K016-F
K016-F
    M5STACK
    M5STICKC+ DEV KIT WITH HAT
K016-F 数据手册
  M5StickC  Development Kit  with Hat  SKU: K016‐F    NOTE: ENV HAT has been upgraded to ENV Hat II.  Description  M5StickC is a mini M5Stack, powered by ESP32, which is a single 2.4 GHz Wi‐Fi and Bluetooth combo  chip and integrates a 4‐MB SPI flash. It is a portable, easy‐to‐use, open source, IoT development board.  What it can do? This tiny block is able to realize your idea, enlighten your creativity, and help with your  IoT prototying in a very short time. It will take away a lot of pains from the development  process.M5stickC is one of the core devices in M5Stack product series.  ENV II is an environment sensor which can sense temperature, humidity and atmospheric pressure. It is  built with SHT30, BMP280 and BMM150 sensors, it is programmed over I2C. SHT30 is a digital  temperature and humidity sensor with high precision and low power consumption. BMP280 is an  absolute barometric pressure sensor which is especially designed for mobile applications. BMM150 is a  magnetometer, which can be used to monitor the change of magnetic field and the direction of  magnetic field.It offers the highest flexibility to optimize the device regarding power consumption,  resolution and filter performance.  SPK HAT is an M5StickC compatible speaker, integrated PAM8303 amplifier (3w single channel type D  power amplifier), High PSRR and differential inputs eliminate noise and rf interference, thus it has the  characteristics of simple functions and high audio reproduction.  It is built in a continually growing hardware and software ecosystem. It has a lot of compatible modules  and units, as well as the open source code & engineering communities that will help you maximize your  benefits in every step of the developing process.  Product Features  ESP32‐based  Built‐in 6‐Axis IMU  Red LED  IR transmitter  Microphone  Buttons, LCD(0.96 inch)  Built‐in Lipo Battery  Extendable Socket  Wearable & Wall mounted  Development Platform UIFlow, MicroPython, Arduino    ENV HAT II  Measurement of temperature, humidity, air pressure and magnetic field  High‐precision  Support IIC  GROVE interface, support UIFlow and Arduino  Two Lego installation holes    SPK HAT  Ultra‐low EMI interference, 20dB better than FCC class B standard at 300MHz  Voltage 5 v power supply, with 4 Ω load power output 3 w, 10% of the total harmonic distortion  Ultra‐low noise without input  Power range: 2.8V~5.5V  Shortcut protection  Include  1x M5StickC  1x 20cm USB Type‐C cable  1x ENV Hat II  1x SPK Hat  1x WALL/1515  1x Brick  1x Watch Belt    Applications  IoT terminal controller  Wearable devices  STEM education product  DIY creation  Weather Station  Compass  MP4/MP3                https://m5stack.com/products/m5stickc‐development‐kit‐with‐hat?_pos=1&_sid=b23733b50&_ss=r/10‐23‐20
K016-F 价格&库存
很抱歉,暂时无法提供与“K016-F”相匹配的价格&库存,您可以联系我们找货
