S9012
S9012
    DOESHARE(德芯)
    SOT-23
    晶体管类型:-;集射极击穿电压(Vceo):-;集电极电流(Ic):-;功率(Pd):-;集电极截止电流(Icbo):-;集电极-发射极饱和电压(VCE(sat)@Ic,Ib):-;特征频率(fT):...
S9012 数据手册
S9012 S9012 PNP Transistors General description SOT-23 Plastic-Encapsulate Transistors FEATURES • Complementary to S9013 • Power Dissipation of 300mW • High Stability and High Reliability MECHANICAL DATA • SOT-23 Small Outline Plastic Package • Epoxy UL: 94V-0 • Mounting Position: Any Marking: 2T1 Maximum Ratings & Thermal Characteristics Characteristic TA = 25°C unless otherwise noted Symbol Rating Unit Collector-Base voltage VCBO -40 Vdc Collector-Emitter Voltage VCEO -30 Vdc Emitter-Base voltage VEBO -5.0 Vdc Collector Current-Continuous Ic -500 mAdc Base-Current IB -50 mAdc Collector Power Dissipation PC 300 mW Junction Temperature Tj 150 ℃ Tstg -55〜150 ℃ Storage Temperature Range www.doeshare.net S9012 Electrical Characteristics TA = 25°C unless otherwise noted Characteristic Collector Cutoff Current Emitter Cutoff Current Collect-Base Breakdown Voltage Collect-Base Breakdown Voltage Emitter-Base Breakdown Voltage Symbol Test Condition Min TYP Max Unit ICBO VCB= -35V,IE=0 — — -0.1 μA IEBO VEB= -5V,IC=0 — — -0.1 μA V(BR)CBO IC= -100μA -40 — — V V(BR)CEO IC= -1.0mA -30 — — V V(BR)EBO IE= -100μA -5 — — V hFE(1) VCE= -1V, IC= -100mA 70 — 400 hFE(2) VCE= -6V, IC= -400mA 25 — — VCE(sat) IC= -500mA, IB= -50mA — — -0.6 V VBE VCE= -1V, IC= -100mA — -0.8 -1.0 V fT VCE= -6V, IC= -20mA 150 300 — MHz VCB= -6V,IE=0, f=1MHz — 7.0 10 pF DC Current Gain Collector-Emitter Saturation Voltage Base-Emitter Saturation Voltage Transition Frequency Collector Output Capacitance CLASSIFICATION OF hFE(1) www.doeshare.net Cob — S9012 Typical characteristics www.doeshare.net S9012 SOT-23 PACKAGE OUTLINE Plastic surface mounted package Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs www.doeshare.net S9012 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
S9012 价格&库存
很抱歉,暂时无法提供与“S9012”相匹配的价格&库存,您可以联系我们找货
