SHELL
MASS
MATERIALS
SHELL
O'RING
NUT
MATING SEAL
LOCKING LATCH
16,1 0,3
12,5 0,5
LOCKING LATCH
7
26,1 0,5
SEALING IN UNMATED CONDITIONS
OPEN FACE SEALING
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
6
MATING SEAL
9,5 0,5
ECHELLE 3/1
5%
17.1 g
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC60529
IEC61984
UL94
UL746C
8
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
IP67 WITH R*M25* CONTACTS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
ELECTRICAL
TOUCH PROOF
NOMINAL CURRENT
IEC60529
UL1977
NOMINAL CURRENT
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
CONNECTOR BREAKING CAPACITY
UL1977
IEC61984
277V 13A WITH AWG14/16 WIRES
250VAC 13A 4KV 4
NUT
O'RING
7
IP2X
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
6
ROHS COMPLIANT
5
1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING:PHASE CONTACTS ARE MALE VERSION AND GROUND CONTACT IS FEMALE VERSION
6. UNIT IN MM
7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm
8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY
9. (**) FOR x100 pcs BULK PACKAGING ADD SUFFIX B -> UTL6TH103G1PB
PANEL CUT OUT
5
17,2+0,2
x3 MALE
PHASE
CONTACTS
16,45+0,1
A-A
3
COUPE
ECHELLE 2/1
4
O'RING
UTL10SEAL (*)
THREADED PLUG
UTL6TH103G1P (*) (**)
REAR NUT
UTL10NUT (*)
x 1 FEMALE
GROUND
CONTACT
VIEW IN MOUNTED AND
MATED CONDITIONS
PANEL THICKNESS
6mm MAX
P/N :
40,25 1
2
23/02/18
ISS
DATE
Designed by:
TITLE
Scale
1/1
A-A
1
COUPE
ECHELLE 2/1
UTL5 103G1 P
Update
Latest modification - by:
R.M.
R.M.
Date: 04/04/17
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
F
E
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N $
2
PANEL PLUG SIZE 10
UTL CONNECTOR
General linear
Tolerances:
WWW.SOURIAU.COM
G
3
CountryJurisdiction
& Control List
FR
NOT LISTED
B
H
BLACK POLYAMID
NBR
BLACK ANODIZED ALUMINIUM ALLOY
SILICON
STAINLESS STEEL
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
25,6 0,3
22.25 # 0.3
A
36,25 0,7
B
C
D
E
F
G
H
NOTES
MATING FACE
8
B.5; Validé
WIRING FACE
SOURIAU DRG N°
UTL1-0087A-C
B
NPRDS / PROJECT
IC155105C
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL5103G1P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+73.050761+8.85334
