MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
PRODUCT CHARACTERISTICS
VDSS
RDS(on)Typ(@V GS =10 V)
ID
Symbol
60V
13mΩ
50A
2.Drain
1.Gate
APPLICATIONS
* Switching applications
3.Source
4
FEATURES
4
* High Switching Speed
* Improved dv/dt capability
1
2
3
TO-252
ORDER INFORMATION
Order codes
Halogen-Free
Halogen
N/A
N/A
Package
MOT50N06D
MOT50N06C
TO-252
TO-251
1
2
3
TO-251
Packing
2500 pieces /Reel
70 pieces /Tube
ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
RATINGS
UNIT
Drain-Source Voltage
VDSS
60
V
Gate-Source Voltage
VGSS
±20
V
Continuous Drain Current
ID
50
A
Pulsed Drain Current (Note 2)
IDM
150
A
Avalanche Energy
Single Pulsed (Note 3)
EAS
92
mJ
Peak Diode Recovery dv/dt
dv/dt
10
V/ns
Power Dissipation
46
W
TO-251/TO-252
PD
Junction Temperature
TJ
+150
°C
Operation and Storage Temperature
TSTG
-55 ~ +150
°C
Notes: 1. Absolute maximum ratings are those values beyond which the device could be permanently damaged.
Absolute maximum ratings are stress ratings only and functional device operation is not implied.
2. Repetitive Rating : Pulse width limited by maximum junction temperature.
3. L=43mH, IAS=43A, VDD=25V, RG=20Ω, Starting TJ=25°C
4. ISD ≤ 30A, VDS=0V, di/dt ≤ 200A/µs, VDD ≤ BVDSS, Starting TJ = 25°C
-1-
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
ELECTRICAL CHARACTERISTICS (TC=25°C, unless otherwise specified)
PARAMETER
Off characteristics
SYMBOL
Drain-Source Breakdown Voltage
Drain-Source Leakage Current
Forward
Gate-Source Leakage Current
Reverse
On characteristics
BVDSS
IDSS
Gate Threshold Voltage
Static Drain-Source On-State Resistance
Dynamic characteristics
VGS(TH)
RDS(ON)
Input Capacitance
Output Capacitance
Reverse Transfer Capacitance
Switching characteristics
IGSS
CISS
COSS
CRSS
TEST CONDITIONS
60
VDS=VGS, ID=250μA
VGS=10V, ID=25A
1.0
VDS=50V, VGS=10V, ID=1.3A
IG=3mA (Note1,2)
VDS=30V, VGS=10V, ID=50A,
RG=25Ω (Note1,2)
Maximum Continuous Drain-Source Diode
IS
Forward Current
Maximum Pulsed Drain-Source Diode
ISM
Forward Current
Drain-Source Diode Forward Voltage
VSD
IS=50A, VGS=0V
Body Diode Reverse Recovery Time
trr
IS=30A, VGS=0V,
dIS/dt=100A/µs
Body Diode Reverse Recovery Charge
Qrr
Notes: 1. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
2. Essentially independent of operating temperature.
-2-
TYP MAX UNIT
VGS=0V, ID=250μA
VDS=60V, VGS=0V
VGS=20V, VDS=0V
VGS=-20V, VDS=0V
VGS=0V, VDS=25V, f=1MHz
Total Gate Charge
QG
Gate-Source Charge
QGS
Gate-Drain Charge
QGD
Turn-On Delay Time
tD(ON)
Turn-On Rise Time
tR
Turn-Off Delay Time
tD(OFF)
Turn-Off Fall Time
tF
Drain-source diode characteristics and maximum ratings
MIN
10
100
-100
V
μA
nA
nA
V
13
2.5
18
mΩ
2500
230
200
pF
pF
pF
7.2
0.4
0.8
18
46
202
116
nC
nC
nC
ns
ns
ns
ns
50
A
150
A
50
80
1.5
V
ns
nC
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS
Peak Diode Recovery dv/dt Test Circuit
VGS
(Driver)
Period
D=
P.W.
P. W.
Period
VGS= 10V
IFM, Body Diode Forward Current
ISD
(D.U.T.)
di/dt
IRM
Body Diode Reverse Current
Body Diode Recovery dv/dt
VDS
(D.U.T.)
VDD
Body Diode
Forward Voltage Drop
Peak Diode Recovery dv/dt Waveforms
-3-
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS(Cont.)
Fig. 2A Switching Test Circuit
Fig. 2B Switching Waveforms
VGS
Same Type
as D.U.T.
QG
VDS
QGS
QGD
VGS
DUT
Charge
Fig. 3A Gate Charge Test Circuit
Fig. 3B Gate Charge Waveform
Fig. 4A Unclamped Inductive Switching Test Circuit
-4-
Fig. 4B Unclamped Inductive Switching Waveforms
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
TYPICAL CHARACTERISTICS
-5-
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
TYPICAL CHARACTERISTICS(Cont.)
-6-
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
n TO-252 PACKAGE OUTLINE DIMENSIONS
-7-
www.mot-mos.com
MOT50N06C
MOT50N06D
N-CHANNEL MOSFET
n TO-251 PACKAGE OUTLINE DIMENSIONS
-8-
www.mot-mos.com
很抱歉,暂时无法提供与“MOT50N06D”相匹配的价格&库存,您可以联系我们找货
