QLUV07J3QCV
3535 3W 60D UVA LED
QLUV07J3QCV V1.0
Product Outline:
The high output ceramic type of 3535 UV LEDs with 60 degree quartz glass lens. High
power UV LED series are designed for high current operation and high power output
applications. Quelighting UV LED is ideal UV light source for curing, printing, and detecting
applications
Features:
405nm
High Power UV LED
Quartz glass lens
Max. current = 1000mA
Package Dimension = 3.5mm X 3.5mm X 2.48mm
Ceramic subtract
Low thermal resistance
View angle = 60 degree
RoHS compliant
ESD 4KV
Custom Bin available upon special request
Application:
UV gluing, UV curing, UV marking
Printing and Coating
Adhesive
Medical applications
Industrial facility applications
Compliance and Certification:
1
QLUV07J3QCV V1.0
Mechanical Property:
(Dimension)
Note:
1. All dimension in millimeters
2. tolerance is ±0.2mm
3. Please do not use a force of over 3kgf impact or pressure on the lens of the LED, otherwise
it will cause a catastrophic failure.
2
QLUV07J3QCV V1.0
Recommended Solder footprint:
Note:
2. The drawing without tolerances is for reference only
3. Suggest stencil T=0.12 mm
Electrical / Optical Characteristic
Product
QLUV07J3QCV-271-405
View
angle
IF(mA)
60
700
(T=25 oC)
VF(V)
Typ.
max
3.5
4.0
Wavelength
(nm)
400-405
Radiant
Power(mW)
min
typ.
830
1050
(1) The Forward Voltage tolerance is ±0.1V
(2) The Peak wavelength tolerance is ±2
(3) The Radiant power is ± 7%
Absolute Maximum Rating
(T=25 oC)
Part #
Pd (mW)
IF (mA)
IFP (mA)*
VR (V)
TOP (oC)
TST (oC)
Tj (oC)**
TSOL
(oC)**
Rth(J-S)
(C/W)***
QLUV07J3QCV
4000
1000
1100
-5
-40 – 85
-40 - 100
125
260
8
*Duty 1/10 @ 10Khz
** Junction Temperature
*** IR Reflow for no more than 10 sec @ 260 oC
**** Thermal resistance is calculated from junction to solder
3
QLUV07J3QCV V1.0
Peak Wavelength Binning
Wavelength Rank @ 700mA
Code name
Low
High
Units
U400
400
405
nm
Forward Voltage (VF) Bin:
VF rank @ 700mA
Code name
Low
High
45
3.2
3.4
67
3.4
3.6
89
3.6
3.8
AB
3.8
4.0
Units
V
The forward voltage tolerance is ± 0.1V
Radiant Power Binning:
Radiant Power rank (mW) @ 700mA
Code name
Low
High
T2
755
830
U1
830
910
U2
910
1000
V1
1000
1100
V2
1100
1210
W1
1210
1330
Units
mW
luminous flux tolerance is ± 7%
4
QLUV07J3QCV V1.0
Characteristic Curves
Forward Voltage vs. Forward Current
Forward current vs. Relative luminous intensity
5
QLUV07J3QCV V1.0
Radiation Pattern for 60 degree
Spectrum Distribution
6
QLUV07J3QCV V1.0
◼ Reliability test:
No
Item
Condition
Time/Cycle
Sample
size
1
Steady State Operating Life of Room
Temperature
25℃ Operating
1000 Hrs
20 pcs
2
Steady State Operating Life of Low
Temperature -40℃
-40℃ Operating
1000 Hrs
20 pcs
3
Temperature 60℃
60℃ Operating
1000 Hrs
20 pcs
4
Temperature 85℃
85℃ Operating
1000 Hrs
20 pcs
5
Low temperature storage -40℃
-40℃ Storage
1000 Hrs
20 pcs
6
High temperature storage 100℃
100℃ Storage
1000 Hrs
20 pcs
7
Steady State Operating Life of High
Humidity Heat 60℃90%
60oC/90% Operating
1000 Hrs
20 pcs
8
Steady State
Condition
25℃10Hz duty=1/10 Operating
200 Cycle
20 pcs
9
Resistance to soldering heat on PCB
(JEDEC MSL3)
pre-store@60℃, 60%RH for
52hrs Tsld max.=260 10sec
3 Times
20 pcs
10
Heat Cycle Test (JEDEC MRC)
25℃~65℃~-10℃, 90%RH,
24hr/1cycle
10 Cycle
20 pcs
11
Thermal shock
-40℃/ 20minr~ 5minr~125℃
/20min
100 Cycle
20 pcs
Pulse
Operating
Life
◼ Judgment Criteria:
Item
Symbol
Test Condition
Judgment
Criteria
Forward Voltage
Vf
700 mA
△Vf< 10%
Luminous Flux
Iv
700 mA
△Iv< 30%
7
QLUV07J3QCV V1.0
Solder Profile:
-The recommended reflow soldering profile is as follows (temperatures indicated are as
measured on the surface of the LED resin):
Notes:
●We recommend using the M705-S101-S4 solder paste from SMIC (SenjuMetal Industry Co., Ltd.)
