JBM-026
JBM-026
    PISUPPLY
    箱 红色 分叉式双侧 3.504" 长 x 2.441" 宽(89.00mm x 62.00mm) X 1.575"(40.00mm)
JBM-026 数据手册
JustBoom Amp HAT Case Black SKU: JBM-011 Red SKU: JBM-026 The Amp HAT Case is a sleek and durable enclosure for the Raspberry Pi and Amp HAT. Removing or installing the Raspberry Pi or Amp board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC HAT and Amp HAT. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! Description The Amp HAT Case is a sleek and durable enclosure for the Raspberry Pi and Amp HAT. Removing or installing the Raspberry Pi or Amp board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC HAT and Amp HAT. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! DAC HAT Case Features: • • • • • • • • • Supports and protects your JustBoom Amp and Raspberry Pi Easy to open case allows for quick access to your Amp and Raspberry Pi boards Smooth black finish that blends in with any audio setup Leaves all ports accessible Compatible with the Raspberry Pi 3, 2, and B+ No tools are needed for assembly or disassembly Designed and made in the UK from high quality material 4 x rubber feet included Access to micro SD port Setup Guide Follow our full setup guide for assembling your JustBoom Amp HAT and Case. Additional information WEIGHT 0.077 kg DIMENSIONS 8.9 x 6.2 x 4 cm COLOUR Black, Red https://www.pi-supply.com/product/justboom-amp-hat-case//2/9/18
JBM-026 价格&库存
很抱歉,暂时无法提供与“JBM-026”相匹配的价格&库存,您可以联系我们找货
JBM-026
    • 1+17.93575
