AOD484
www.VBsemi.com
N-Channel 30-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) ()
30
a, e
ID (A)
0.007 at VGS = 10 V
70
0.009 at V GS = 4.5 V
60
Qg (Typ)
25 nC
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2011/65/EU
APPLICATIONS
D
• OR-ing
• Server
• DC/DC
TO-252
G
G
D
S
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
30
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 175 °C)
TC = 25 °C
70
TC = 70 °C
50
TA = 25 °C
ID
Single Pulse Avalanche Energy
Continuous Source-Drain Diode Current
L = 0.1 mH
TC = 25 °C
TA = 25 °C
IAS
39
EAS
94.8
TC = 70 °C
TA = 25 °C
IS
A
3.13b, c
100a
75
PD
W
3.25b, c
2.33b, c
TA = 70 °C
TJ, Tstg
Operating Junction and Storage Temperature Range
mJ
50a, e
TC = 25 °C
Maximum Power Dissipation
A
18b, c
200
IDM
Avalanche Current Pulse
V
21 .8b, c
TA = 70 °C
Pulsed Drain Current
Unit
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambient
Maximum Junction-to-Case
Symbol
b, d
Typ.
Max.
t 10 sec
RthJA
32
40
Steady State
RthJC
0.5
0.6
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 10 sec.
d. Maximum under steady state conditions is 90 °C/W.
e. Calculated based on maximum junction temperature. Package limitation current is 90 A.
服务热线:400-655-8788
1
VBM1310
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
30
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS/TJ
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
ID = 250 µA
VGS(th)
VDS = VGS, ID = 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
V
35
mV/°C
- 7.5
1.5
2.0
V
± 100
nA
VDS = 30 V, VGS = 0 V
1
VDS = 30 V, VGS = 0 V, TJ = 55 °C
10
VDS 5 V, VGS = 10 V
90
µA
A
VGS = 10 V, ID = 21.8 A
0.007
VGS = 4.5 V, ID = 18A
0.009
VDS = 15 V, ID = 21.8 A
160
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
2201
VDS = 15 V, VGS = 0 V, f = 1 MHz
td(off)
pF
370
VDS = 15 V, VGS = 10 V, ID = 21.8 A
VDS = 15 V, VGS = 4.5 V, ID = 21.8 A
35
45
25
35
15
1.4
2.1
18
27
VDD = 15 V, RL = 0.625
ID 24 A, VGEN = 10 V, Rg = 1
11
17
70
105
tf
10
15
td(on)
55
83
180
270
55
83
12
18
tr
td(off)
nC
f = 1 MHz
td(on)
tr
525
VDD = 15 V, RL = 0.67
ID 22.5 A, VGEN = 4.5 V, Rg = 1
tf
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Currenta
ISM
Body Diode Voltage
VSD
120
TC = 25 °C
120
IS = 22 A
0.8
1.2
A
V
Body Diode Reverse Recovery Time
trr
52
78
ns
Body Diode Reverse Recovery Charge
Qrr
70.2
105
nC
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
IF = 20 A, di/dt = 100 A/µs, TJ = 25 °C
27
25
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
AOD484
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
3.0
90
VGS = 10 V thru 4 V
2.4
I D - Drain Current (A)
75
60
45
30
1.8
1.2
TC = 25 °C
0.6
15
VGS = 2 V
TC = 125 °C
VGS = 3 V
TC = - 55 °C
0.0
2.0
0.5
1.0
1.5
VDS - Drain-to-Source Voltage (V)
1
2
3
4
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
600
0.0 30
TC = 25 °C
0.025
R DS(on) – On-Resistance (Ω)
G fs - Transconductance (S)
500
TC = 125 °C
400
300
TC = - 55 °C
200
0.020
0.015
0.010
VGS = 10 V
0.005
100
0.00
40
50
60
70
80
90
ID - Drain Current (A)
45
60
30
Transconductance
RDS(on) vs. Drain Current
15
75
90
10
V GS - Gate-to-Source Voltage (V)
Ciss
2000
C - Capacitance (pF)
VGS = 4.5 V
1500
1000
Coss
500
Crss
ID = 21.8 A
8
VDS = 15 V
VDS = 24 V
6
4
2
12
18
24
Capacitance
30
150
90
120
60
Qg - Total Gate Charge (nC)
180
Gate Charge
服务热线:400-655-8788
3
AOD484
www.VBsemi.com
100
VGS = 10 V, ID= 38.8 A
VGS = 4.5 V, ID = 27 A
10
1.0
I S - Source Current (A)
R DS(on) - On-Resistance (Normalized)
1.2
0.8
0.6
0.4
1
T J = 150 °C
T J = 25 °C
0.1
0.01
0.2
- 50
0.001
- 25
50
75
100
125
150
0.2
0.4
0.6
0.8
1
VSD - Source-to-Drain Voltage (V)
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
Forward Diode Voltage vs. Temperature
2.8
0.005
0.004
2.4
TA = 125 °C
V GS(th) Variance (V)
RDS(on) -On-Resistance (Ω)
ID = 38.8 A
0.003
TA = 25 °C
0.002
ID = 250 µA
2.0
1.6
1.2
0.001
0.000
4
6
8
10
0.8
- 50 - 25
50
75
100
TJ - Temperature (°C)
RDS(on) vs. VGS vs. Temperature
Threshold Voltage
125 150
175
1000
*Limited by rDS (on)
100
10
10 ms
100 ms
1
1s
10 s
dc
0.1
0.01
TA = 25 °C
Single Pulse
0.001
0.1
*VGS
1
10
100
minimum VGS at which rDS(on) is specified
Safe Operating Area, Junction-to-Ambient
服务热线:400-655-8788
4
AOD484
www.VBsemi.com
300
300
250
250
Power Dissipation (W)
200
150
Package Limited
100
50
200
150
100
50
50
75
100
125
150
175
50
75
100
125
TC - Case Temperature (°C)
Current Derating*
Power Derating
150
175
*The power dissipation PD is based on TJ(max) = 175 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
1
10
Square Wave Pulse Duration (sec)
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
AOD484
www.VBsemi.com
TO-252AA CASE OUTLINE
E
MILLIMETERS
A
C2
e
b2
D1
e1
E1
L
gage plane height (0.5 mm)
L4
b
L5
H
D
L3
b3
C
A1
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
0.024
C
0.46
0.61
0.018
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
5.21
0.205
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
e1
0.090 BSC
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.14
1.52
0.045
0.060
ECN: X12-0247-Rev. M, 24-Dec-12
DWG: 5347
Note
• Dimension L3 is for reference only.
6
服务热线:400-655-8788
AOD484
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
(6.180)
0.087
(2.202)
0.090
(2.286)
0.420
(10.668)
0.243
(5.690)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
7
AOD484
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
