R F
C o m p o n e n t s
June 2015
Multilayer Band Pass Filter (Balance Output Type)
For 2400–2500MHz
DEA202450BT-7210A1
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 2400–2500MHz
DEA202450BT-7210A1
SHAPES AND DIMENSIONS
[Top view]
2.00±0.15
0.80max.
(5)
(4)
(1)
(2)
(3)
Marking
1.25±0.15
(6)
0.65±0.20
0.30±0.20
Terminal functions
1 Unbalanced port
2 GND
3 Balanced port
4 Balanced port
5 GND
6 GND
0.25±0.20
[Bottom view]
0.20±0.20
0.35±0.20
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.50
0.80
0.35
Port3
Balance2
0.80
Port1
Unbalance
0.30 0.35
Dimensions in mm
Port2 Balance1
Line width is designed to match 50Ω
characteristic impedance depending
on PCB material and thickness.
Port extension value is
139.56ps for all port.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150605 / rf_bpf_dea202450bt-7210a1_en.fm
RF Components
DEA202450BT-7210A1
ELECTRICAL CHARACTERISTICS
Frequency Range
(MHz)
Item
Unbalanced Port Characteristic Impedance (:)
Balanced Port Characteristic Impedance (:)
Insertion Loss (dB)
Attenuation (dB)
Return Loss at Unbalanced Port (dB)
Phase Balance (deg.)
Amplitude Balance (dB)
2400 to 2500
4800 to 5000
7200 to 7500
2400 to 2500
2400 to 2500
2400 to 2500
Min.
15
165
–2
Typ.
Max.
50 (Nominal)
Matched to TI CC253x, CC254x, CC85xx series
0.95
1.5
28
33
22
183
195
–0.67
2
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DEA202450BT-7210A1
FREQUENCY CHARACTERISTICS
SDS21 INSERTION LOSS
SDS21 ATTENUATION
0.0
10
1.0
Attenuation(dB)
Insertion Loss (dB)
1.5
2.0
2.5
3.0
3.5
4.0
30
40
50
4.5
5.0
2000
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
60
500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Frequency (MHz)
3000
SDD22 RETURN LOSS at BALANCE PORT
5
10
10
Return Loss (dB)
Return Loss (dB)
SSS11 RETURN LOSS at UNBALANCE PORT
15
30
2000
15
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
30
2000
3000
PHASE BALANCE
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
3000
2400 2500 2600
Frequency (MHz)
2700
2800
2900
3000
AMPLITUDE BALANCE
3.0
200
2.5
195
2.0
1.5
190
185
180
175
1.0
0.5
–0.5
–1.0
–1.5
170
–2.0
165
160
2000
–2.5
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
3000
–3.0
2000
2100
2200
2300
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA202450BT-7210A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+5.034265+0.60962
- 50+4.0021850+0.48464
- 250+3.17652250+0.38466
- 500+2.88983500+0.34994
- 1000+2.821021000+0.34161
- 2000+2.763692000+0.33467
- 10000+2.7063510000+0.32773
- 20000+2.6490120000+0.32078
