JustBoom DAC and Amp Case
Red SKU: JBM-030 Black SKU: JBM-015
Description
The DAC and Amp Case is a stylish and durable enclosure for the standalone
JustBoom DAC and Amp boards. You can have either one or both of the boards in the case at the
same time.
Removing or installing the Raspberry Pi, DAC or Amp boards is quick and simple; all without the
need for tools. The two piece case is incredibly easy and straight forward to use.
This is currently the only case to perfectly accommodate the JustBoom DAC and Amp. We’ve
designed the case to allow enough clearance around all connectors so thick, high-end cables can fit
securely. Get setup within minutes and start enjoying high quality audio!
DAC and Amp Case Features:
Supports and protects your JustBoom Amp, DAC, and Raspberry Pi
Easy to open case allows for quick access to your Amp, DAC or Raspberry Pi boards
Smooth black finish that blends in with any audio setup
Leaves all ports accessible
Compatible with the Raspberry Pi 3, 2, and B+
No tools are needed for assembly or disassembly
Designed and made in the UK from high quality material
4 x rubber feet included
Access to micro SD port
Setup Guide
Follow this guide on assembling your DAC and Amp case.
Additional information
WEIGHT
0.065 kg
DIMENSIONS
7.1 x 6.7 x 3.2 cm
https://www.pi-supply.com/product/justboom-dac-and-amp-case/2/9/18
很抱歉,暂时无法提供与“JBM-015”相匹配的价格&库存,您可以联系我们找货
