AOD464P
105V N-Channel MOSFET
General Description
Product Summary
The AOD464P uses advanced trench
technology and design to provide
BVDSS
RDSON
ID
105V
45mΩ
30A
excellent RDS(ON). This device is suitable
Applications
for use in high voltage synchronous
DC-DC Converters
rectification , load switching and general
Power switching application
purpose applications.
TO-252 Pin Configuration
Features
D
Low On-Resistance
Fast Switching
D
G
100% avalanche tested
S
G
TO-252
(AOD464P)
RoHS Compliant
S
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
105
V
VGS
Gate-Sou ce Voltage
±25
V
ID@TC=25℃
Continuous Drain Current
30
A
ID@TC=100℃
A
IDM
Pulsed Drain Current
90
A
EAS
Single Pulse Avalanche Energy1
324
mJ
PD@TC=25℃
Total Power Dissipation
80
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
CA01P1
Max.
Unit
R θJA
Thermal Resistance Junction-ambient (Steady-State)
Parameter
55
℃/ W
R θJC
Thermal Resistance Junction -Case (Steady-State)
1.5
℃/ W
www.cmosfet.com
Typ.
Page 1 of 2
AOD464P
Electrical Characteristics (TJ=25℃ , unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
Min.
Typ.
Max.
Unit
V
VGS=0V , ID=250uA
105
VGS=10V , ID=15A
45
VGS=6V , ID=15A
50
mΩ
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =250uA
2
4
V
IDSS
Drain-Source Leakage Current
VDS= 84V , VGS=0V , TJ=25℃
1
uA
IGSS
Gate-Source Leakage Current
VGS = ±25V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=10V , ID=15A
S
VDS=0V , VGS=0V , f=1MHz
1.5
Ω
40
8
Gate-Drain Charge
11
Turn-On Delay Time
15
Rg
Gate Resistance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Td(on)
Tr
Td(off)
Tf
VDS=50V , VGS=10V, ID=15A
Rise Time
VDS =50V , VGS=10V , RL =2.7Ω
26
Turn-Off Delay Time
RG =3Ω
38
Fall Time
30
Ciss
Input Capacitance
1700
Coss
Output Capacitance
200
Crss
Reverse Transfer Capacitance
80
VDS=25V , VGS=0V , f=1MHz
nC
ns
pF
Diode Characteristics
Symbol
IS
VSD
Min.
Typ.
Max.
Unit
Continuous Source Current
Parameter
VG=VD=0V , Force Current
Conditions
30
A
Diode Forward Voltage
VGS=0V , IS=1A , TJ=25℃
1
V
Note :
1.The test condition is VDD=30V,VGS=10V,L=0.5mH,I D=36A
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA01P1
www.cmosfet.com
Page 2 of 2
很抱歉,暂时无法提供与“AOD464P”相匹配的价格&库存,您可以联系我们找货
