+100℃ 15min
2
Temperature Cycle
5min
L:-40℃ 15min
H:+100℃ 5min
3
Thermal
Shock
10sec
L:-10℃ 5min
High Temperature
4
Storage
Low Temperature
5
Storage
6
DC Operating Life
High Temperature /
7
High Humidity
Iv≦Ivt*0.5
0/1
or
Vf≧U
TEMP:100℃
1000 HRS
76 PCS
TEMP:-40℃
1000 HRS
76 PCS
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
TEMP:25℃
IF=20mA
85℃/85%RH
or
Vf≦L
0/1
0/1
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability test
U:Upper Specification Limit
L:Lower Specification Limit
Official Product
Customer Part No.
Data Sheet No.
Page 12/15
Tape Dimensions(Units : mm)
Reel Dimension
Official Product
Customer Part No.
Data Sheet No.
Page 13/15
Recommended Soldering Pattern(Units : mm; Tolerance: ± 0.1)
PACKING & LABEL SPECIFICATIONS
Official Product
Customer Part No.
Data Sheet No.
Page 14/15
Revision History
Revision
Page
Version No.
Revision Date
1.0
08-14-2021
Initial Release
Official Product
Customer Part No.
Data Sheet No.
Page 15/15
HV-317464/260/UYSYGM-ST3-TR1-U1930 价格&库存
很抱歉,暂时无法提供与“HV-317464/260/UYSYGM-ST3-TR1-U1930”相匹配的价格&库存,您可以联系我们找货
