MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
PRODUCT CHARACTERISTICS
VDSS
RDS(on)Typ( @VGS =10 V)
Qg@type
ID
Symbol
700V
2.Drain
2.6Ω
15nC
4A
APPLICATIONS
1.Gate
* High frequency switching mode power supply
* Electronic ballast
* LED power supplies
3.Source
FEATURES
* Ultra Low Gate Charge
* Low Reverse Transfer Capacitance
* Fast Switching Capability
* Avalanche Energy Specified
* Improved dv/dt Capability, High Ruggedness
4
4
1
3
N/A
1
Package
TO-251
TO-252
MOT4N70C
MOT4N70D
2
3
TO-251
TO-252
ORDER INFORMATION
Order codes
Halogen-Free
Halogen
N/A
2
Packing
70 pieces/Tube
2500 pieces /Reel
ABSOLUTE MAXIMUM RATINGS (TA = 25°С, unless otherwise specified)
SYMBOL
RATINGS
UNIT
PARAMETER
V
700
Drain-Source Voltage
VDSS
±30
V
Gate-Source Voltage
VGSS
4
A
Avalanche Current (Note 2)
I AR
A
4
Continuous
ID
Drain Current
I DM
A
Pulsed (Note 2)
16
260
mJ
Single Pulsed (Note 3)
E AS
Avalanche Energy
mJ
E AR
10.6
Repetitive (Note 2)
dv/dt
V/ns
Peak Diode Recovery dv/dt (Note 4)
4.5
PD
49
Power Dissipation
W
°С
+150
Junction Temperature
TJ
°С
-55 ~ +150
Operating Temperature
TOPR
С
Storage Temperature
TSTG
-55 ~ +150
Notes: 1. Absolute maximum ratings are those values beyond which the device could be permanently damaged.
Absolute maximum ratings are stress ratings only and functional device operation is not implied.
2. Repetitive Rating : Pulse width limited by maximum junction temperature
3. L = 26.9mH, IAS = 4A, V DD = 50V, RG = 25 Ω, Starting TJ = 25°C
4. ISD≤ 4A, di/dt ≤200A/μs, VDD≤ BVDSS, Starting TJ = 25°C
-1-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
ELECTRICAL CHARACTERISTICS (TA =25°С, unless otherwise specified)
PARAMETER
Off characteristics
Drain-Source Breakdown Voltage
Drain-Source Leakage Current
SYMBOL
TEST CONDITIONS
MIN TYP MAX UNIT
BVDSS
IDSS
VGS = 0 V, ID = 250 μA
700
VDS = 700 V, VGS = 0 V
Forward
VGS = 30 V, VDS = 0 V
Gate-Source Leakage Current
IGSS
Reverse
VGS = -30 V, VDS = 0 V
Breakdown Voltage Temperature Coefficient △BVDSS/△TJ ID = 250μA, Referenced to 25°C On characteristics
Gate Threshold Voltage
VGS(TH)
VDS = VGS, ID = 250 μA
2.0
Static Drain-Source On-State Resistance
RDS(ON)
VGS = 10 V, ID = 2A
V
10 μA
100
nA
-100
- V/°С
0.6
2.6
4.0
2.8
V
Ω
Dynamic characteristics
Input Capacitance
Output Capacitance
Switching characteristics
CISS
COSS
CRSS
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
Turn-Off Fall Time
Total Gate Charge
Gate-Source Charge
Gate-Drain Charge
Source-drain diode ratings and characteristics
tD(ON)
tR
tD(OFF)
tF
QG
QGS
QGD
VDS = 25 V, VGS = 0 V,
f = 1MHz
520
70
8
pF
pF
pF
VDD = 350V, ID = 4A,
RG = 25Ω (Note 1, 2)
13
45
25
35
15
3.4
7.1
ns
ns
ns
ns
nC
nC
nC
1.4
V
4
A
16
A
250
1.5
ns
μC
VDS= 560V, ID= 4A,
VGS= 10 V (Note 1, 2)
Drain-Source Diode Forward Voltage
VSD
VGS = 0 V, IS = 4A
Maximum Continuous Drain-Source Diode
IS
Forward Current
Maximum Pulsed Drain-Source Diode
ISM
Forward Current
Reverse Recovery Time
trr
VGS = 0 V, IS = 4 A,
dI/dt = 100 A/μs (Note 1)
Reverse Recovery Charge
QRR
Notes: 1. Pulse Test: Pulse width ≤ 300µs, Duty cycle ≤ 2%
2. Essentially independent of operating temperature
-2-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS
Peak Diode Recovery dv/dt Test Circuit
VGS
(Driver)
Period
D=
P.W.
P. W.
Period
VGS= 10V
IFM, Body Diode Forward Current
ISD
(D.U.T.)
di/dt
IRM
Body Diode Reverse Current
Body Diode Recovery dv/dt
VDS
(D.U.T.)
VDD
Body Diode
Forward Voltage Drop
Peak Diode Recovery dv/dt Waveforms
-3-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS(Cont.)
Switching Test Circuit
Switching Waveforms
Gate Charge Test Circuit
Gate Charge Waveform
Unclamped Inductive Switching Test Circuit
Unclamped Inductive Switching Waveforms
-4-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
TY PICAL CHARACTERISTICS
300
Drain Current vs. Drain-Source
Breakdown Voltage
300
250
Drain Current, ID (µA)
250
200
150
100
200
150
100
50
50
2
4
5
6
3
Gate Threshold Voltage, VTH (V)
7
Drain Current, ID (A)
0 200 400 600 800 1000 1200 1400
Drain-Source Breakdown Voltage, BVDSS(V)
Drain Current vs.
-5-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
n TO-251F-3L PACKAGE OUTLINE DIMENSIONS
-6-
www.mot-mos.com
MOT4N70C
MOT4N70D
N-CHANNEL MOSFET
n TO-252F-2L PACKAGE OUTLINE DIMENSIONS
-7-
www.mot-mos.com
很抱歉,暂时无法提供与“MOT4N70D”相匹配的价格&库存,您可以联系我们找货
