S9014
S9014
NPN Transistors
General description
SOT-23 Plastic-Encapsulate Transistors
FEATURES
Complementary to S9015
Power Dissipation of 200mW
High Stability and High Reliability
MECHANICAL DATA
SOT-23 Small Outline Plastic Package
Epoxy UL: 94V-0
Mounting Position: Any
Marking: J6
Maximum Ratings & Thermal Characteristics
TA = 25°C unless otherwise noted
Parameters
Collector-Base Voltage
Collector-Emitter Voltage
Emitter -Base Voltage
Collector Current-Continuous
Collector Power Dissipation
Junction Temperature
Storage Temperature
Thermal resistance From junction to ambient
Electrical Characteristics
Symbol
VCBO
VCEO
VEBO
IC
PC
Tj
Tstg
RθJA
Symbols
Collector-base breakdown voltage
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
Collector cut-off current
Emitter cut-off current
DC current gain
Collector-emitter saturation voltage
Base -emitter saturation voltage
Transition frequency
Test Condition
Limits
Min
Max
50
V(BR)CBO
IC=100uA, IE=0
V(BR)CEO
IC=0.1mA, IB=0
45
V(BR)EBO
ICEO
IE=100uA, IC=0
VCE=20V, IB=0
5
ICBO
VCB=40V, IE=0
IEBO
VEB=5V, IC=0
V
V
100
V
nA
100
nA
100
nA
VCE=1V, IC=100mA
hFE(2)
VCE=1V, IC=800mA
VCE(sat)
IC=800mA, IB=80mA
VBE(sat)
IC=800mA, IB=80mA
150
V
VCE=10V, IC=50mA,f=30MHz
50
MHz
fT
L
200-450
H
450-1000
200
Unit
hFE(1)
CLASSIFICATION OF hFE(1)
www.doeshare.net
Unit
V
V
V
mA
mW
℃/W
Parameter
RANK
RANGE
Value
50
45
5
100
200
150
-55-+150
625
1000
0.30
1.00
V
S9014
Typical characteristics
www.doeshare.net
S9014
SOT-23 PACKAGE OUTLINE Plastic surface mounted package
Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs
www.doeshare.net
S9014
Important Notice and Disclaimer
DOESHARE has used reasonable care in preparing the information included in this
document, but DOESHARE does not warrant that such information is error free.
DOESHARE assumes no liability whatsoever for any damages incurred by you
resulting from errors in or omissions from the information included herein.
DOESHARE no warranty, representation or guarantee regarding the documents,
circuits and products specification, DOESHARE reservation rights to make changes
for any documents, products, circuits and specifications at any time without notice.
Purchasers are solely responsible for the choice, selection and use of the
DOESHARE products and services described herein, and DOESHARE assumes no
liability whatsoever relating to the choice, selection or use of the products and
services described herein.
No license, express or implied, by implication or otherwise under any intellectual
property rights of DOESHARE.
Resale of DOESHARE products with provisions different from the statements
and/or technical features set forth in this document shall immediately void any
warranty granted by DOESHARE for the DOESHARE product or service described
herein and shall not create or extend in any manner whatsoever, any liability of
DOESHARE.
www.doeshare.net
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
