QLUV07EYGE
QLUV07EYGE
    QUELIGHTING
    紫外线(UV) 发射器 300nm ~ 315nm 6.5V 30mA 2mW/sr @ 20mA 130° 1414(3535 公制)
QLUV07EYGE 数据手册
QLUV07EYGE 3535 3mW UVB LED QLUV07EYGE V1.1 Product Outline: The high output ceramic type 3535 LEDs, UVB LED series are designed for high current operation and high power output applications. Quelighting UV LED is ideal UV light source for water disinfection. Features: • • • • • • • • • UVB 310nm LED Max. current = 30mA Package Dimension = 3.5mmX3.5mmX1.05mm Ceramic subtract MSL 3 qualified according to J-STD 020 Low thermal resistance View angle = 120 degree RoHS compliant Custom Bin available upon special request Application: • • • • • Plant Growth Skin Condition Treatment Disinfection Phototherapy Bio-Analysis/DetectionFeatures Compliance and Certification: 1 QLUV07EYGE V1.1 Mechanical Property: 140 Degree Field Angle Note: 1. All dimension in millimeters 2. tolerance is ±0.2mm Recommended Solder footprint: Note: 1. All dimension in millimeters 2. The drawing without tolerances is for reference only 3. Suggest stencil T=0.12 mm 2 QLUV07EYGE V1.1 Electrical / Optical Characteristic (T=25 oC) VF(V) Product View angle QLUV07EYGE IF(mA) 130 20 Typ. max 6.5 8 Radiant Power(mW) Wavelength (nm) 300-315 min typ. 2 3.3 (1) The Forward Voltage tolerance is ±0.1V (2) The Peak wavelength tolerance is ±2 (3) The Radiant power is ± 7% Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) Tj (oC)** TSOL (oC)** Rth(J-S) (C/W)*** QLUV07EYGE 0.24 30 40 -5 -40 – 60 -40 - 85 85 260 15 *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder Peak Wavelength Binning Wavelength Rank @ 20mA Code name Low High Units U300 300 315 nm Forward Voltage (VF) Bin: VF Rank @ 20mA Code name Min. Max. Units A B C D E F 5.0 5.5 6.0 6.5 7.0 7.5 5.5 6.0 6.5 7.0 7.5 8.0 V The forward voltage tolerance is ± 0.1V 3 QLUV07EYGE V1.1 Characteristic Curves Forward Voltage vs. Forward Current Relative Luminous Intensity vs Ambient Temperature Forward current vs. Relative luminous intensity Solder Temperature (Slug) vs. Maximum Forward Current 4 QLUV07EYGE V1.1 Spectrum Distribution Typical Representative Spatial Radiation Pattern 5 QLUV07EYGE V1.1 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 500 Hrs 10 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 500 Hrs 10 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 500 Hrs 10 pcs 4 Steady State Operating Life of Low Temperature 85℃ 65℃ Operating 500 Hrs 10 pcs 5 Low temperature storage -40℃ -40℃ Storage 500 Hrs 10 pcs 6 High temperature storage 100℃ 100℃ Storage 500 Hrs 10 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 500 Hrs 10 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 100 Cycle 10 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 10 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 10 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 100 Cycle 10 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 100 mA △Vf< 10% Luminous Flux Iv 100 mA △Iv< 30% 6 QLUV07EYGE V1.1 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly Temperature Min(Tsmin) 100℃ 150℃ Temperature Max(Tsmax) 150℃ 200℃ Time(ta) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up rate(TL to TP) 3℃/second max. 3℃/second max. Liquidous Temperature(TL) 183℃ 217℃ Time(tL) maintained above TL 60-150 seconds 60-150 seconds Peak package body temperature(TP) 235℃ 260℃ Time within 5℃ of Actual Peak temperature (tp) Ramp-down rate(TP to TL) 20seconds* 30 seconds* 6℃/second max. 6℃/second max. Time 25℃ to peak temperature 6 minutes max. 8 minutes max. * Tolerance for peak profile temperature (TP) is defined as a supplier minimum and a user maximum. 7 QLUV07EYGE V1.1 Taping & Packing: Notes: 1. Drawing not to scale. 2. All dimensions are in millimeters. 3. Unless otherwise indicated, tolerances are ± 0.10mm. 8 QLUV07EYGE V1.1 Eye Safety Guidelines During operation The LED emits high intensity ultraviolet (UV) light, which is harmful to skin and eyes. UV light is hazardous to skin and may cause cancer. 1) Avoid looking directly at the UV light: Wear protective glasses/goggle with ANSI Z87 rated. 2) Wear facial shield / Lab Coat with long sleeve / Gloves to cover skin may exposed to UVC LEDs. 3) Attach warning labels on products/systems that is composed with UV LEDs. 9 QLUV07EYGE V1.1 Warning label: Labeling Ordering Information: Part # QLUV07EYGE Multiple Quantities Quantity per Reel 250, 500 or 1000 pcs 10 QLUV07EYGE V1.1 Revision History: Revision Date: Changes: Version #: 01-01-2020 Initial release 1.0 09-08-2021 Added the Vf bin code 1.1 11
QLUV07EYGE 价格&库存
很抱歉,暂时无法提供与“QLUV07EYGE”相匹配的价格&库存,您可以联系我们找货
