KIA
5A,500V
N-CHANNEL MOSFET
5N50H
SEMICONDUCTORS
1. Features
n
RDS(on)=1.25Ω(typ) @Vgs=10V
n
RoHS compliant
n
Low on resistance
n
Low gate charge
n
Peak current vs pulse width curve
2. Applications
n
Adaptor
n
Charger
n
SMPS standby power
3.Symbol
1 of 8
Pin
Function
1
Gate
2
Drain
3
Source
Rev 1.1 JUN 2017
KIA
5A,500V
N-CHANNEL MOSFET
5N50H
SEMICONDUCTORS
4. Absolute maximum ratings
Parameter
(note*1)
Drain-source voltage
Continuous drain current
(note*2)
Pulsed drain current,VGS@10V
Symbol
Rating
Units
VDSS
500
V
ID
5.0*
A
ID@100℃
Figure 3
A
IDM
Figure 6
A
100
W
0.8
W/℃
Power dissipation
PD
Derating factor above 25℃
Gate-source voltage
VGS
+20
V
Single pulse Avalanche Engergy
EAS
260
mJ
Pulse avalanche rating
IAS
Figure 8
A
dv/dt
5.0
V/ns
TL
300
ºC
TPKG
260
TJ ,TSTG
-55 to150
(note*3)
Peak diode recovery dv/dt
Maximum temperature for soldering
Leads at 0.063 in ( 1.6mm ) from case for 10
seconds package body for 10 seconds
Operating junction and storage temperature
range
ºC
*Drain current limited by maximum junction temperature
Caution:Stresses greater than those listed in the”Absolute maximum ratings”table may cause permanent
Damage to the device
5. Thermal characteristics
Parameter
Symbol
Rating
Unit
Test condition
Junction-ambient
RθJA
62
ºC/W
Junction-case
RθJC
1.25
ºC/W
1 cubic foot chamber,free air
Drain lead soldered to water cooled heatsink,PD
adjusted for a peak junction temperature of +150℃
2 of 8
Rev 1.1 JUN 2017
5A,500V
N-CHANNEL MOSFET
KIA
5N50H
SEMICONDUCTORS
6. Electrical characteristics
Parameter
Symbol
Drain-source breakdown voltage
Breakdown voltage temperature coeffcient,
BVDSS
△BVDSS/△TJ
Figure 11
(TJ=25°C,unless otherwise specified)
Test Conditions
Min Typ Max Units
VGS=0V,IDS=250μA
500
Reference to 25℃
V
V/℃
0.61
ID=250uA
VDS=500V, VGS=0V
Drain-source leakage current
IDSS
1
100
VDS=VGS, ID=250μA
2.0
4.0
VGS=20V
1
VGS=-20V
-1
1.25
1.5
Ω
6
S
VDS=400V, VGS=0V
TJ=125°C
Gate threshold voltage,Figure 12
VGS(th)
Gate-source forward leakage
IGSS
Gate-source reverse leakage
VGS=10V,ID=2.5A
Static drain-source on-resistance
RDS(on)
Figure 9 and 10
(note*4)
μA
V
uA
VDS=15V, ID=2.5A
Forward transconductance
gfs
Input capacitance
Ciss
VDS=25V,VGS=0V
525
Output capacitance
Coss
f=1MHz
64
Reverse transfer capacitance
Crss
Figure 14
12
Turn-on delay time
td(on)
9.0
Rise time
Turn-off delay time
Fall time
(note*4)
tr
VDD=250V, ID=5A,
11
td(off)
RG=12Ω,VGS=10V
30
16
14
3.0
6.0
tf
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
VDD=250V, ID=5A,
Figure 15
pF
ns
nC
Continuous source current(body biode)
IS
Integral pn-diode in
5
Maximum pulsed current(body biode)
ISM
MOSFET
Diode forward voltage
VSD
IS=5A, VGS=0V
1.5
V
Reverse recovery time
trr
IF=5A, VGS=0V
400
nS
Reverse recovery charge
Qrr
di/dt=100A/μs
1700
nC
A
Note:1.TJ=25℃ to 150℃.
2.Repetitive rating;pulse width limited by maximum junction temperature
3.ISD=5A di/dt
很抱歉,暂时无法提供与“KIA5N50HD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.67735
- 50+1.35940
- 150+1.22310
- 500+1.00311
