HYG035N10NS2P/B
N-Channel Enhancement Mode MOSFET
Feature
Pin Description
100V/180A
RDS(ON)=3.2mΩ(typ.) @ VGS = 10V
100% Avalanche Tested
Reliable and Rugged
Lead-Free and Green Devices Available
(RoHS Compliant)
TO-220FB-3L
TO-263-2L
Applications
Power Switching application
DC-DC Converters
Motor control
N-Channel MOSFET
Ordering and Marking Information
Package Code
P
B
G035N10
G035N10
XYMXXXXXX
XYMXXXXXX
P :TO-220FB-3L
B:TO-263-2L
Date Code
XYMXXXXXX
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
V1.0
1
HYG035N10NS2P/B
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
100
V
VGSS
Gate-Source Voltage
±20
V
TJ
Junction Temperature Range
-55 to 175
°C
TSTG
Storage Temperature Range
-55 to 175
°C
Tc=25°C
180
A
Tc=25°C
490
A
Tc=25°C
180
A
Tc=100°C
127
A
Tc=25°C
220
W
Tc=100°C
110
W
IS
Source Current-Continuous(Body Diode)
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
0.68
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
62.5
°C/W
EAS
Single Pulsed-Avalanche Energy ***
720
mJ
L=0.3mH
Repetitive rating;pulse width limited by max. junction temperature.
Surface mounted on FR-4 board.
Limited by TJmax , starting TJ=25°C, L = 0.3mH, VDS=80V, VGS =10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG035N10NS2
Unit
Min
Typ.
Max
VGS=0V,IDS=250μA
100
V
VDS=100V,VGS=0V
1.0
μA
50
μA
4
V
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)*
TJ=125°C
Gate Threshold Voltage
VDS=VGS, IDS=250μA
2
3
Gate-Source Leakage Current
VGS=±20V,VDS=0V
Drain-Source On-State Resistance
VGS=10V,IDS=50A
3.2
4
mΩ
ISD=50A,VGS=0V
0.88
1.3
V
78
ns
192
nC
±100
nA
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=50A,dISD/dt=100A/μs
www.hymexa.com
V1.0
2
HYG035N10NS2P/B
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG035N10NS2
Min
Typ.
Max
Unit
Dynamic Characteristics
RG
Gate Resistance
VGS=0V,VDS=0V,F=1MHz
2.1
Ciss
Input Capacitance
VGS=0V,
7270
Coss
VDS=50V,
2420
Frequency=500KHz
189
td(ON)
Output Capacitance
Reverse Transfer
Capacitance
Turn-on Delay Time
28
Tr
Turn-on Rise Time
VDD=50V,RG=4Ω,
99
td(OFF)
Turn-off Delay Time
IDS=50A,VGS=10V
70
85
115
41
30
Crss
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=80V, VGS=10V,
ID=50A
nC
Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2%
www.hymexa.com
V1.0
3
HYG035N10NS2P/B
Typical Operating Characteristics
ID-Drain Current(A)
Voltage
Figure 2: Drain Current
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Impedance
Thermal
Normalized Transient
Figure 4: Thermal Transient Impedance
Zθjc
Voltage
ID-Drain Current(A)
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
VDS-Drain-Source Voltage(V)
VDS-Drain-Source Voltage (V)
Voltage
RDS(ON)-ON-Resistance(mΩ)
Figure 6: Drain-Source On Resistance
Voltage
ID-Drain Current(A)
Figure 5: Output Characteristics
ID-Drain Current(A)
www.hymexa.com
V1.0
4
HYG035N10NS2P/B
Typical Operating Characteristics(Cont.)
Voltage
IS-Source Current (A)
Figure 8: Source-Drain Diode Forward
Voltage
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
Voltage
VGS-Gate-Source Voltage (V)
Figure 10: Gate Charge Characteristics
Voltage
C-Capacitance(pF)
Figure 9: Capacitance Characteristics
VSD-Source-Drain Voltage(V)
Q G-Gate Charge (nC)
www.hymexa.com
V1.0
5
HYG035N10NS2P/B
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
V1.0
6
HYG035N10NS2P/B
Device Per Unit
Package Type
Unit
Quantity
TO-220FB-3L
TO-263-2L
TO-263-2L
Tube
Tube
Reel
50
50
800
Package Information
TO-220FB-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.80
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
12.75
13.50
13.80
L1
3.10
3.40
ΦP
3.40
3.60
3.80
Q
2.60
2.80
3.00
www.hymexa.com
V1.0
7
HYG035N10NS2P/B
Package Information
TO-263-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.22
1.27
1.42
A2
2.49
2.69
2.89
A3
0.25
b
0.7
0.81
0.96
b1
1.17
1.27
1.47
c
0.3
0.38
0.53
D1
8.5
8.7
8.9
D4
6.6
E
9.86
10.16
10.36
E5
7.06
e
2.54 BSC
H
14.7
15.1
15.5
H2
1.07
1.27
1.47
L
2
2.3
2.6
L1
1.4
1.55
1.7
L4
θ
0.25 BSC
0°
5°
www.hymexa.com
9°
V1.0
8
HYG035N10NS2P/B
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmaxto TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tpto Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
SeeClassification Tempin table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
V1.0
9
HYG035N10NS2P/B
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HYG035N10NS2B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.18840
- 10+5.18400
- 30+4.63320
