LP3351
Preliminary Datasheet
PWM Dimming Control for LED Driver
General Description
Features
LP3351 is a cost effective LED driver optimized for
LCD monitor and LCD TV backlighting application. It
provides a high performance LED backlight solution
with minimized bill of material count.
The LP3351 contains a PWM boost driver which
uses current mode control and fixed frequency
operation to regulate the LED current. The LED
current is sensed through an external current sense
resistor. The voltage across the sensing resistor is
compared with reference level of 0.21V, the error
amplified to control the pulse width of the power
switch thus to regulate the current flowing the LED.
Otherwise, The LP3351 offers external frequency
PWM dimming method for a wide range of dimming
control.
Other features include over current protection (OCP),
output over voltage protection (OVP), and
under-voltage lockout (UVLO). The
LP3351 is
available in a space saving SOP-8 (0.5mm pitch)
package.
Order Information
LP3351 □□□
LP3351
Wide VIN Range: 8V to 28V
Current-Mode PWM Controller
External PWM Dimming Mode
Under-Voltage Lockout
Over Voltage Protection
Over Current Protection
Under-Voltage Protection
Over-Temperature Protection
Available in SOP-8
RoHS Compliant and Halogen Free
Pb-Free Package
Applications
TFT LCD TV
TFT LCD Monitor
Flat Panel Display
Marking Information
Device
Marking
Package
Shipping
LP3351
LPS
SOP-8
3K/REEL
LP3351
F: Green
Package Type
SO: SOP-8
Version 0.3 MAR-2018
YWX
Y: Y is year code. W: W is week code. X: X is series number.
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 7
LP3351
Typical Application Circuit
L1
68uH
VIN
C1
220uF
R1
10Ω
C2
10uF
EN /
PWM
VIN
GATE
OVP
CS
GND
CTRL
V+
R2
200kΩ
R5
0Ω
C3
47uF
R6
1kΩ
R3
R7
10kΩ
0.18Ω
FB
COMP
LP3351
V-
R8
100Ω
Rcomp
47kΩ
R9
2Ω
Ccomp
33nF
Figure 1. Typical Application Circuit of LP3351
Pin Configuration
GATE
1
8
VIN
GND
2
7
CTRL
CS
3
6
COMP
OVP
4
5
FB
Figure 2. SOP-8 Package Top View
LP3351
Page 2 of 7
LP3351
Function Block Diagram
FB
COMP
EA and
Comp.
Internal
Regulator
VIN
UVLO
Control
Logic
EN / PWM
OVP OCP
OSC OTP
CTRL
OVP
CS
GATE
Gate
Driver
GND
Figure 3. Function Block Diagram
Functional Pin Description
Pin NO.
Pin Name
1
GATE
External NMOS Gate Drive Pin.
2
GND
Ground.
3
CS
LP3351
Description
Current Sense Input Pin.
4
OVP
Over Voltage Protection Sense Input. Connect to an external resistive voltage divider
from the V+ to GND.
5
FB
Regulator Feedback Input. Connect to an external resistive to set the output current.
6
COMP
Regulator Error Amplifier Compensation Pin.
7
CTRL
Enable and External PWM Dimming Control.
8
VIN
Input Supply Pin. Decouple with 10μF ceramic capacitor close to the pin.
Page 3 of 7
LP3351
Absolute Maximum Ratings Note 1
VIN to GND -------------------------------------------------------------------------------------------------------- −0.3V to +36V
GATE, CS, FB, COMP, OVP, CTRL to GND ------------------------------------------------------------- −0.3V to +20V
Operating Junction Temperature Range (TJ)
Operation Ambient Temperature Range -------------------------------------------------------------- −20°C to +85°C
Storage Temperature Range ---------------------------------------------------------------------------- −65°C to +150°C
Maximum Soldering Temperature (at leads, 10sec) ----------------------------------------------- +260°C
Maximum Junction Temperature ----------------------------------------------------------------------- +150°C
------------------------------------------------------ −40℃ to +150℃
Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of
the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Thermal Resistance
SOP-8, θJA ---------------------------------------------------------------------------------------------------- 112°C/W
SOP-8, θJC ---------------------------------------------------------------------------------------------------- 39°C/W
LP3351
Page 4 of 7
LP3351
Electrical Characteristics
(VIN=12V, VCTRL=5V, TA=25°C, unless otherwise specified)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Units
28
V
General
Input Supply Voltage
VIN Supply Current
VVLI
8
Sleep Current
310
400
uA
Operation Current
2.5
3
mA
7
8
V
IQ
Input UVLO Threshold
VUVLO(VTH)
V IN Rising
UVLO Threshold Hysteresis
VUVLO(HYS)
Falling Hysteresis
Thermal Shutdown Threshold
TSD
Thermal Shutdown Hysteresis
∆TSD
Temperature Rising
6
500
140
160
mV
180
°C
°C
PWM
Internal Oscillator Frequency
FOSC
175
VIH
Logic High.
