The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 698-1616MHz / 1920-2700MHz
DPX202700DT-4035B5
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX202700DT-4035B5
SHAPES AND DIMENSIONS
2.00±0.15
[Top view]
0.90±0.10
(2)
(3)
(6)
(5)
(4)
Marking
1.25±0.10
(1)
0.65±0.05
0.30±0.15
Terminal functions
1 Low-band
2 GND
3 High-band
4 GND
5 Common
6 GND
0.30±0.20
[Bottom view]
0.20±0.15
0.35±0.10
Dimensions in mm
0.89
0.77
RECOMMENDED LAND PATTERN
0.33
0.32
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx202700dt-4035b5_en.fm
RF Components
DPX202700DT-4035B5
ELECTRICAL CHARACTERISTICS
LOW-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
698 to 960
960 to 1572
1572 to 1578
1605 to 1616
698 to 960
960 to 1572
1572 to 1578
1605 to 1616
698 to 960
960 to 1572
1572 to 1578
1605 to 1616
1920 to 1990
2010 to 2025
2110 to 2170
2300 to 2700
9.54
9.54
9.54
9.54
13
10
10
10
0.31
0.57
0.57
0.75
40.1
25.7
24.3
23.1
22
16
15
14
50 (Nominal)
0.50
0.85
0.85
1.10
0.60 (–40 to +85°C)
1.05 (–40 to +85°C)
1.05 (–40 to +85°C)
1.30 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
1920 to 1990
2010 to 2025
2110 to 2170
2300 to 2700
1920 to 1990
2010 to 2025
2110 to 2170
2300 to 2700
1920 to 1990
2010 to 2025
2110 to 2170
2300 to 2700
698 to 960
960 to 1572
1572 to 1578
1605 to 1616
9.54
9.54
9.54
8.52
10
10
18
13
0.74
0.54
0.52
0.53
18.0
16.8
14.1
11.5
14
14
30
25
50 (Nominal)
1.10
0.80
0.80
0.80
1.30 (–40 to +85°C)
1.00 (–40 to +85°C)
1.00 (–40 to +85°C)
1.00 (–40 to +85°C)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX202700DT-4035B5
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
LOW-BAND
Insertion Loss
1.5
2.0
800
1000
1200
Frequency(MHz)
1400
1600
3.0
1800
1800
Return Loss
10
2800
2000
2200
2400
Frequency(MHz)
2600
2800
30
800
1000
1200
Frequency(MHz)
1400
1600
50
1800
1800
10
Attenuation(dB)
Attenuation
Attenuation(dB)
2600
Attenuation
40
50
500
2200
2400
Frequency(MHz)
40
40
50
600
2000
Return Loss
Return Loss(dB)
Return Loss(dB)
2.0
2.5
2.5
3.0
600
1.5
40
1000
1500
2000
2500
Frequency(MHz)
3000
3500
4000
50
500
1000
1500
2000
2500
Frequency(MHz)
3000
3500
4000
RF Components
DPX202700DT-4035B5
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
40
50
500
30
1000
1500
2000
2500
Frequency(MHz)
3000
3500
4000
50
500
1000
1500
2000
2500
Frequency(MHz)
3000
3500
4000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX202700DT-4035B5”相匹配的价格&库存,您可以联系我们找货
