SPECIFICATION
SPEC NO. TFA7NAA00523
DATE : Apr.24th,2020
To
Foxtar
CUSTOMER'S PRODUCT NAME
TDK'S PRODUCT NAME
DEA102025LT-6326B1
RECEIPT CONFIRMATION
DATE :
YEAR
MONTH
DAY
TDK Corporation
Sales
Engineering
Electronic Components Sales &
Marketing Group
Electronic Components Business Company
Communication Devices Business Group
APPROVED
PERSON IN CHARGE
APPROVED
CHECKED
H.Matsubara M.Tsutsumi
PERSON IN CHARGE
H.Ashida
Page 2/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
Specification Change History
Customer's Product Name:
TDK Product Name :
DEA102025LT-6326B1
Ver
Date
Person in charge
Apr.24th,2020
H.Ashida
Change Item
Initial issue
Note
(1.0)
Page 3/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
Low Pass Filter Specification
( TDK Part Number :
DEA102025LT-6326B1
1. Marking
Direction Mark
2. Mechanical Outline
2-1 Package
Package:
Delivery Medium:
Soldering Method:
Size:
Height:
Surface mount package
Tape on reel
IR-reflow
1.00 x 0.50 mm typ.
0.40 mm max.
Mechanical Dimensions
[Bottom View]
[Top View]
L
(6)
T
(5)
(4)
(4)
(5)
(6)
W
d
(3)
(1)
(2)
(2)
(3)
a
Dimensions (mm)
L
W
T
1.00
0.50
+/-0.05 +/-0.05
0.40
Max
(1)
a
b
c
d
0.18
0.125
0.18
0.15
+/-0.05 +/-0.05 +/-0.05 +/-0.05
Terminal functions
NC
(1)
GND
(2)
NC
(3)
(4)
(5)
(6)
Output Port
GND
Input Port
c
b
Page 4/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
2-2 Coplanarity
0.05 mm max. difference in Z-direction as follows
Z
1.0 mm
Coplanarity measurement method
Coplanarity = T1-T2
0.05 mm max.
Each terminal extends the full of the product. Hence any coplanarity deviation between
terminals is due to curvature in the substrate. TDK guarantees that the edge of
each terminal is within 0.05 mm of the horizontal plane.
3. Environment (Temperature & Humidity)
3-1 Operating & Storage Condition
Storage Temperature Range : -40 ~ +85 °C
Operating Temperature Range : -40 ~ +85 °C
Humidity
: 0 ~ 90 %RH (Max. wet bulb temperature 38 °C )
3-2 Storage Condition before Soldering
Temperature
Humidity
Term of Storage
Baking
: +5 ~ +30 °C
: 20 ~ 70 %RH
: Within 12 months (After the delivery) *
: Unnecessary
* After peeling off cover tape, do not keep exposing the products to the open air.
For the products stored longer than 12 months, confirm their terminals and solderability before use.
3-3 Moisture Sensitivity Level
Equal to Level 1
Page 5/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
4. Electrical Specification
4-1 Electrical Characteristics
Parameter
TDK Spec
Min. Typ. Max.
2025 1.05 1.40
2025 1.60
Frequency (MHz)
Insertion Loss (dB)
Insertion Loss (dB)
(–40 to +85 °C)
VSWR
Attenuation (dB)
1880 to
1880 to
1880
2400
3760
5150
5640
7520
9400
to 2025
to 2500
to 4050
to 5850
to 6075
to 8100
to 10125
Characteristic Impedance (ohm)
Ta = +25+/-5°C
1.50 2.0
10 19.0
25 46.0
25 50.0
25 46.0
25 33.0
22 27.0
50 (Nominal)
4-2 Maximum Ratings
TDK Spec
Parameter
Min. Max.
