HXY
AOD478-HXY
ELECTRONICS CO.,LTD
N-Channel Enhancement Mode MOSFET
HUAXUANYANG
Description
The AOD478-HXY uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 4.5V. This
D
S
device is suitable for use as a
G
Battery protection or in other Switching application.
TO252-2L
General Features
VDS = 100V ID = 20A
PIN2 D
RDS(ON) < 87 mΩ @ VGS=10V
Application
PIN1 G !
Battery protection
PIN3 S
N-Channel MOSFET
Load switch
Uninterruptible power supply
Package Marking and Ordering Information
Pack
Product ID
AOD478-HXY
TO252-2L
Marking
Qty(PCS)
20N10 XXX YYYY
2500
Absolute Maximum Ratings Tc=25℃ unless otherwise noted
Symbol
Parameter
VDS
Rating
Units
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
A
ID@TC=100℃
10
A
10V1
5
A
10V1
3.4
A
30
A
6.1
mJ
ID@TA=25℃
ID@TA=70℃
IDM
EAS
Pulsed Drain
Current2
Single Pulse Avalanche
Energy3
IAS
Avalanche Current
15
A
PD@TC=25℃
Total Power Dissipation4
34.7
W
PD@TA=25℃
2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
62
℃/W
3.6
℃/W
RθJA
Thermal Resistance Junction-ambient
RθJC
Junction-Case1
Thermal Resistance
Shenzhen HuaXuanYang Electronics CO.,LTD
1
www.hxymos.com
HXY
AOD478-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△T BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
VGS=0V , ID=250uA
Min.
Typ.
Max.
Unit
100
V
Reference to 25℃ , ID=1mA
0.098
V/℃
VGS=10V , ID=10A
80
87
m
VGS=4.5V , ID=8A
95
105
m
1.0
2.5
V
-4.57
mV/℃
VDS=80V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=10A
13
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
Qg
Total Gate Charge (10V)
26.2
Qgs
Gate-Source Charge
4.6
Qgd
Gate-Drain Charge
5.1
Td(on)
Turn-On Delay Time
4.2
Tr
Td(off)
Tf
VDS=80V , VGS=10V , ID=10A
nC
Rise Time
VDD=50V , VGS=10V , RG=3.3
8.2
Turn-Off Delay Time
ID=10A
35.6
9.6
1535
60
37
Min.
Typ.
Max.
Unit
A
30
A
1.2
V
37
nS
27.3
nC
Fall Time
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source Current1,5
Pulsed Source
Current2,5
Diode Forward
Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=10A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=11A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hxymos.com
HXY
AOD478-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Typical Characteristics
25
VGS=10V
VGS=7V
ID Drain Current (A)
VGS=5V
15
VGS=4.5V
10
5
VGS=3V
4
6
VDS , Drain-to-Source Voltage (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
10
IS Source Current(A)
8
6
TJ=150℃
4
TJ=25℃
2
0.25
0.50
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics Of Reverse
diode
2.5
Normalized On Resistance
Normalized VGS(th) (V)
1.8
2.0
1.4
1.5
1
0.6
1.0
0.2
0.5
-50
100
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
150
-50
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
www.hxymos.com
HXY
AOD478-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
10000
100.00
F=1.0MHz
10us
100us
10.00
1ms
1000
ID (A)
Capacitance (pF)
Ciss
10ms
100ms
1.00
100
DC
Coss
0.10
TC=25℃
Single Pulse
Crss
10
0.01
1
5
9
13
17
21
25
0.1
1
10
VDS , Drain to Source Voltage (V)
100
1000
VDS (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
P DM
0.01
T ON
T
SINGLE
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
VGS
Fig.11 Unclamped Inductive Switching Waveform
www.hxymos.com
HXY
AOD478-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
TO-252-2L Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
2.200
2.400
0.087
0.094
A1
0.000
0.127
0.000
0.005
b
0.660
0.860
0.026
0.034
c
0.460
0.580
0.018
0.023
D
6.500
6.700
0.256
0.264
D1
5.100
5.460
0.201
0.215
D2
0.483 TYP.
0.190 TYP.
E
6.000
6.200
0.236
0.244
e
2.186
2.386
0.086
0.094
L
9.800
10.400
0.386
L1
L2
2.900 TYP.
1.400
L3
0.409
0.114 TYP.
1.700
0.055
1.600 TYP.
0.067
0.063 TYP.
L4
0.600
1.000
0.024
0.039
Φ
1.100
1.300
0.043
0.051
θ
0°
8°
0°
8°
h
0.000
0.300
0.000
0.012
V
5.350 TYP.
0.211 TYP.
www.hxymos.com
HXY
AOD478-HXY
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
