May. 2021 Ver.4.0
TDK Corporation
Multilayer Diplexer
DPX Series
P/N:
2.5x2.0mm [EIA 1008] TYPE
DPX255000DT-5089A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(7)
(6)
(5)
(5)
(6)
(7)
(8)
(9)
(4)
(4)
(9)
(8)
(1)
(2)
(3)
(3)
(2)
(1)
Dimensions (mm)
L
W
T
a
b
c
d
e
f
g
h
2.50 2.00 0.75 0.40 0.55 0.95 0.40 0.30 0.70 0.80 0.90
+/-0.10 +/-0.10
Max
+/-0.10 +/-0.15 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
GND
(4)
High-Band Port
(5)
(6)
(7)
(8)
(9)
GND
Low-Band Port
GND
GND
■ TERMINATION FINISH
Material
Ag
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Insertion Loss (dB)
1447.9 to
TDK Spec
Min. Typ. Max.
2690 0.76 0.95
Insertion Loss (dB)
(–40 to +85 °C)
Return Loss
( Low-Band Port )
Attenuation (dB)
1447.9 to
2690
1447.9 to
2690
10
Parameter
Frequency (MHz)
3300
3500
6000
9000
to
960
to 1189
to 3500
to 6000
to 9000
to 12750
Characteristic Impedance (ohm)
Ta = +25+/-5°C
1.10
13.9
22 25.0
2
4.1
18 26.6
23 24.7
25 29.9
10 13.7
50 (Nominal)
High-Band
Insertion Loss (dB)
3300 to
TDK Spec
Min. Typ. Max.
5000 0.77 0.97
Insertion Loss (dB)
(–40 to +85 °C)
Return Loss
( High-Band Port )
Attenuation (dB)
3300 to
5000
3300 to
5000
12
Parameter
Ta = +25+/-5°C
Frequency (MHz)
100
1164
1448
5100
5850
5950
6000
9000
1.12
16.4
to 1000 30 42.0
to 1189 28 32.5
to 2690 20 24.3
to 5150 0.5
0.8
to 5950 13 20.7
to 6000 15 29.2
to 9000 20 24.2
to 12750 11 16.0
50 (Nominal)
May. 2021
Ver.4.0
TDK Corporation
DPX255000DT-5089A1
( Measurement )
Common
Parameter
Isolation (dB)
Return Loss
( Common Port )
Ta = +25+/-5°C
Frequency (MHz)
100 to
3300 to
1447.9 to
3300 to
2690
6000
2690
5000
TDK Spec
Min. Typ. Max.
20 24.4
18 24.5
10 14.3
12 15.7
50 (Nominal)
■ MAXIMUM RATINGS
Parameter
TDK Spec
Conditions
–40 to +85 °C
Operating temperature (°C)
–40 to +85 °C
Storage temperature (°C)
Frequency (MHz)
Power Handling (W) *1
CW
1
Low-Band
1447.9 to 2690
CW
1
High-Band
3300 to 5000
Human Body Model : HBM
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
Machine Model : MM
@Each Port (V)
+/-500
Humidity : 60%RH max
Charged Device Model : CDM
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ FREQUENCY CHARACTERISTICS
S21
S21
Attenuation
Attenuation
100 MHz
05
100
780
780
960
960
1164
1164
1189
1189
3300
3300
3500
3500
6000
6000
7140
7140
9000
9000
11000
11000
12750
12750
510
10
15
Attenuation[dB]
Attenuation[dB]
15
25
30
30
35
35
40
40
45
45
50
50
55
55
60
60 0
2000
2000
4000
6000
6000
8000
8000
10000
10000
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
29.90
29.90
24.90
24.90
37.28
37.28
5.80
5.80
4.60
4.60
29.96
29.96
26.57
26.57
37.06
37.06
29.86
29.86
33.67
33.67
14.28
14.28
13.44
13.44
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
12000
12000
High band-Port
High band-Port
5
10
10
15
15
25
30
30
35
35
40
40
45
45
50
50
55
55
60
2000
60 0
S31
S31
Attenuation
Attenuation
100 MHz 49.66 dB
