HXY
AOD403-HXY
ELECTRONICS CO.,LTD
P-Channel Enhancement Mode MOSFET
HUAXUANYANG
Description
The AOD403-HXY uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
D
operation with gate voltages as low as 4.5V. This
S
device is suitable for use as a
G
Battery protection or in other Switching application.
TO252-2L
General Features
D
VDS = -30V ID =-70 A
RDS(ON) < 10mΩ @ VGS=-10V
G
Application
S
Battery protection
P-Channel MOSFET
Load switch
Uninterruptible power supply
Package Marking and Ordering Information
Product ID
AOD403-HXY
Pack
Marking
Qty(PCS)
TO252-2L
70P03 XXX YYYY
2500
Absolute Maximum Ratings (TC=25℃ unless otherwise specified)
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1,6
-70
A
ID@TC=100℃
-10V1,6
-50
A
-200
A
80
mJ
-40
A
90
W
-55 to 175
-55 to 175
℃/W
50
℃/W
1.6
℃/W
IDM
EAS
IAS
PD@TC=25℃
Pulsed Drain Current2
Single Pulse Avalanche
Energy3
Avalanche Current
Total Power
Dissipation4
TSTG
Storage Temperature Range
TJ
Operating Junction Temperature Range
RθJA
RθJC
Thermal Resistance Junction-ambient
1(t≦10S)
1(Steady
Thermal Resistance Junction-case
Shenzhen HuaXuanYang Electronics CO.,LTD
1
State)
www.hxymos.com
HXY
AOD403-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
VGS=-10V , ID=-20A
7
10
mΩ
VGS=-4.5V , ID=-15A
11
18
mΩ
VGS=VDS , ID =-250uA
-1.2
-2.5
V
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.2
Ω
Qg
Total Gate Charge (-10V)
60
Qgs
Gate-Source Charge
9
Qgd
Gate-Drain Charge
15
Td(on)
Turn-On Delay Time
17
40
55
13
3450
255
140
Tr
Td(off)
Tf
Rise Time
Turn-Off Delay Time
Fall Time
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=-15V ,
VGS=-10V
ID=-18A
VDD=-15V
VGS=-10V
RG=3.3Ω,
ID=-20A
VDS=-25V , VGS=0V , f=1MHz
uA
nC
ns
pF
Continuous Source Current1,5
VG=VD=0V , Force Current
-70
A
VSD
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
trr
Reverse Recovery Time
IF=-20A , di/dt=100A/µs ,
22
nS
72
nC
IS
Qrr
Reverse Recovery Charge
TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=-50V,VGS=-10V,L=0.1mH,IAS=-40A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation
6.The maximum current rating is package limited.
www.hxymos.com
HXY
AOD403-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source Voltage
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized -VGS(th) vs. TJ
Fig.6 Normalized RDSON vs. TJ
www.hxymos.com
HXY
AOD403-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
P DM
SINGLE
T ON
T
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching Waveform
www.hxymos.com
HXY
AOD403-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
TO252-2L Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
2.200
2.400
0.087
0.094
A1
0.000
0.127
0.000
0.005
b
0.660
0.860
0.026
0.034
c
0.460
0.580
0.018
0.023
D
6.500
6.700
0.256
0.264
D1
5.100
5.460
0.201
0.215
D2
4.830 TYP.
0.190 TYP.
E
6.000
6.200
0.236
0.244
e
2.186
2.386
0.086
0.094
L
9.800
10.400
0.386
0.409
L1
L2
2.900 TYP.
1.400
L3
0.114 TYP.
1.700
0.055
1.600 TYP.
0.067
0.063 TYP.
L4
0.600
1.000
0.024
0.039
Φ
1.100
1.300
0.043
0.051
θ
0°
8°
0°
8°
h
0.000
0.300
0.000
0.012
V
5.350 TYP.
0.211 TYP.
www.hxymos.com
HXY
AOD403-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
