K016-T2
K016-T2
    M5STACK
    ESP32-PICO,Lepton 3.0 热成像,红外(IR) 传感器 M5Stack 平台评估扩展板
K016-T2 数据手册
M5StickT2 SKU:K016-T2 Description M5StickT2is an exquisite and compact infrared thermal imaging camera. It adopts the latest FLIR Lepton 3.0 long-wave infrared (LWIR) camera core with an effective resolution of 160 * 120 for a clear and stable image. As it is a large area non-contact infrared sensor, it is a good solution for temperature measurement. Its main control chip is Espressif’s ESP32, which has built-in support for Wi-Fi and Bluetooth connections, and computing speeds of up to 240Mhz. This provides a favorable guarantee for image output with a FPS reaching 7 and above. The screen is 1.14 inches and has a resolution of 135 * 240. The device comes with a rich variety of hardware resources: An on-board 6-axis Inertial Measurement Unit, a digital microphone and a power management chip and a built-in 300mAh battery, all embedded into the device. In terms of interactive operation, two programmable buttons and a rotary encoder are provided. In order to facilitate users to connect more peripherals, a 4 Pin HY2.0 interface with I2C support is provided at the bottom. The body is 3D printed from high quality Black Nylon filament. In addition, an M3 screw hole and a 1/4" screw hole are provided underside for easy mounting. Power switch operation: Power on :Long press power button for 2 seconds Power off :Short press power button for 6 seconds Usage Press the reset button to power on. The default display screen is RGB display mode. The left side is the temperature image, the upper right is the power display, and the lower right is the histogram and temperature range. The temperature range is automatically adjusted with the target temperature. The default bulls-eye automatically tracks the maximum temperature. Press the button on the right side of the fuselage (B button) to switch the tracking mode (minimum / center / maximum value), press the button A on the front of the fuselage to switch the image display mode (GRAY / GOLDEN / RAINBOW / IRONBLACK / RGB). Dial encoder controls the display sensitivity (adjust the display temperature and color gamut), and long press the reset button for 6 seconds to turn off. Product Features ESP32-based Case Material: Nylon 3D print FLIR Lepton 3.0 Built-in 6-Axis IMU,microphone Buttons and dial encoder IPS LCD(1.14 inch) built-in Lipo Battery GROVE/4P HY2.0 Interface Include 1x M5StickT2 1x USB Type-C(20cm) Applications Car engine failure check Building dehumidification insulation sealing test Industrial furnace inner wall refractory crack Outdoor observation of animals at night Lepton 3.0 Parameter Effective Pixels 160*120 Field of view 56° Fast imaging time < 500ms Effective Frame Rate 8.7Hz Input Clock 25MHz Pixel Size 12μm Low operating power 150 mW (operating), 650 mW (during shutter event), 5 mW (standby) Scene Dynamic Range Low Gain Mode: -10 to 400°C; High Gain Mode: -10 to 140°C Spectral Range 8 to 14µm Thermal Sensitivity <50 mK(0.050°C) Optimum Temperature Range -10°C to +80°C Specification Resources Parameter ESP32 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi, dual mode Bluetooth Flash Memory 4MB Power Input 5V @ 500mA Port TypeC x 1, GROVE(I2C+I/0+UART) x 1 LCD screen 1.14 inch, 135*240 Colorful TFT LCD, ST7789 Button Custom button x 2 MEMS MPU6886 MIC SPM1423 Power Manager AXP192 Battery 300 mAh @ 3.7V Antenna 2.4G 3D Antenna Thermal Lepton 3.0 Encoder Dial encoder Operating Temperature 0°C to 60°C Net weight 26g Gross weight 82g Product Size 48*30*29mm Package Size 144*44*43mm Case Material Plastic ( PC ) EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader Download MacOS Version Easyloader Description: Thermal imaging operation instructions: A button to switch tracking mode, B button to switch display mode, dial to ? adjust sensitivity. PinMap BUTTON A & BUTTON B ESP32 GPIO37 BUTTON A Button Pin GPIO39 BUTTON B Button Pin IPS LCD Driver IC:ST7789 Resolution:135 * 240 ESP32 GPIO15 GPIO13 GPIO23 GPIO18 GPIO5 IPS LCD MOSI CLK DC RST CS HY2.0 PORT ESP32 GPIO33 GPIO32 5V GND HY2.0 port SCL SDA 5V GND MIC (SPM1423) ESP32 GPIO0 GPIO34 MICPHONE SCL SDA 6-Axis posture sensor (SH200Q/MPU6886) & power management IC (AXP192) ESP32 GPIO22 GPIO21 6-Axis posture sensor SCL SDA power management IC SCL SDA AXP192 Microphone RTC TFT backlight TFT IC ESP32/3.3V MPU6886/SH200Q 5V GROVE LDOio0 LDO1 LDO2 LDO3 DC-DC1 IPSOUT Dial Encoder ESP32 PA2 PA3 PA4 Encoder SW EN_B EN_A Related Link datasheet ESP32-PICO MPU6886 AXP192 SPM1423 Lepton datasheet Lepton enigneering datasheet Lepton software interface description 3D Printer STL File STL Example Arduino If you want the complete code, please click here Version Change Release Date Product Change Note: 2020.1 Initial public release / 2021.5 Optimize the internal structure, reduce the volume of the pulsator, and optimize the details /
K016-T2 价格&库存
很抱歉,暂时无法提供与“K016-T2”相匹配的价格&库存,您可以联系我们找货