4000
2000
S21
High band-Port
Insertion Loss
1447.9 MHz
2100 MHz
2690 MHz
0.5
0.53
0.54
0.76
dB
dB
dB
10000
10000
12000
12000
S31
1.5
2
2.5
3
3.5
Insertion Loss
3300 MHz
3700 MHz
4000 MHz
5000 MHz
0.5
1
1.5
0.77
0.62
0.51
0.69
dB
dB
dB
dB
2
2.5
3
3.5
4
4
4.5
4.5
5
5
500
1000
1500
2000
2500
3000
2500
3500
3000
3500
4000
Frequency[MHz]
Common Port Return Loss
4500
5000
5500
6000
Frequency[MHz]
S11
Isolation
S23
32.72 dB
14.27 dB
22.87 dB
3700
4000
5000
30
40
MHz
MHz
MHz
MHz
28.71
15.74
19.56
25.02
dB
dB
dB
dB
10
Isolation[dB]
1447.9 MHz
2100 MHz
2690 MHz
10
Return Loss[dB]
8000
8000
Insertion Loss[dB]
Insertion Loss[dB]
1
50
100
1180
2690
3300
3650
5420
6000
MHz
MHz
MHz
MHz
MHz
MHz
MHz
51.3
25.5
30.6
30.2
26.1
24.5
29.5
dB
dB
dB
dB
dB
dB
dB
3300
3700
4000
5000
MHz
MHz
MHz
MHz
29.02
16.37
18.33
29.17
dB
dB
dB
dB
40
50
60
60
2000
3000
4000
5000
6000
7000
8000
2000
3000
Low band-Port Return Loss
4000
5000
6000
7000
8000
Frequency[MHz]
Frequency[MHz]
S22
High band-Port Return Loss
S33
1447.9 MHz
2100 MHz
2690 MHz
31.34 dB
14.02 dB
19.31 dB
10
Return Loss[dB]
10
Return Loss[dB]
6000
6000
49.66 dB
dB
44.34
44.34 dB
dB
34.65
34.65 dB
dB
33.09
33.09
dB
29.65 dB
29.65 dB
dB
24.26
24.26 dB
dB
29.37
29.37
dB
0.83 dB
0.83 dB
dB
29.02
20.69 dB
dB
36.34
36.34
dB
24.25 dB
24.25 dB
dB
44.88
44.88
dB
16.29 dB
16.29 dB
dB
19.88
19.88 dB
Frequency[MHz]
Frequency[MHz]
Frequency[MHz]
Frequency[MHz]
Low band-Port
100 MHz
MHz
1000
1000 MHz
MHz
1164
1164 MHz
MHz
1189
1189
MHz
1447.9 MHz
1448 MHz
MHz
2510
2510 MHz
MHz
2690
2690
MHz
5100 MHz
5100 MHz
MHz
5950
5850 MHz
MHz
6000
6000
MHz
6600 MHz
6600 MHz
MHz
9000
9000
MHz
11250 MHz
11250MHz
MHz
12750
12750 MHz
Attenuation[dB]
Attenuation[dB]
Low band-Port
Low band-Port
40
50
40
50
60
60
500
1000
1500
2000
2500
Frequency[MHz]
3000
3500
2500
3000
3500
4000
4500
5000
5500
6000
Frequency[MHz]
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ RECOMMENDED LAND PATTERN
04
4
unit : mm
■ EVALUATION BOARD
4
unit : mm
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.4.0
TDK Corporation
DPX255000DT-5089A1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
Loading Direction
J
E
K
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
2.2 2.7 8.0
+/-0.05
D
3.5
+/-0.05 +0.3/-0.1 +/-0.05
G
F
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
K
t
0.85 0.25
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX255000DT-5089A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.515191+0.58351
- 10+3.6772710+0.47522
- 25+3.3892825+0.43801
- 50+3.1862550+0.41177
- 100+2.99540100+0.38711
- 250+2.76236250+0.35699
- 500+2.59832500+0.33579
- 1000+2.444091000+0.31586
- 国内价格 香港价格
- 2000+2.233332000+0.28862
- 4000+2.100874000+0.27150
- 6000+2.027026000+0.26196
- 10000+1.9376610000+0.25041
- 14000+1.8809314000+0.24308
- 20000+1.8225820000+0.23554
- 国内价格
- 5+1.29082
- 50+1.02482
- 150+0.91077