for lead-free soldering.
8
QLUV07J3QCV V1.0
●Do not use solder pastes with post reflow flux residue>47%. (58Bi-42Sn eutectic alloy, etc) This kind of
solder pastes may cause a reliability problem to LED
●All temperatures refer to topside of the package, measured on the package body surface.
●Repairing should not be done after the LEDs have been soldered. When repairing is unavoidable,
a double-head soldering iron should be used. It should be confirmed beforehand whether the
characteristics of the LEDs will or will not be damaged by repairing.
●Reflow soldering should not be done more than three times
●When soldering, do not put stress on the LEDs during heating.
●After soldering, do not warp the circuit board.
Taping & Packing:
9
QLUV07J3QCV V1.0
Notes:
1. Drawing not to scale.
2. All dimensions are in millimeters.
3. Unless otherwise indicated, tolerances are ±0.10mm.
10
QLUV07J3QCV V1.0
Handling Precautions
• LEDs are ESD (electrostatic discharge) sensitive; static electricity and surge voltages seriously damage
UV LEDs and can result in product failure
• Use proper ESD protection, including grounded wrist straps, ESD footwear and clothes
• Ensure that tools, jigs and machines being used are properly grounded
• LED mounting equipment should include protection against voltage surge
• The UVC LED is not protected by a lens and requires careful handling
• Do not handle the LED with bare hands as it may contaminate the LED surface and affect the optical
characteristics.
• Avoid touching the LED die
• Do not use adhesives that outgas organic vapor
• Dropping the product may cause damage
• If handling the product with tweezers, use only the side of the package and be careful not to apply
excessive force
• Proper thermal management is required to prevent warpage and damage to the modules and its
components.
• Do not apply mechanical force or excess vibration during handling or normal operation
Storage Precautions
Please do not open the moisture proof package (with silica desiccant).more than one week.
This may cause the leads of LED discoloration.
We recommend storing LEDs in a dry box once moisture proof bag is opened.
The recommended storage conditions are temperature 5 to 30°C and humidity less than 40% RH.
It is also recommended to restore the LEDs into the moisture proof bag and reseal it.
Notes for handling Quartz lens LEDs
● Avoid touching the quartz lens especially by sharp tools such as Tweezers.
● Avoid leaving fingerprints on the quartz lens.
● Please store the LEDs away from dusty areas or seal the product against dust.
● Under SMT production, please avoid the mechanical pressure on the quartz lens.
● Please do not mold over the quartz lens with another resin. (epoxy, urethane, etc)
11
QLUV07J3QCV V1.0
Eye Safety Guidelines
The LED emits high intensity ultraviolet (UV) light, which is harmful to skin and eyes. UV light is
hazardous to skin and may cause cancer.
1) Avoid looking directly at the UV light: Wear protective glasses/goggle with ANSI Z87 rated.
2) Wear facial shield / Lab Coat with long sleeve / Gloves to cover skin may exposed to UVC LEDs.
3) Attach warning labels on products/systems that is composed with UV LEDs.
Samples of Warning label:
Labeling
12
QLUV07J3QCV V1.0
Ordering Information:
Part #
Multiple Quantities
QLUV07J3QCV
Quantity per Reel
250, 500 pcs
Revision History:
Revision Date:
09-23-2020
Changes:
Initial release
Version #:
1.0
13
很抱歉,暂时无法提供与“QLUV07J3QCV”相匹配的价格&库存,您可以联系我们找货
