ShenZhen HanKingYuan Electronic Co.,Ltd
KY2305A
-20V P-Channel Mosfet
FEATURES
SOT-23
● RDS(ON) ≤ 45mΩ( 35mΩ Typ.)
@VGS=-4.5V
● RDS(ON) ≤ 70mΩ( 38mΩ Typ.)
@VGS=-2.5V
● RDS(ON) ≤ 90mΩ( 50mΩ Typ.)
@VGS=-1.8V
APPLICATIONS
● Load Switch for Portable Devices
● DC/DC Converter
MARKING
P-CHANNEL MOSFET
S5
Other marks: "2305 " or " S5B "
Maximum ratings (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage
-20
VGS
Gate-Source Voltage
±12
ID
Continuous Drain Current
-4.1
IDM
Pulsed Drain Current
-16
PD
Maximum Power Dissipation
0.83
W
Thermal Resistance from Junction to Ambient(t ≤5s)
150
℃/W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55 ~+150
RθJA
www.scr-ky.com
V
A
1/6
KY2305A
MOSFET ELECTRICAL CHARACTERISTICS Ta=25 ℃ unless otherwise specified
Symbol
Parameter
Test Condition
Min
Typ
Max
Units
Static
V(BR)DSS
Drain-source breakdown voltage
VGS = 0V, ID =-250µA
-20
-21.5
VGS(th)
Gate-source threshold voltage
VDS =VGS, ID =-250µA
-0.4
-0.7
IGSS
Gate-source leakage
VDS =0V, VGS =±10V
±100
nA
IDSS
Zero gate voltage drain current
VDS =-16V, VGS =0V
-1
µA
RDS(on)
VSD
Drain-source on-state
resistance note1
Body diode voltage
-1
VGS =-4.5V, ID =-3.5A
35
45
VGS =-2.5V, ID =-3A
38
70
VGS =-1.8V, ID =-2A
50
90
IS=-3.3A
-0.9
-1.2
V
mΩ
V
Dynamicnote2
Ciss
Input capacitance
Coss
Output capacitance
Crss
Reverse transfer capacitance
Qg
Total gate charge
Qgs
Gate-source charge
Qgd
Gate-drain charge
td(on)
Turn-on delay time
tr
Rise time
td(off)
tf
Turn-off delay time
Fall time
740
VDS =-4V,VGS =0V,f =1MHz
pF
290
190
VDS=-4V,VGS=-2.5V
ID=-4.1A
VDS=-4V,
RL=1.2Ω, ID =-3.3A,
VGEN=-4.5V,RG=1Ω
4.5
9
nC
1.2
1.6
13
53
32
48
10
nS
Notes: 1. Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
2 . Guaranteed by design, not subject to production testing.
www.scr-ky.com
2/6
KY2305A
Typical Performance Characteristics
Figure1. Output Characteristics
Figure2. Transfer Characteristics
Figure3. Rdson-Drain Current
Figure4. Typical Source-Drain Diode Forward
Voltage
Figure5. Capacitance Characteristics
Figure6. Gate Charge
www.scr-ky.com
3/6
KY2305A
Typical Performance Characteristics (cont.)
Figure7. Normalized Breakdown Voltage vs.
Temperature
Figure9. Safe Operation Area
www.scr-ky.com
Figure8. Normalized on Resistance vs.
Temperature
Figure10. Drain Current vs. Case Temperature
4/6
KY2305A
SOT-23 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min
Max
Dimensions In Inches
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
2.000
0.071
e
e1
0.950 TYP
1.800
L
0.037 TYP
0.550 REF
0.022 REF
L1
0.300
0.500
0.012
θ
0°
8°
0°
www.scr-ky.com
0.079
0.020
8°
5/6
KY2305A
SOT-23 Embossed Carrier Tape
www.scr-ky.com
6/6
很抱歉,暂时无法提供与“KY2305A”相匹配的价格&库存,您可以联系我们找货
