Preliminary Datasheet
LP28009
Single and Dual Cell Li+ Battery Charger IC –LP28009
General Description
Features
The LP28009 is a fully integrated low cost single-cell
and dual cell Li-Ion battery charger IC ideal for
portable applications. The LP28009 is capable of
being powered up from AC adapter. The LP28009
enters sleep mode when AC adapter is removed. The
LP28009 optimizes the charging task by using a
control algorithm including preconditioning mode, fast
charge mode and constant voltage mode. The
charging task is terminated as the charge current
drops below the preset threshold. The AC adapter
charge current can be programmed up to 1.2A with
an external resister. The internal thermal feedback
circuitry regulates the die temperature to optimize the
charge rate for all ambient temperatures. The
LP28009 features 18V maximum rating voltages for
AC adapter. The other features are under voltage
protection, over voltage protection for AC adapter
supply and battery temperature monitoring.
18V Maximum Rating for AC Adapter
Internal Integrate P-MOSFETs
AC Adapter Power Good Status Indicator
Charge Status Indicator
Under Voltage Protection
Over Voltage Protection
Automatic Recharge Feature
Battery Temperature Monitoring
Small 8-Lead SOP(EP) Package
Thermal Feedback Optimizing Charge Rate
ROHS Compliant and 100% Lead (Pb)-Free
Marking Information
Device
Marking
LP28009
Package
Shipping
SP:SOP-8
3K/REEL
Order Information
LP28009 □ □
F: Pb-Free
Package Type
Typical Application Circuit
VIN
1
SP: SOP-8(EP)
RED
Output Voltage
2
3
4
42: 4.2V
10uF
9
84: 8.4V
ACIN
CHRG_S
BATT
NC
8
7
10uF
PGOOD
GND
GND
ISETA
EN
5
BATTERY
6
LP28009-42SPF
I/O CTRL
Q1
LPM9013
Applications
Portable Media Players/MP3 players
Cellular and Smart mobile phone
PDA/DSC
Bluetooth Applications
VIN
1
RED
2
3
4
10uF
9
ACIN
CHRG_S
BATT
NC
8
7
10uF
PGOOD
GND
ISETA
GND
EN
BATT
5
6
LP28009-84SPF
I/O CTRL
Q8
LPM9013
LP28009 – 02
May.-2013
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 12
LP28009
Functional Pin Description
P ac k age T y pe
P in C onf ig ur ati ons
ACIN 1
8 BATT
CHG_S 2
ESOP- 8
9
PGOOD 3
PGND
7
NC
6
EN
5 ISETA
GND 4
Pin Description
P in N o
P in N ame
P in F unc tion
1
AC I N
2
C H G_ S
C har ge Status Indic ator O utput(O pen Dr ain) .
3
PG O OD
Pow er G ood Indic ator O utput( O pen dr ain) .
4
GND
5
I SET A
6
EN
C har ge E nable Input( ac tiv e low ) .
7
NC
N o I nter nal C onnec tion.
Wall Ad aptor C har ge Input Supply .
G r ound.
Wall Adaptor s upply c har ge c urr ent Set point.
Bat t er y C har ge C ur r ent O utput.
T his pin pr ov ides c har ge c ur r ent to the battery and
8
BAT T
r egulates the final float v oltage to 4.2 or 8.4V. An
int er nal pr ec is ion r es istor div ider fr om this pin s ets the
f loat v oltage w hic h is disc onnec ted i n s hutdow n mode.
9
( Ex pos ed
Ex pos ed Pad Should be s older ed to PC B Boar d and
PG N D
C onnec ted to G N D .
Pad)
Note: LP28009-42SPF and LP28009-84SPF of
LP28009 – 02
May.-2013
Battery (Pin8) is output pin, the pin connector to Battery.
Page 2 of 12
LP28009
Function Block Diagram
LP28009 – 02
May.-2013
Page 3 of 12
LP28009
LP28009-42 Flow Chart
LP28009
LP28009 – 02
May.-2013
Page 4 of 12
LP28009
Absolute Maximum Ratings
VIN, VBATT, VCHGSB, VPGOOD, VEN
-0.3V to 15V
Storage Temperature Range------------------------------------------------------------------------------------ -65℃ to 150℃
VISETA
-0.3V to 3.6V
Junction Temperat ure (TJ) ---- ---------------- ----------------- ------------ ------------------------ ---- 150℃
Lead Temperature (soldering,10 sec.) --------------------------------------------------------------------------------------
260℃
Operating Ratings
Supply Voltage
--------------------------------------------------------------------------------------------------------------- 9V to 13.5V
Thermal Resistance(θJA) ------------------------------------------------------------------------------------------------------- 46℃/W
Operating Temperature Range
-------------------------------------------------------------------------------------- -40℃ to 85℃
Electrical Characteristics
(TA=25℃, VIN=10V; unless otherwise specified.)
Symbol
VIN
Icc
Parameter
Input
Operating
Conditions
Voltage
Range
Input Supply Current
Min
Typ
Max
Units
9
10
13.5
V
Charge Mode.RSET=30K
300
uA
Standby Mode (Charge Terminated)
250
UA
190
uA
Shutdown Mode
(RSET Not
Connected VIN < VBATT or VIN
Vuv)
VFLOAT
Regulated
Output(Float)
0℃ ≤ TA ≤ 85℃
8.316
Voltage
RSET=1.5k,Current
Mode
RSET=0.75k,Current Mode
IBATT
ITRICKLE
VTRICKLE
VTRHYS
VMSD
VASD
LP28009 – 02
BATT Pin Current
Trickle Charge Current
Trickle Charge Threshold
8.484
V
500
mA
1000
mA
Standby Mode, VBATT=8.4V
-1
uA
Shutdown Mode
-1
uA
Sleep Mode, VIN=0V
-1
uA
VBATT
很抱歉,暂时无法提供与“LP28009-84SPF”相匹配的价格&库存,您可以联系我们找货
