JBM-030
JBM-030
    PISUPPLY
    箱 红色 分叉式双侧 2.795" 长 x 2.638" 宽(71.00mm x 67.00mm) X 1.260"(32.00mm)
JBM-030 数据手册
JustBoom DAC and Amp Case Red SKU: JBM-030 Black SKU: JBM-015 Description The DAC and Amp Case is a stylish and durable enclosure for the standalone JustBoom DAC and Amp boards. You can have either one or both of the boards in the case at the same time. Removing or installing the Raspberry Pi, DAC or Amp boards is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC and Amp. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! • • • • • • • • • DAC and Amp Case Features: Supports and protects your JustBoom Amp, DAC, and Raspberry Pi Easy to open case allows for quick access to your Amp, DAC or Raspberry Pi boards Smooth black finish that blends in with any audio setup Leaves all ports accessible Compatible with the Raspberry Pi 3, 2, and B+ No tools are needed for assembly or disassembly Designed and made in the UK from high quality material 4 x rubber feet included Access to micro SD port Setup Guide Follow this guide on assembling your DAC and Amp case. Additional information WEIGHT 0.065 kg DIMENSIONS 7.1 x 6.7 x 3.2 cm https://www.pi-supply.com/product/justboom-dac-and-amp-case/2/9/18
JBM-030 价格&库存
很抱歉,暂时无法提供与“JBM-030”相匹配的价格&库存,您可以联系我们找货
JBM-030
    • 1+17.92090
