MOT15N10C
MOT15N10D
N-CHANNEL MOSFET
PRODUCT CHARACTERISTICS
VDSS
RDS(on)Typ(@V GS =10 V)
Symbol
100V
80mΩ
24nC
15A
Qg@type
ID
2.Drain
APPLICATIONS
1.Gate
* Electronic Ballast
* Electronic Transformer
* Switch Mode Power Supply
3.Source
FEATURES
Low On-Resistance
Fast Switching
High Input Resistance
Rohs Compliant
4
4
X
X
1
Package: TO-251 or TO-252(IPAK & DPAK)
ORDER INFORMATION
Order codes
Halogen-Free
2
1
Package
TO-252
TO-251
2
3
TO-251
TO-252
MOT15N10D
MOT15N10C
N/A
N/A
X
3
Halogen
X
Packing
2500 pieces /Reel
70 pieces /Tube
ABSOLUTE MAXIMUM RATINGS (TC = 25°C, unless otherwise specified)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
SYMBOL
VDSS
VGSS
Drain Current Continuous
TC=25°C, TJ=150°C
TC=70°C, TJ=150°C
ID
Power Dissipation
TC=25°C
TC=70°C
PD
RATINGS
100
±20
15
13.8
UNIT
V
V
A
A
34.7
22.2
-55~+150
W
W
°C
RATINGS
3.6
UNIT
°C/W
TJ
Operating Junction Temperature
Note: Absolute maximum ratings are those values beyond which the device could be permanently damaged.
Absolute maximum ratings are stress ratings only and functional device operation is not implied.
THERMAL
CHARACTERISTICS (TA=25°C, unless otherwise noted)
PARAMETER
SYMBOL
Junction to Case (Note)
θJC
Note: The device mounted on 1in2 FR4 board with 2 oz copper.
-1-
www.mot-mos.com
MOT15N10C
MOT15N10D
N-CHANNEL MOSFET
ELECTRICAL CHARACTERISTICS (TC=25°C, unless otherwise noted)
PARAMETER
Off characteristics
Drain-Source Breakdown Voltage
Drain-Source Leakage Current
Gate-Source Leakage Current
SYMBOL
BVDSS
IDSS
IGSS
Dynamic characteristics
On characteristics
Gate Threshold Voltage
VGS(TH)
Drain-Source On-State Resistance (Note)
RDS(ON)
Input Capacitance
Output Capacitance
Reverse Transfer Capacitance
Switching characteristics
CISS
COSS
CRSS
Total Gate Charge
QG
Total Gate Charge
QG
Gate to Source Charge
QGS
Gate to Drain Charge
QGD
Gate-Resistance
RG
Turn-ON Delay Time
tD(ON)
Rise Time
tR
Turn-OFF Delay Time
tD(OFF)
Fall-Time
tF
Source-drain diode ratings and characteristics
TEST CONDITIONS
MIN TYP MAX UNIT
ID=250µA, VGS=0V
VDS=80V, VGS=0V
VGS=+20V, VDS=0V
VGS=-20V, VDS=0V
100
V
1
µA
+100 nA
-100 nA
VDS=VGS, ID=250µA
VGS=10V, ID=8A
1
80
3
100
V
mΩ
VGS=0V, VDS=15V, f=1MHz
890
58
23
pF
pF
pF
24
13
4.6
7.6
0.9
14
33
39
5
nC
nC
nC
nC
Ω
ns
ns
ns
ns
VGS=10V, VDS=80V, ID=10A
VGS=4.5V, VDS=80V, ID=10A
VDS=0V, VGS=0V, f=1MHz
VDS=50V, RL=5Ω, VGEN=10V,
RG=1Ω
Drain-Source Diode Forward Voltage
VSD
IS=8A, VGS=0V
0.9 1.2
Note: Pulse test: pulse width≤300us, duty cycle≤2%, Guaranteed by design, not subject to production testing.
-2-
www.mot-mos.com
V
MOT15N10C
MOT15N10D
N-CHANNEL MOSFET
TY PICAL CHARACTERISTICS
Drain Current vs. Drain-Source
Breakdown Voltage
300
Drain Current vs. Gate Threshold Voltage
300
VDS=VGS
250
250
200
200
150
150
100
100
50
50
90
120
60
Drain-Source Breakdown Voltage, BVDSS (V)
Characteristics
Drain Current vs. Source to Drain Voltage
10
VGS=10V
8
Drain Current, ID (A)
10
0.4
1.6
0.8 1.2
2.0 2.4
Gate Threshold Voltage, VTH (V)
6
4
2
8
6
4
2
0.2 0.3
0.4 0.5
Drain to Source Voltage, VDS (V)
0.2
0.4
0.6
0.8
1.0
Source to Drain Voltage, VSD (V)
Safe Operating Area
100
TO-252
MAX
10
100us
1ms
1 Operation in this area
is limited by RDS(ON)
10ms
DC
0.1
0.01
TJ=150°C
TC=25°C
Single Pulse
1
10
100
Drain-Source Voltage, VDS (V)
-3-
www.mot-mos.com
MOT15N10C
MOT15N10D
N-CHANNEL MOSFET
n TO-251-3L PACKAGE OUTLINE DIMENSIONS
-4-
www.mot-mos.com
MOT15N10C
MOT15N10D
N-CHANNEL MOSFET
n TO-252-2L PACKAGE OUTLINE DIMENSIONS
-5-
www.mot-mos.com
很抱歉,暂时无法提供与“MOT15N10D”相匹配的价格&库存,您可以联系我们找货
