K016-D
K016-D
    M5STACK
    M5STICKC WITH WATCH ACCESSORIES
K016-D 数据手册
      M5StickC ESP32-PICO Mini IoT Development Kit SKU: K016-D Noted: Stick C ETD on Oct.10, thanks for the understanding. M5Stick‐C is a mini M5Stack, powered by ESP32. It is a portable, easy-to-use, open source, IoT development board. What it can do? This tiny block is able to realize your idea, enlighten your creativity, and help with your IoT prototying in a very short time. It will takes away a lot of the pains form the development process. M5stickC is one of the core devices in M5Stack product series which is built in a continues growing hardware & software ecosystem. It has a lot of compatible modules & units, as well as the open source code & engineering community that will help you maximum your benefit in every step of the developing process. Notice:  Only Orange type is available for now Product Features                5V DC power supply USB Type-C ESP32-based 4 MByte Flash + 520K RAM 6-Axis IMU MPU6886 Red LED IR transmitter Microphone 2 Buttons, LCD(0.96 inch), 1 Reset 2.4G Antenna: Proant 440 80 mAh Lipo Battery Extendable Socket Grove Port Wearable & Wall mounted Development Platform UIFlow, MicroPython, Arduino ESP32 Features           240 MHz dual core Tensilica LX6 microcontroller with 600 DMIPS Integrated 520 KB SRAM Integrated 802.11b/g/n HT40 Wi-Fi transceiver, baseband, stack and LWIP Integrated dual mode Bluetooth (classic and BLE) Hall sensor 10x capactive touch interface 32 kHz crystal oscillator PWM/timer input/output available on every GPIO pin SDIO master/salve 50MHz SD-card interface support Part List   1x M5StickC 1x USB Type-C cable                   https://m5stack.com/products/stick‐c/10‐2‐19
K016-D 价格&库存
很抱歉,暂时无法提供与“K016-D”相匹配的价格&库存,您可以联系我们找货
