JBM-027
JBM-027
    PISUPPLY
    箱 红色 分叉式双侧 2.717" 长 x 1.496" 宽(69.00mm x 38.00mm) X 1.378"(35.00mm)
JBM-027 数据手册
JustBoom DAC Zero Case Black SKU: JBM-012 Red SKU: JBM-027 The DAC Zero Case is a sleek and durable enclosure for the Pi Zero and DAC Zero pHAT. Removing or installing the Pi Zero or DAC Zero pHAT board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC Zero pHAT and Pi Zero. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! Description The DAC Zero Case is a sleek and durable enclosure for the Pi Zero and DAC Zero pHAT. Removing or installing the Pi Zero or DAC Zero pHAT board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC Zero pHAT and Pi Zero. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! • • • • • • • • • DAC Zero pHAT Case Features: Supports and protects your JustBoom DAC Zero and Pi Zero Easy to open case allows for quick access to your DAC Zero and Pi Zero Smooth black finish that blends in with any audio setup Leaves all ports accessible Compatible with the Pi Zero No tools are needed for assembly or disassembly Designed and made in the UK from high quality material 4 x rubber feet included Access to micro SD port Setup Guide Follow our full setup guide for assembling your JustBoom DAC Zero and Case. Additional information WEIGHT 0.049 kg DIMENSIONS 6.9 x 3.8 x 3.5 cm https://www.pi-supply.com/product/justboom-dac-zero-case/2/9/18
JBM-027 价格&库存
很抱歉,暂时无法提供与“JBM-027”相匹配的价格&库存,您可以联系我们找货
JBM-027
    • 1+17.91718
