AOD4130-HXY
AOD4130-HXY
    HXY(华轩阳)
    TO252
    类型:N沟道;漏源电压(Vdss):60V;连续漏极电流(Id):30A;功率(Pd):34.7W;导通电阻(RDS(on)@Vgs,Id):30mΩ@10V,15A;阈值电压(Vgs(th)@Id)...
AOD4130-HXY 数据手册
HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Description The AOD4130-HXY uses advanced trench technology to provide excellent RDS(ON), low gate charge and D operation with gate voltages as low as 4.5V. This S device is suitable for use as a G Battery protection or in other Switching application. TO252-2L General Features VDS = 60V ID =30 A PIN2 D ! RDS(ON) < 26mΩ @ VGS=10V " PIN1 G ! Application ! " " " ! PIN3 S Battery protection N-Channel MOSFET Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AOD4130-HXY TO252-2L 30N06XXXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Rating Units VDS Drain-Source Voltage 60 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current, VGS @ 10V1 30 A ID@TC=100℃ Continuous Drain Current, VGS @ 10V1 15 A ID@TA=25℃ Continuous Drain Current, VGS @ 10V1 5.6 A ID@TA=70℃ Continuous Drain Current, VGS @ 10V1 4.5 A IDM Pulsed Drain Current2 46 A EAS Single Pulse Avalanche Energy3 25.5 mJ IAS Avalanche Current 22.6 A PD@TC=25℃ Total Power Dissipation4 34.7 W PD@TA=25℃ Total Power Dissipation4 2 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG RθJA Thermal Resistance Junction-Ambient 1 62 ℃/W RθJC Thermal Resistance Junction-Case1 3.6 ℃/W Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) VGS(th) △VGS(th) Static Drain-Source On-Resistance2 Conditions Min. Typ. Max. Unit VGS=0V , ID=250uA 60 --- --- V Reference to 25℃ , ID=1mA --- 0.063 --- V/℃ VGS=10V , ID=15A --- 22 26 VGS=4.5V , ID=10A --- 30 38 1.2 --- 2.5 mΩ V mV/℃ Gate Threshold Voltage VGS(th) Temperature Coefficient VGS=VDS , ID =250uA --- -5.24 --- VDS=48V , VGS=0V , TJ=25℃ --- --- 1 VDS=48V , VGS=0V , TJ=55℃ --- --- 5 uA IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=5V , ID=15A --- 17 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 3.2 --- Ω Qg Total Gate Charge (4.5V) --- 12.6 --- Qgs Gate-Source Charge --- 3.2 --- Qgd Gate-Drain Charge --- 6.3 --- Td(on) Turn-On Delay Time --- 8 --- --- 14.2 --- --- 24.4 --- Fall Time --- 4.6 --- Ciss Input Capacitance --- 1378 --- Coss Output Capacitance --- 86 --- Crss Reverse Transfer Capacitance --- 64 --- IS Continuous Source Current1,5 --- --- 23 A --- --- 46 A --- --- 1.2 V Tr Td(off) Tf Rise Time Turn-Off Delay Time ISM Pulsed Source Current2,5 VSD Diode Forward Voltage2 VDS=48V , VGS=4.5V , ID=12A VDD=30V , VGS=10V , RG=3.3 , ID=10A VDS=15V , VGS=0V , f=1MHz VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ nC ns pF Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=22.6A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Typical Characteristics 35 12 ID=12A VGS=10V VGS=7 33 VGS=5V 8 RDSON (mΩ) ID Drain Current (A) 10 VGS=4.5V VGS=3V 6 30 4 28 2 0 25 0 0.5 1 1.5 VDS , Drain-to-Source Voltage (V) 2 2 Fig.1 Typical Output Characteristics 4 6 8 VGS (V) 10 Fig.2 On-Resistance v.s Gate-Source 12 Voltage 10 ID=12A VGS Gate to Source Voltage (V) IS Source Current(A) 10 8 6 TJ=150℃ TJ=25℃ 4 2 0 0.2 0.4 0.6 0.8 8 6 4 2 0 0 1 VSD , Source-to-Drain Voltage (V) 5 10 15 20 25 QG , Total Gate Charge (nC) Fig.3 Forward Characteristics of Reverse Fig.4 Gate-Charge Characteristics diode 2.5 Normalized On Resistance 1.5 Normalized VGS(th) 2.0 1 1.5 0.5 1.0 0.5 0 -50 0 50 100 TJ ,Junction Temperature (℃) Fig.5 Normalized VGS(th) v.s TJ Shenzhen HuaXuanYang Electronics CO.,LTD 150 -50 0 50 100 150 T J , Junction Temperature (℃) Fig.6 Normalized RDSON v.s TJ www.hxymos.com HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG 100.00 10000 F=1.0MHz 10us 100us Capacitance (pF) Ciss 10.00 1ms 1000 ID (A) 10ms 100ms 1.00 DC Coss 100 0.10 Crss TC=25℃ Single Pulse 0.01 10 1 5 9 13 17 VDS Drain to Source Voltage(V) 21 0.1 25 1 10 100 1000 VDS (V) Fig.7 Capacitance Fig.8 Safe Operating Area Normalized Thermal Response (RθJC) 1 DUTY=0.5 0.2 0.1 0.1 0.05 0.02 0.01 P DM 0.01 T ON T SINGLE D = TON/T TJpeak = TC+P DMXRθJC 0.001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance EAS= VDS 90% BVDSS 1 L x IAS2 x 2 BVDSS BVDSS-VDD VDD IAS 10% VGS Td(on) Tr Ton Td(off) Tf Toff Fig.10 Switching Time Waveform Shenzhen HuaXuanYang Electronics CO.,LTD VGS Fig.11 Unclamped Inductive Waveform www.hxymos.com HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG TO252-2L Package Information Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 2.200 2.400 0.087 0.094 A1 0.000 0.127 0.000 0.005 b 0.660 0.860 0.026 0.034 c 0.460 0.580 0.018 0.023 D 6.500 6.700 0.256 0.264 D1 5.100 5.460 0.201 0.215 D2 0.483 TYP. 0.190 TYP. E 6.000 6.200 0.236 0.244 e 2.186 2.386 0.086 0.094 L 9.800 10.400 0.386 L1 L2 2.900 TYP. 1.400 L3 0.409 0.114 TYP. 1.700 0.055 1.600 TYP. 0.067 0.063 TYP. L4 0.600 1.000 0.024 0.039 Φ 1.100 1.300 0.043 0.051 θ 0° 8° 0° 8° h 0.000 0.300 0.000 0.012 V 5.350 TYP. Shenzhen HuaXuanYang Electronics CO.,LTD 0.211 TYP. www.hxymos.com HXY AOD4130-HXY ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
AOD4130-HXY 价格&库存
很抱歉,暂时无法提供与“AOD4130-HXY”相匹配的价格&库存,您可以联系我们找货