VIL
Logic Low
200
225
kHz
2.6
V
PWM Threshold Voltage
Pull Down Resistor
1
RPull_Low
150
kΩ
Error Amplifier
Reference voltage at
non-inverting input.
Reference Voltage
VREF
Open Loop Voltage Gain
Am
Transconductance of EA
Gm
80
100
120
uA/V
ISource
24
30
36
uA
ISink
48
60
72
uA
1.8
2
2.2
V
Output Source Current
Output Sink Current
-1.5%
0.21
+1.5%
70
V
dB
Protection Threshold
VOVP
Threshold of OVP
VOCP
Threshold of OCP
(duty=90%)
330
mV
50
ms
1
ms
Normal Operation
0.2
V
System Startup
100
mV
Fault Trigger Duration
Connect detect time
SCP Threshold
LP3351
Tdet
VOVP_UV
Page 5 of 7
LP3351
Application Information
Over Temperature Protection
The LP3351 device enters over temperature
protection(OTP) if its junction temperature exceeds
160°C (Typ.). During over temperature protection
none of the device's functions are available. To
resume normal operation the junction temperature
need cool down, and the outputs will restart.
LP3351
Layout Guideline
The proper PCB layout and component placement are
critical for all circuit. The careful attention should be
prevent electromagnetic interference (EMI) problems.
Here are some suggestions to the layout of LP3351
design.
1. Connected all ground together with one
uninterrupted ground plane with at least two vias .
2. The input capacitor should be located as closed as
possible to the VIN and ground plane.
3. Minimize the distance of all traces connected to the
LX node, that the traces short and wide route to obtain
optimum efficiency.
4. All output capacitor must be closed to ground
plane. The ground terminal of COUT must be located
as closed as possible to ground plane.
5. Radiated noise can be decreased by choosing a
shielded inductor.
VIN
V+
Diode
L
G
Rin
GND
S
1
8
2
7
LP3351
6
5
4
GND
R2
R3
Cin
3
COUT
Boost Loop Compensation
The feedback loop can be compensated with an
external compensation network consisted of Rcomp,
Ccomp(As Figure 1). Choosing Rcomp to set high
frequency integrator gain for fast transient response
and Ccomp to set the integrator zero to maintain loop
stability.
The LP3351 converter has an over voltage protection
by OVP pin. When the LEDs fail open circuit or LEDs
are disconnected from the circuit, the over voltage
function will monitor the output voltage through OVP
pin to protect the converter. When LP3351 occur
OVP, it will latch off until VIN is re-startup or CTRL
input is recycled.
LED Current Setting
The LED current is specified by current sense resistor
between the FB pin to ground. In order to have
accurate LED current, precision resistors are
preferred. The LED current can be programmed by:
ILED=0.21/RFB
Dimming Control
The LED brightness is controlled by the PWM signal
at CTRL pin which has different duty cycle. LP3351
can accept an external PWM signal to CTRL pin in the
range of 100Hz to 1 kHz.
Current Sense and Over Current Protection (OCP)
The over current protection level can be set by R7(As
Figure 1) and senses inductor current to compare with
current limit value. When the inductor current exceeds
the current limit, the switching will turns off
immediately. It prevents large current damaging the
external component. The OCP level is calculated as:
IOCP=0.33/R7
The LP3351 uses a current mode control structure.
The CS pin not only has current sense function but
also build-in a slope compensation to avoid
sub-harmonic
oscillation.
Additional
slope
compensation lessened the influence of the sensed
current in the control loop.
CIN
The LP3351 is designed in a current mode, constant
frequency PWM boost converter. It can use dimming
input that can by external control signal with a duty
ratio of 1%-100% in 100Hz to 1kHz. LP3351 offers
protection features to protect the system such as
output over voltage protection, boost diode
disconnection protection, output short circuit
protection and over temperature protection.
Under Voltage Lockout (UVLO)
The LP3351 had an UVLO internal circuit that enable
the device once the voltage on the VIN voltage
exceeds the UVLO threshold voltage.
Boost Controller
The LP3351 uses 200kHz fixed-frequency, current
mode architecture to fixed the output current. The
output voltage and soft start time can be adjustable by
internal register.
R6
R7
RComp
CComp
GND
R8
RFB
V-
Figure 4. Recommended PCB Layout Diagram
Page 6 of 7
LP3351
Outline Information
SOP-8 Package (Unit: mm)
D
LPS
LP3351
YWX
E
E1
1
b
DIMENSION IN MILLIMETER
SYMBOLS
UNIT
MIN
NOM
MAX
A
1.750
A1
0.100
0.225
A2
1.300
1.400
1.500
A3
0.600
0.650
0.700
b
0.390
0.470
D
4.800
4.900
5.000
E
5.800
6.000
6.200
E1
3.800
3.900
4.000
e
e
L
1.27BSC
0.500
0.800
A3
A1
A
A2
L
LP3351
Page 7 of 7
很抱歉,暂时无法提供与“LP3351SOF”相匹配的价格&库存,您可以联系我们找货