Conditions
Power Handling (W) *1
Human Body Model : HBM
@Each Port (V) -1000
1000 100pF / 1500ohm
Machine Model : MM
@Each Port (V)
-150
150 200pF / 0ohm
Charged Device Model : CDM @Each Port (V)
-500
500 Relative humidity : 60%RH max
0.5
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
Page 6/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
5. Typical Electrical Characteristics
S11
POLA
REF 1.0 U
SCALE 1.0U FS
S21
VSWR
REF 0.0dB
SCALE 0.5dB/
0.6
0.4
0.2
U
INSERTION LOSS
MARKER 1
1880.0 MHz
1.51
MARKER 2
1920.0 MHz
1.35
MARKER 3
2010.0 MHz
1.12
MARKER 4
2025.0 MHz
1.12
MARKER 5
MHz
0.8
-1
Log MAG
0.0
1 jV
1
-0.2
0.5
1.0
1.5
2.0
2.5
3.0
3.5
MARKER 6
MHz
-0.4
4.0
MARKER 1
1880.0 MHz
0.99 dB
MARKER 2
1920.0 MHz
0.96 dB
MARKER 3
2010.0 MHz
1.03 dB
MARKER 4
2025.0 MHz
1.05 dB
MARKER 5
MHz
dB
MARKER 6
MHz
dB
-0.6
4.5
-0.8
5.0
1400
-1
S21
Log MAG
REF 0.0dB
SCALE 5.0dB/
S11
Log MAG
1900
2150
REF 0.0dB
2400
SCALE 5.0dB/
ATTENUATION
5
10
15
30
35
1
40
45
50
1000
S21
1500
2000
Log MAG
2500
3000
3500
4000
REF 0.0dB
4500
5000
5500
6000
MARKER 1
2400.0 MHz
18.6 dB
MARKER 2
2500.0 MHz
29.3 dB
MARKER 3
2620.0 MHz
24.2 dB
MARKER 4
2690.0 MHz
23.9 dB
MARKER 5
3760.0 MHz
46.0 dB
MARKER 6
4050.0 MHz
65.7 dB
MARKER 7
5150.0 MHz
52.4 dB
MARKER 8
5850.0 MHz
50.4 dB
MARKER 1
1880.0 MHz
13.9 dB
MARKER 2
1920.0 MHz
16.6 dB
MARKER 3
2010.0 MHz
25.0 dB
MARKER 4
2025.0 MHz
25.2 dB
MARKER 5
MHz
dB
MARKER 6
MHz
dB
RETURN LOSS
5
10
15
30
35
40
45
50
500
1000
1500
2000
2500
3000
3500
4000
SCALE 5.0dB/
ATTENUATION
5
10
15
30
35
40
1
45
50
2000
3000
4000
5000
6000
7000
8000
9000
10000
11000
12000
13000
MARKER 1
5640 MHz
57.3 dB
MARKER 2
6075 MHz
46.3 dB
MARKER 3
7520 MHz
34.7 dB
MARKER 4
8100 MHz
32.6 dB
MARKER 5
9400 MHz
28.8 dB
MARKER 6
10125 MHz
27.9 dB
MARKER 7
0.0 MHz
0.0 dB
MARKER 8
0.0 MHz
0.0 dB
Page 7/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
6. Test Circuit
Network
Analyzer
50 ohm
PORT1
PORT2
Note 1: The Port Extension
function on the Network
Analyzer is used to extend the
calibration plane to the DUT
terminals.
GND
IN
D.U.T
50 ohm
OUT
GND
7. Recommended Land Pattern
Note 2: Loss in the PCB traces
is
compensated
for
by
measurement data taken on a
PCB Thru’ line.
Page 8/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
8. Environmental and Quality Proposal
This product satisfies the electrical specification after the following tests.
