HSW6800
Dual N-CH Fast Switching MOSFETs
Description
Product Summary
The HSW6800 is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSW6800 meet the RoHS and Green Product
requirement with full function reliability approved.
VDS
30
V
RDS(ON),max
45
mΩ
ID
4
A
SOT23-6L Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±12
V
ID@TA=25℃
Continuous Drain Current, VGS @ 4.5V1
4
A
ID@TA=70℃
3
A
IDM
Pulsed Drain Current2
16
A
PD@TA=25℃
Total Power Dissipation3
1.4
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient 1
www.hs-semi.cn
Ver2.0
Typ.
Max.
Unit
90
℃/W
1
HSW6800
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.029
V/℃
VGS=4.5V , ID=4A
32
45
VGS=2.5V , ID=3A
45
60
0.6
0.9
1.3
V
-2.82
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=2A
5
S
Qg
Total Gate Charge (4.5V)
9.5
Qgs
Gate-Source Charge
1.6
Qgd
Gate-Drain Charge
3
Td(on)
VDS=15V , VGS=4.5V , ID=4A
3.2
Rise Time
VDD=15V , VGS=4.5V , RG=3.3
4.9
Turn-Off Delay Time
ID=3A
22
Fall Time
4
Ciss
Input Capacitance
880
Coss
Output Capacitance
99
Crss
Reverse Transfer Capacitance
73
Min.
Typ.
Max.
Unit
4
A
16
A
1.2
V
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current1,4
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver2.0
2
HSW6800
Typical Characteristics
55
16
ID=3A
VGS=5V
14
50
VGS=3V
VGS=2.5V
10
RDSON (mΩ)
ID Drain Current (A)
VGS=4.5V
12
45
8
40
6
VGS=1.8V
4
35
2
30
0.4
0.6
0.8
VDS , Drain-to-Source Voltage (V)
2.5
Fig.1 Typical Output Characteristics
7.5
10
Fig.2 On-Resistance vs. Gate-Source
Voltage
6
IS Source Current(A)
5
VGS (V)
4
TJ=150℃
TJ=25℃
2
0.6
0.9
VSD , Source-to-Drain Voltage (V)
1.2
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics Of Reverse
diode
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver2.0
3
HSW6800
1000
100.00
Ciss
100us
10ms
ID (A)
Capacitance (pF)
10.00
100
100ms
1.00
Coss
1s
Crss
0.10
DC
TA=25℃
Single Pulse
F=1.0MHz
10
1
4
7
10
13
16
19
0.01
22
0.1
VDS , Drain to Source Voltage (V)
1
Fig.7 Capacitance
VDS (V)
10
100
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TA + PDM x RθJA
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver2.0
4
HSW6800
SOT23-6L Package Outline Dimensions
www.hs-semi.cn
Ver2.0
5
很抱歉,暂时无法提供与“HSW6800”相匹配的价格&库存,您可以联系我们找货
