KYL3401
KYL3401
    KY(韩景元)
    SOT23-3
    类型:P沟道;漏源电压(Vdss):30V;连续漏极电流(Id):4.2A;功率(Pd):1.7W;导通电阻(RDS(on)@Vgs,Id):48mΩ@10V,4A;
KYL3401 数据手册
ShenZhen HanKingYuan Electronic Co.,Ltd KYL3401 30V P-Channel Mosfet SOT-23-3L FEATURES ● RDS(ON) ≤ 60mΩ( 48mΩ Typ.) @VGS=-10V ● RDS(ON) ≤ 78mΩ( 57mΩ Typ.) @VGS=-4.5V 1. GATE ● RDS(ON) ≤ 112mΩ( 77mΩ Typ.) @VGS=-2.5V 3. DRAIN 2. SOURCE APPLICATIONS ● Load Switch ● PWM Applications ● Power Management MARKING P-CHANNEL MOSFET 3401X Other marks: "X1YV 17 X: Date Code " MAXIMUM RATINGS (Ta=25°C unless otherwise noted) Symbol Parameter Max. Units VDSS Drain-Source Voltage -30 V VGSS Gate-Source Voltage ±12 V -4.2 -2.7 A A -30 A Ta= 25℃ Ta= 100℃ ID Continuous Drain Current IDM Pulsed Drain Current PD Power Dissipation 1.7 W Thermal Resistance, Junction to Ambient 76.2 ℃/W -55 to +150 ℃ RθJA TJ,TSTG note1 Operating and Storage Temperature Range www.scr-ky.com 1/5 ShenZhen HanKingYuan Electronic Co.,Ltd KYL3400 MOSFET ELECTRICAL CHARACTERISTICS Ta=25 °C unless otherwise specified Symbol Parameter Test Condition Min. Typ. Max. Units Off Characteristic V(BR)DSS Drain-Source Breakdown Voltage VGS=0V, ID=-250μA -30 - - V IDSS Zero Gate Voltage Drain Current VDS=-30V, VGS=0V, - - -1.0 μA IGSS Gate to Body Leakage Current VDS=0V, VGS= ±12V - - ±100 nA VDS=VGS, ID=-250μA -0.6 -0.9 -1.3 V VGS= -10V, ID= -4A - 48 60 VGS= -4.5V, ID= -3A - 57 78 VGS= -2.5V, ID= -1A - 77 112 - 880 - pF - 105 - pF - 65 - pF - 8.5 - nC - 1.8 - nC - 2.7 - nC - 7 - ns - 3 - ns - 20 - ns - 12 - ns On Characteristics VGS(th) RDS(on) Gate Threshold Voltage Static Drain-Source on-Resistance note2 mΩ Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain(“Miller”) Charge VDS= -15V, VGS=0V, f=1.0MHz VDS= -15V, ID= -4.2A, VGS= -10V Switching Characteristics td(on) Turn-on Delay Time tr Turn-on Rise Time td(off) Turn-off Delay Time tf VDD= -15V, ID= -1A, VGS= -10V, RGEN=2.5Ω Turn-off Fall Time Drain-Source Diode Characteristics and Maximum Ratings IS Maximum Continuous Drain to Source Diode Forward Current - - -4.2 A ISM Maximum Pulsed Drain to Source Diode Forward Current - - -30 A VSD Drain to Source Diode Forward Voltage - -0.8 -1.2 V VGS=0V, IS=-4.2A Notes:1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature 2. Pulse Test: Pulse Width≤300μs, Duty Cycle≤2% www.scr-ky.com 2/5 ShenZhen HanKingYuan Electronic Co.,Ltd KYL3400 TYPICAL PERFORMANCE CHARACTERISTICS Figure 2: Typical Transfer Characteristics Figure1: Output Characteristics -ID (A) 25 25 10V -ID (A) TA=-55℃ 4.5V 20 20 25℃ 15 15 125℃ 2.5V 10 10 5 5 2 4 -V GS (V) V GS=1.5V -V DS (V) 0 0 6 8 10 1.0 1.5 2.0 2.5 Figure 4: Body Diode Characteristics Figure 3:On-resistance vs. Drain Current 100 0 0 .5 R DS(ON) (mΩ) -IS (A) 10 V GS =-2.5V 80 TJ=150℃ VGS =-4.5V 60 40 TJ=-50℃ TJ=-25℃ 1 V GS =-10V 20 -ID(A) 0 0 1 2 3 4 5 Figure 5: Gate Charge Characteristics 0.1 0.0 0.4 VSD(V) 0.6 0.8 1.0 1.2 1.4 Figure 6: Capacitance Characteristics -V GS (V) 10 0.2 C(pF) VDS =-15V ID=-4.2A 8 Ciss 103 6 4 Coss 102 Crss 2 0 0 Q g(nC) 2 www.scr-ky.com 4 6 8 10 101 0 -V DS (V) 5 10 15 20 25 30 3/5 ShenZhen HanKingYuan Electronic Co.,Ltd KYL3400 TYPICAL PERFORMANCE CHARACTERISTICS (cont.) Figure 7: Normalized Breakdown Voltage vs. Junction Temperature Figure 8: Normalized on Resistance vs. Junction Temperature RDS(on) VBR(DSS) 2.5 1.3 1.2 2.0 1.1 1.5 1.0 1.0 0.9 Tj (℃) 0 -100 -50 0 50 100 150 200 Figure 9: Maximum Safe Operating Area Tj (℃ ) -50 0 50 100 150 200 Figure 10: Maximum Continuous Drain Current vs. Ambient Temperature -ID(A) 102 0.5 -100 5 -ID(A) 4 1 10 10μs 3 100μs 2 Limited by RDS(on) 0 10 1ms TA=25℃ Single pulse 10-1 0.1 1 1 DC -VDS (V) 10 0 100 0 25 50 T A ( ℃) 75 100 125 150 Figure.11: Maximum Effective Transient Thermal Impedance, Junction-to-Ambient 102 ZthJ-A(℃ /W) 101 100 PDM D=0.5 t1 D=0.2 D=0.1 t2 D=0.05 D=0.02 D=0.01 Notes: Single pulse 1.Duty factor D=t1/t2 2.Peak TJ=P DM*ZthJA+TA TP(s) 10-1 10-2 -4 10 10-3 10-2 www.scr-ky.com 10-1 100 101 102 4/5 ShenZhen HanKingYuan Electronic Co.,Ltd KYL3400 SOT-23-3L PACKAGE OUTLINE DRAWING Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 e e1 0.950 TYP. 1.800 L L1 θ www.scr-ky.com 2.000 0.071 0.700 REF. 0.300 0° 0.116 0.037 TYP. 0.079 0.028 REF. 0.600 8° 0.012 0° 0.024 8° 5/5
KYL3401 价格&库存
很抱歉,暂时无法提供与“KYL3401”相匹配的价格&库存,您可以联系我们找货
