The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 704-960MHz / 1710-2690MHz
DPX202690DT-4049A2
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX202690DT-4049A2
SHAPES AND DIMENSIONS
2.00±0.15
[Top view]
0.90±0.10
(5)
(4)
(1)
(2)
( 3)
Marking
1.25±0.15
(6)
[Bottom view]
0.65±0.15
0.30±0.15
Terminal functions
1 GND
2 Common
3 GND
4 High-band
5 GND
6 Low-band
0.20±0.15
0.35±0.15
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
Dimensions in mm
0.77
0.32
0.58
0.33
0.932
0.58
0.77
ø0.30 through hole
0.32
0.33
Land
Solder resist
Dimensions in mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx202690dt-4049a2_en.fm
RF Components
DPX202690DT-4049A2
ELECTRICAL CHARACTERISTICS
LOW-BAND
Frequency Range
(MHz)
Min.
Typ.
Max.
704 to 960
704 to 824
824 to 960
1710 to 2170
2170 to 2690
11.73
13.98
15
13
0.24
18.0
19.7
17.7
16.8
50 (Nominal)
0.30
Frequency Range
(MHz)
Min.
Typ.
Max.
1710 to 2170
2170 to 2690
1710 to 2170
2170 to 2690
704 to 824
824 to 960
11.73
7.36
17
0.83
13.8
8.8
20.4
22.8
50 (Nominal)
0.50
1.20
Item
Frequency Range
(MHz)
Min.
Typ.
Max.
Return Loss (dB)
704 to 824
824 to 960
1710 to 2170
2170 to 2690
11.73
13.98
11.73
7.36
17.5
19.4
13.6
8.8
50 (Nominal)
3
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
Power Handling (W)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX202690DT-4049A2
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.5
3.0
500
600
700
800
900
1000
Frequency(MHz)
1100
1200
3.0
1300
1600
10
2200
2400
Frequency(MHz)
2600
2800
3000
1800
2000
2200
2400
Frequency(MHz)
2600
2800
3000
1000
1500
Frequency(MHz)
50
600
700
800
900
1000
Frequency(MHz)
1100
1200
1300
Attenuation
1600
Attenuation
10
Attenuation(dB)
40
50
2000
40
40
50
500
1800
Return Loss
Return Loss(dB)
Return Loss(dB)
2.0
2.5
Return Loss
Attenuation(dB)
1.5
40
1000
1500
Frequency(MHz)
2000
2500
3000
50
2000
2500
3000
RF Components
DPX202690DT-4049A2
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
50
30
40
1000
1500
Frequency(MHz)
2000
2500
3000
50
1000
1500
Frequency(MHz)
2000
2500
3000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX202690DT-4049A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.435991+0.04710
- 10+0.3878310+0.04189
- 25+0.3333325+0.03601
- 100+0.30545100+0.03300
- 250+0.26109250+0.02820
- 500+0.16603500+0.01794
- 国内价格
- 10+0.47454
- 25+0.43819
- 100+0.37924
- 250+0.31931
- 500+0.29966