(When measured after two hours in normal conditions)
Temperature
Characteristics
All data initially taken at +25°C, then repeated at -40°C and again at +85 °C
Heat Proof
+85 +/- 2 °C for 1000 hours
Cold Proof
-40 +/- 2 °C for 500 hours
Moisture Proof
Heat Shock
Vibration
+60 +/- 2 °C, 90~95%RH for 1000 hours
-40 ~ +85 °C for 350 cycles,
each cycle being 30 min
10-500Hz vibration frequency (10G Max.)
with 1.52mmp-p amplitude for two hours in x,y,z directions
1.Acceleration 1000m/s2
Mechanical Shock
2.Direction X, Y, Z ,X’,Y’,Z’,axes
3.Time 6ms duration and 3 times in each direction
The dipped surface of the terminal shall be at least 75% covered with
Solderability
solder after dipped in solder bath of 245+/- 3 °C for 3 +/- 0.5 sec.
Remark solder: Sn-3.0Ag-0.5Cu
Remark flux: Rosin 25%, Alcohol 75%
Solder Heat Shock
Drop Shock
It shall be possible to hot air reflow the components three times with
a temperature profile shown below.
Dropped onto steel plate or concrete from 100cm height three times.
Solder specimen components on
the test printed circuit board (L:100
R230
x W:40 x T:0.8mm) in appended
Bending
1
recommended PCB pattern.
Apply the load in direction of the
arrow until bending reaches 1mm
gap+/-1
45
45
for 5+/-1 sec.
Unit:mm
Board Adhesion
(Push Test)
arrow until 5N for 5+/-1 sec.
5N
Page 9/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
9. Recommended Reflowing Temperature Profile
3oC/sec
or lower
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
6oC /sec
or lower
Soldering
Peak
Critical zone (T3 to T4)
Time
Temp.
Time
Temp.
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature.
The maximum number of reflow is 3.
Note: Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Page 10/11
No.
Apr.24th,2020
TDK Corporation
TFA7NAA00523
10. Packing
10-1 Carrier Tape
K
J
Loading Direction
B
D
A
B
t
G
H
F
(Unit:mm)
A
B
0.62 1.12
+/-0.05 +/-0.05
C
8.0
D
3.5
+/-0.2 +/-0.05
E
1.75
F
2.0
G
2.0
H
4.0
J
1.5
+/-0.1 +/-0.05 +/-0.05 +/-0.05 +0.1/-0
10-2 Reel Dimensions
13+/-0.2
13.0+/-1.0
LabelA
2.0+/-0.5
60+1.0/-0
LabelB
21+/-0.8
180 +0/-1.5
9.0 +1.0/-0
10-3 Standard Reel Packaging Quantities
10000pcs./reel
Unit : mm
K
t
0.48 0.20
Max
+/-0.05
C
E
Sprocket hole
Page 11/11
No.
TFA7NAA00523
Apr.24th,2020
TDK Corporation
11. Other
11-1 Caution
The products listed on this specification sheet are intended for use in general electronic
equipment (AV equipment, telecommunications equipment, home appliances,
amusement equipment, computer equipment, personal equipment, office equipment,
measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society,
person or property. Please understand that we are not responsible for any damage or
liability caused by use of the products in any of the applications below or for any other use
exceeding the range or conditions set forth in this specification sheet.
- Aerospace/Aviation equipment
- Transportation equipment (cars, electric trains, ships, etc.)
- Medical equipment
- Power-generation control equipment
- Atomic energy-related equipment
- Seabed equipment
- Transportation control equipment
- Public information-processing equipment
- Military equipment
- Electric heating apparatus, burning equipment
- Disaster prevention/crime prevention equipment
- Safety equipment
- Other applications that are not considered general-purpose applications
When designing your equipment even for general-purpose applications,
you are kindly requested to take into consideration securing protection circuit/device or
providing backup circuits in your equipment.
11-2 Storage Conditions
Do not store the product in following conditions, performance may deteriorate.
- Exposure to atmosphere containing corrosive gas, such as Cl2, NH3, SOx and NOx
- Exposure to volatile or combustible gases
- Exposure to excessive dust
- Exposure to direct sunlight
- Exposure to direct water splashing
- Exposure to freezing temperature
- Exposure to dew condensation due to high humidity
11-3 Product Origin
1. TDK Akita Corporation, Akita, Japan
2. TDK Dalian Corporation, Dalian, China
