HSW8810
Dual N-Ch Fast Switching MOSFETs
Description
Product Summary
The HSW8810 is the low RDSON trenched N-CH
MOSFETs with robust ESD protection. This
product is suitable for Lithium-ion battery pack
applications.
The HSW8810 meet the RoHS and Green Product
requirement with full function reliability approved.
Green Device Available
Super Low Gate Charge
ESD Protection
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
VDS
V
RDS(ON),max
mΩ
ID
6
A
SOT23-6L Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
ID@TA=25℃
Continuous Drain Current1
6
A
ID@TA=70℃
4.8
A
IDM
Pulsed Drain Current2
24
A
PD@TA=25℃
Total Power Dissipation3
1.25
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient 1
www.hs-semi.cn
Ver 2.0
Typ.
Max.
Unit
100
℃/W
1
HSW8810
N-Channel Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
VGS(th)
Parameter
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
VGS=4.5V , ID=3A
15
16.5
VGS=4.0V , ID=3A
15.5
17
20.5
VGS=3.7V , ID=3A
16
17.5
21
VGS=3.1V , ID=3A
17
18.5
23
VGS=2.5V , ID=3A
18.5
21
26
VGS=VDS , ID =250uA
0.5
0.7
1.2
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
m
V
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±10
uA
gfs
Forward Transconductance
VDS=5V , ID=3A
17
S
Qg
Total Gate Charge
10.4
1.3
VDS=15V , VGS=4.5V , ID=6A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
2.6
Turn-On Delay Time
3.2
Td(on)
uA
nC
Rise Time
VDD=10V , VGS=4.5V , RG=3.3
9.8
Turn-Off Delay Time
ID=3A
31
Fall Time
3.6
Ciss
Input Capacitance
630
Coss
Output Capacitance
66
Crss
Reverse Transfer Capacitance
63
Min.
Typ.
Max.
Unit
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,4
VG=VD=0V , Force Current
5.5
A
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
0.78
1.2
V
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper, t ≤10s.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSW8810
N-Channel Typical
Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source voltage
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-Charge Characteristics
diode
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSW8810
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
P DM
0.01
T ON
T
SINGLE
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
HSW8810
SOT23-6L Package Outline Dimensions
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSW8810”相匹配的价格&库存,您可以联系我们找货
