MIKROE-5109
MIKROE-5109
    MIKRO
    SP3221E RS232 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5109 数据手册
RS232 3 Click PID: MIKROE-5109 RS232 3 Click is a compact add-on board representing a universal usable RS232 transceiver. This board features the SP3221E, a low-power RS232 transceiver from MaxLinear. The SP3221E uses an internal high-efficiency, charge-pump power supply and is compliant with EIA/TIA-232-F standards when powered by any of the mikroBUS™ power rails. The AUTO ON-LINE® feature allows the SP3221E to automatically "Wake-Up" from a Shutdown state when an RS232 cable is connected and a peripheral device is turned on. When not connected or not in use, the SP3221E will automatically shut down, drawing less supply current. This Click board™ is suitable for low-power serial communications, portable serial devices, point-of-sale equipment, and many more applications. RS232 3 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type RS232 Applications Can be used for low-power serial communications, portable serial devices, pointof-sale equipment, and many more applications On-board modules SP3221E - low-power RS232 transceiver from MaxLinear Key Features EIA/TIA-232-F standards, AUTO ON-LINE® circuitry automatically wakes up from a shutdown, minimum 250kbps data rate under load, Regulated charge pump yields stable RS-232 outputs regardless of power supply, and more Interface UART ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads RS232 3 click example on Libstock SP3221E datasheet RS232 3 click 2D and 3D files RS232 3 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-5109 价格&库存
很抱歉,暂时无法提供与“MIKROE-5109”相匹配的价格&库存,您可以联系我们找货
