QLUV04H3U
QLUV04H3U
    QUELIGHTING
    紫外线(UV) 发射器 425nm(420nm ~ 430nm) 3.2V 700mA 365mW/sr @ 350mA(标准) 120° 1212(3030 公制)
QLUV04H3U 数据手册
QLUV04H3U 3030 UV LED QLUV04H3U V1.1 V1.0 Product Outline: This is the high power LED with reflector type. EMC 3030 UV LED series are designed for high current operation and high power output applications. Quelighting UV LED is ideal UV light source for curing, printing, and detecting applications Features: • • • • • • • • 420nm High Power UV LED Max. current = 700mA Package Dimension = 3.2mmX3.0mmX0.6mm View angel >120° RoHS compliant ESD 8KV Custom Bin available upon special request Application: • • • • • UV Curing Printing and Coating Adhesive Medical applications Industrial facility applications Compliance and Certification: 1 QLUV04H3U V1.1 V1.0 Mechanical Property: Note: 1. All dimension in millimeters 2. tolerance is ±0.2mm Recommended Solder footprint: Note: 1. All dimension in millimeters 2. The drawing without tolerances is for reference only 3. Suggest stencil T=0.1 mm 2 QLUV04H3U V1.1 V1.0 Electrical / Optical Characteristic Product QLUV04H3U-420nm View angle IF(mA) >120 350 (T=25 oC) VF(V) Typ. max 3.2 3.5 Wavelength (nm) Radiant Power(mW) min 420-430 typ. 365 (1) The Forward Voltage tolerance is ±0.1V (2) The Peak wavelength tolerance is ±2 (3) The Radiant power is ± 7% Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 700 mA Leakage Current (5V) Ir 10 μA Power Dissipation Pd 2.5 W Pulse Forward Current Ifp 700 mA LED Junction Temperature TJ 85 ℃ Storage Temperature Tstg -40 ~ 80 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Thermal Resistance Junction / Solder Point Tsol 260 < 10 sec ℃ Rth Typ. 13.1 ℃/W *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder 3 QLUV04H3U V1.1 V1.0 Peak Wavelength Binning Wavelength Rank @ 350mA Code name Low High U420A 420 430 Units nm Forward Voltage (VF) Bin: VF rank @ 350mA Code name Low High 23 3 3.2 45 3.2 3.4 67 3.4 3.6 89 3.6 3.8 A0 3.8 4.0 Units V The forward voltage tolerance is ± 0.2V Radiant Power Binning: Radiant Power rank (mW) @ 350mA Code name Low High P02 200 300 P03 300 400 P04 400 500 P05 500 600 Units mW luminous flux tolerance is ± 7% 4 QLUV04H3U V1.1 V1.0 Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLUV04H3U V1.1 V1.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLUV04H3U V1.1 V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 350 mA △Vf< 10% Luminous Flux Iv 350 mA △Iv< 30% 7 QLUV04H3U V1.1 V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLUV04H3U V1.1 V1.0 Taping & Packing: 9 QLUV04H3U V1.1 V1.0 10 QLUV04H3U V1.1 V1.0 Labeling Ordering Information: Part # QLUV04H3U Multiple Quantities Quantity per Reel 1000, 2000, 4000 pcs 11 QLUV04H3U V1.1 V1.0 Revision History: Revision Date: Changes: Version #: 09-14-2018 Initial release 1.0 07-10-2021 Update the specification performance 1.1 12
QLUV04H3U 价格&库存
很抱歉,暂时无法提供与“QLUV04H3U”相匹配的价格&库存,您可以联系我们找货
